Question about Whirlpool LEQ9858P Electric Dryer
Dryer wont start
I used my dryer earlier today and it worked fine. Now when I go to push the start button nothing happens. There is pwer to the dryer and the light is working. If you turn the timer dial you can hear that working also. What could be wrong??
  • Anonymous Jan 02, 2009
    It stopped mid cycle and I can't get it to re-start... when i hit the start button I hear a faint noise... but the dern thing won't go.
  • Anonymous Mar 14, 2014
    I have power to the dryer, when I hit the start button nothing happens. The timer does work but nothing else does. i can make the dryer drum move fine so i don't think its the belt. I believe it might be the starter button
  • 15,935 Answers
Http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208522243.pdf
if possible, with the door open, push the limit switch the door normally hits to let the drier know the door is shut. That switch may be bad.
Posted on Dec 27, 2008
Lenovo thinkpad t400 laptop wont open
try changing the keyboard because switch is on keyboard and use adapter to plug and test
Mar 25, 2014 | Computers & Internet
I have a MEDC400VWG drier.Woked fine yesterday. Put clothes in it today. Pushed start button. nothing happened. Smelled somthing getting hot. opened drier. Heating coils lit up. (with door open). Turned...
Sounds as if the motor centrifugal switch is stuck. Check to see if lint built up around switch or centrifugal mechanism on motor shaft. Rap switch with the handle of a screw driver hard but don't break it .
Nov 01, 2010 | Maytag PYE3300 Dryer
Kenmore 63022 electric dryer, about 7 years old, h...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 20, 2010 | Dryers
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Kenmore 600 Series gas dryer
trigger broken dryer will not turn on. I need a replacement. Where can I buy this part.
Nov 02, 2008 | Dryers
Kenmore 110.69912990
Need more info. Check voltage at outlet. Check thermal fuse,
check thermal cut-off assy. Then you have question -what caused the thermal to fail? There are several.
Mar 17, 2008 | Kenmore 73952 Gas Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Whirlpool LEQ9858P Electric Dryer Logo
393 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
