Question about Yamaha YST-SW1500 Subwoofer
Yamaha YST-SW150 subwoofer popping
My Yamaha YST-SW150 subwoofer starting popping randomly. I had not used it for 6 months and now it is too annoying. It sounds like something internal. Is it in the sensing circuit that turns it on? Is there an internal adjustment or fix for this? A circuit diagram would be greatly appreciated.
2 Suggested Answers
  • 238 Answers
SOURCE: Yamaha YST-SW150 Subwoofer
hi, is it a humming noise ??? check if the connector is plugged in properly,check the earthing, if its a three pin mains plug, if its a two pin, then the CPU SMPShave a proper eathing. let me know
Posted on Jan 12, 2008
I obtained a pair of Yamaha YST MS50 speakers with no subwoofer. Can they be adapted to use a different sub, such as the inexpensive Yamaha YST MSW5? The clear problem is in different cabling.
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 03, 2016 | Yamaha YST-MS50 Computer Speakers
My wharfedale sw150 subwoofer cuts out in normal viewing, any suggestions
If your Wharfedale sub is powered, it gets its input from a subwoofer output on the rear of the Sony. At a certain level, your sub is turned on and sounds just fine until the level decreases during quiet passages of music then it turns off. I believe the theory is that this approach prevents start-up "pops" but in practice it is a poor solution. I have had several subs that have acted this way. I don't know of a way to fix this short of eliminating the level-controlled turn-on circuit
Sep 28, 2012 | Wharfedale SW150 Subwoofer
How do I connect the YST-SW45 sub to a different system
It's a standard non-proprietary standalone self-powered sub that accepts any input one could want. Your unnamed electronics will be the determining factor. Manuals spell it all out.
Aug 05, 2011 | Yamaha YST-SW45 Subwoofer
No sound from my Yamaha YST-SW315 subwoofer. When I run the test speakers don't have sound either. Not sure if its the subwoofer or the Yamaha RX-V450 receiver
Feed it with an RCA cable any other audio device you may have (CD, TV, MP3 player, PC) to prove it can or can not woof. It will respond to any audio, not just LFE or subwoofer audio.
Apr 14, 2011 | Yamaha YST-SW315 Subwoofer
I have a YST-SW150 speaker that turns it self off after 7 minutes , turn it back on and it'll go again for 7 minutes, (sounds good those 7 min) music sensor auto on/off is off
I just fixed one of these with the same symptom.
In between the power supply board and the amplifier board are a number of rather fine interconnect wires. One of these is the shutdown/startup control line for the auto on/off function.
In my case the wire had been pinched where they are cable tied together. Causeing the power supply to think there was no music input and should shut down.
rejoing the broken wire rectified the problem.
In my case more than one wire had been damaged.
the shut down line is labled SO on the amplifier board connector.
Aug 10, 2010 | Yamaha YST-SW150 Speaker
Yamaha YST-SW320 subwoofer won't play sound
I too have amplifier and speakers thatI rent for parties, and sometimes when I connect them they don't work and I battle with them for hours before I find the out that its just a little thing that happened, like speaker wire might have cut inside, or the wire conneted for the CD to Amplifier is bad and son on.
But I will advice that you test your amplifier and woofer, with another equipment independently to be sure if they still working well or not. As this will help you to know what to do next.
May somthing happened to one of them the last time you used it and you did not notice, and it might just need some servicing.
Best wishes
Nov 13, 2009 | Yamaha YST-SW320 Subwoofer
Jan 10, 2008 | Yamaha YST-SW150 Speaker
Yamaha YST-SW1500 Subwoofer Logo
81 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
