Question about RCA F27650 27" TV
Rca f27650 27"tv w/vport
Hello,i recently bought a philips dvdr3505/37 that has an hdmi terminal. is there a way to connect to my tv using the vport slot on it or can i only use the rca vport cable for enhanced dvd viewing,which i am only assuming is also known as progressive scan? would appreciate any input on this... thx, raccerexx
    Novelist:
    Champion:
  • 236 Answers
The hdmi port is for high definition multimedia interface. You should be able to send standard video through the Vport to your set. (RCA phono jack and plug) Stargazer
Posted on Apr 23, 2007
SOURCE:
How should I connect my Technics SA-AX730 receiver to my Panasonic TC-40A420U that uses HDMI?
I assume the Panasonic is a TV. I have never heard of green audio outputs. Audio outputs should be red and white (for RCA plugs). There are adapters available that convert the yellow, red and white component outputs to HDMI. You can get them at GameStop (I bought one recently to connect a game system for my daughter). If you have a TV converter box from your cable or satellite provider you might be able to connect the audio out on the cable box to your Technics receiver and run a HDMI to the TV (be sure to turn off the TV's internal speakers through the TV's menu) for video.
Oct 15, 2014 | Technics SA-AX730 Receiver
My tv is speaking spanish on only the usa channel please help me
Using your remote control that came with your tv, go to menu, then settings, scroll down to language and select ENGLISH then exit
Apr 08, 2014 | RCA 32v550t 32" Tv With Xbox-ready Vport
I just bought a phillips blu ray and trying to hook it up to my sanyo 50" plasma through a hdmi i get video but no sound the tv says to use the dvi port and audio 3 inputs but the blu ray does not hav
Hello there, the hdmi cable is a great way to get high definition video from a bluray player to a tv, but if the bluray player is part of a surround sound system you will need to get the sound to the tv separately. There is often a red and white audio terminal in the rear of the bluray player, sometimes located next to a yellow terminal, these are known as a component connection as each component (coloured terminal) is separate and operates a separate function, but all 3 connections can be used together to create a SCART equivalent. You may need to connect an 'Audio Component to 3.5mm jack' cable from the white and red terminals to the headphone/line in socket on the tv.
alternatively, as wilth my player, there is a button on the remote which switches the audio source from component, hdmi, SCART, etc, this may be the same for you.
hope this helps.
Mar 12, 2014 | Televison & Video
How do I connect my Coburn home theater to my Sony 52 inch projection TV I tried but get no sound
if the coburn has a scart interface u willl need a scart cable that terminates to rca the simple av vcr cable jack then ;ug the scart end to the theater and the rca to the tv front jack inputs n u ae ok alternatively get a hdmi cable that terminates to rca and connect the hdmi end to the theater and the rca to the dvi/ dvd/compoment input remember sony use icons not words for there accessories for audio input the icon is an in-arrow to a square box and output an out-arrow from a square box select tv. dvd or component av before u start
Jul 19, 2013 | Televison & Video
My philips tv only has a hdmi connector and my asus laptop only has a vga connector I bought a cable with a hdmi and a vga connectors but it didn't work any suggestions.
Your tv surely has a Composite RCA connector - the yellow round one. You must buy this and use it as described
http://sewelldirect.com/pc-to-tv.asp
Dec 10, 2010 | ASUS Computers & Internet
How do I connect a presario CQ60-211ds to a Philips 42pfl3704d/f7
Hi, I don't know if you have sorted it out, but here goes.
I have a slightly different model to you, but mine has a HDMI output and my TV also has HDMI, just connect the 2 together whith a cheap HDMI cable, not need to spend a fortune and you should be sorted. There is another way and that is using the monitor ( VGA Connector ), but I don't think your TV has a pc input. I have just found this while typing.
http://www.p4c.philips.com/cgi-bin/dcbint/faqview.pl?ctn=42PFL3704D%2FF7&dct=QAC&new_tmpl=1&refdisplay=QAC_72673&refnr=0072673&scy=US&slg=AEN
Give it a read but basically the only connection you can use is hdmi unless you have a dvi connector on you laptop.
I bought a wireless keyboard and mouse and left the laptop near the TV so i can use it from my armchair.
Let me know if this has helped.
Tony
May 30, 2010 | Compaq Presario CQ60-212US Notebook
Cant get audio from my hdmi rca sockets
The problem is that you are trying to use too many connections at once and it is confusing the system. HDMI connection covers both sound, and video. So, no other connection is needed. Try using only HDMI. If that does not work. Use DVI for video and RCA for sound. Also you may need to change the settings in your PC so that it recognises that it is connected to HDMI, or whichever connection you decide to use.
Apr 16, 2009 | Samsung LN-T3253H 32 in. LCD Television
How can i unlock philips hotel tv 21ht3302/41?
hey pls help me.. I have this Tv and igit buttons 3,1,9,7,5,3
and the mute button was worked.
but recently
above code doesn't work,as i remeber I put high security in menu.but What can i do now,please help me.
please...
raveendramax@gmail.com
Aug 14, 2008 | Philips 20PT6441 20" TV
DVD Connection and Surroundsound 7.1 Onkyo
gotta use rca audio cables in addition to the hdmi on this tv
Feb 09, 2008 | Philips 51PW9303 51" Rear Projection...
Open Questions:
Letterboxing: The top and bottom of the screen are cut off I originally obtained this TV from my Bro who passed away from cancer at age 31 a few years ago & I was never able to find out what he did with the manual. However, I was able to find a manual online but after viewing it, I still wasn't able to find the info. that I am trying to obtain for the correct settings to get rid of these black margins at the top & bottom of the screen. I am trying to find out what video output format is supported by this TV model, as far as the resolution and output format, specifically for a Cisco or AKA Scientific Atlanta 500GB HD-DVR through Cox cable? My available settings with Cox cable & the DVR I have( Cisco or Scientific Atlanta 500GB model)are the following-Resolution:480i, with output format of either:Zoom 16:9 Pic or Letterbox 16:9 Resolution:480p standard, with output format of either:Zoom 16:9 Pic. or Letterbox 16:9 Resolution:480wide, with either output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic Resolution:720p wide, with output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic and finally, resolution:1080i wide with output format of:Stretch 4.3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic? Everything worked fine with the screen size when I had a 160GB Motorola HD-DVR with Cox under the video output settings of:resolution:480i and video output of:Zoom 16:9 Pic until, I grew tired of constantly running out of space & had them switch me to a 500GB HD-DVR. They were supposed to install another Motorola HD-DVR but just with 500GB version but when the Cox maintenance employee showed up to swap them out and install the 500GD HD-DVR, he only had a Cisco/Scientific Atlanta 500GB available on his truck, which is I guess what they use for the Contour service but he attached a filter to the back of the coxial cable to make it a regular HD-DVR without Contour(even though they tried charging me extra for contour for 3 months before I finally got that straightened out since the maintenance workers & billing dept. are often not on the same page as I found out at Cox. I have tried calling Cox for support & they say that I need to find out & know my TV's video output settings. I explained to them that it worked perfectly fine just weeks ago with 480i resolution and output format of Zoom 16.9 Pic before they switched to the Cisco/Scientific Atlanta HD-DVR from the Motorola DVR and that I didn't have the manual and I stated why and they basically said, too bad, figure it out yourself. Can someone please help me out? I have the TV set up for the correct zip code, cable box-Yes, the cable box output channel-video 1/Aux (since that is what the TV manual I read online said to use if you are using the 3-color coded cables instead of the coxial cables to plug in from the TV to the HD-DVR) & I have the Cable box remote control code set to code 008 (Scientific Atlanta) that I verified to be correct by checking it through the TV's automated code search. The serial # for the TV is:C306B2084 and the Chassis # is:ATC113BB1 and its the 27" RCA Entertainment Series Guide Plus Gold Gemstar that is X-Box ready. Thanks so much, Todd
Feb 26, 2017 | RCA F27650 27" TV
RCA F27650 27" TV Logo
93 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
