Question about NEC PlasmaSync 42PD3 42" Monitor
Thin red line in middle of screen on nec 42 inch plasma monitor
Middle of screen at the bottom half thin red line
  • 15,935 Answers
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Posted on Dec 27, 2008
How do I fix a vertical line on a 50 inch nec plasma monitor
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 28, 2016 | NEC Televison & Video
Have a two inch solid red vertical line center screen.....what may be problem?
If this is a pencil thin line you have a bad plasma panel. The plasma panel is no longer available.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 16, 2014 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Right half of screen black with thin blue line top to bottom about another line inch over another thin line starting blue then red getting thiner to bottom
This is a very common problem with this Panasonic set where half the right side is bad and the other half is good. This has been traced to a general plasma panel defect in the manufacturing precess. The panel lasts only about 1.5 years and they go bad. The only solution is to replace the plasma panel. The charges for the cost and labor will double the original prize of the TV set.Good luck.
Oct 27, 2009 | Panasonic TH-42PX60U Television
Red line in the middle of my plasma screen
Hi leprecoce,
One transistor out of millions has failed shorted. That is an unusual failure mode, but not unheard of. The chip can probably be replaced, you might want to check google maps or http://tvrepair.com for a repair shop near you.
Most shops should be able to give you an estimate, I would guess around $300, unless the chip is hard to get.
Nov 01, 2017 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
Aug 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Problem with Toshiba 42HP83 Plasma TV
Just on a whim I'd say you have video out put circuits in distress.
can you say WARRENTY lol
Aug 24, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
DirecTV installed but TV reverts back to set up screen for the model.
2 yr old 42 inch plasma.screen goes black,sometimes only half screen,sound is on.it does it after 1 hr of viewing, theres a greenish line in the middle of the black sreen when that happens,
pls help.
Jul 04, 2008 | Televison & Video
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Thin red line on Hitachi plasma
If it goes all the way from top to bottom, you have a bad panel. much to expensive to repair
Aug 10, 2007 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
NEC PlasmaSync 42PD3 42" Monitor Logo
295 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
