Question about Canon CLC-700 Copier
Cannon clc700 error E073
Try switch on and off, but error still come up, any idea to fix or need any parts?
    New Friend:
  • 34 Answers
There is a problem with the transfer drawer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_45d8d6c78cd9f0b6
Posted on Jan 08, 2009
CANNON IR3300 SHOW E0003-000 ERROR WHAT PROMLEM MADE AND WHAT CAN I DO
The main thermistor reading is lower than 140C when paper is moved
The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty. Caution To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
State Turn on the power switch, and clear E002/E003. Thereafter, turn off and then on the power switch. Does the fixing heater operate? NO: See "The fixing heater fails to operate." 2. Wiring Is the wiring from the DC controller PCB to the fixing film unit normal? NO: Correct the wiring. 3. Fixing film unit, DC controller PCB Try replacing the fixing film unit. Is the problem corrected? YES: End. NO: Replace the DC controller PCB
TRY OUT THAT IF U FAIL email me@ kagimuj@ymail.com
Dec 15, 2017 | Cannon Office Equipment & Supplies
E073 0003
hello have a look in side the unit to see if you have any paper no mater how small stuck at the back of the transfer unit,and the transfer drum,if not try cleaning the connections on the back of the transfer unit.also check for a broken switch.
maybe just a good clean may do the trick.
hope this helps
Nov 14, 2012 | Canon CLC 1180 Copier
I have a Canon NP 4080 with an error code E540. When I looked it up it read: lateral movement motor lock. It's an old machine; would like to fix it myself. Any ideas
Hello
According to Cannon
the error E540 is the Stack shift sensor error which may be damage or gone bad, it is recommended that you may consult Cannon Technician for repair.
Hope this helps, good luck
Jan 06, 2011 | Canon imageRUNNER iR C4080 Color Copier
Copier won't stay on. Canon clc700
Most likely the either the scanning lamp or the fuser lamp circuit has on 'open' in it. Check the fuser lamps to make sure they are not burned out and make sure the thermal fuse it good.
Jun 20, 2009 | Canon CLC-700 Copier
Cannon MP830 printer, that is displaying 6A00 error
Yup, the purge thingy needs to be replaced. part number QM2-3032-020. Around $20 bucks for the part, not easy to change.
Jun 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Code error of Cannon IR3300 E000006-0000
getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS
Apr 29, 2009 | Office Equipment & Supplies
CANON CLC 1100
Transfer frame connector try pulling out the transfer drum and look to th rear of the machine and see if there is any paper stuck in the female connector at the rear of the machine.If the problem persists change thr connector.If you need more help get back to me 00447764303923 i am in the uk
Feb 16, 2008 | Canon CLC 1120 Color Copier
Error E073-0004
You need to call a copier technician, first and foremost.
This error code indicates that there is a problem with the transfer drawer connector inside of your copier. You've probably blown a fuse, like the FU903 on the DC fuse board.
There is nothing you can do if you aren't a copier technician. Call one right away; the technician can probably fix this in about ten minutes.
Dec 05, 2007 | Canon CLC 1000 Color Copier
E073-0004
Answered elsewhere, but answering here too:
Canon CLC-700 Copier Logo
82 people viewed this question
old marine
old marine
