Question about Tomtom ONE GPS Receiver
Hi i have just downloaded the quick fix gps and i am not sure hwat i do next regarding install.my problem is that i can not recive no sat signel
Take unit outside, some do not work indoors
Posted on Dec 27, 2008
It keeps losing the plot!
hi
if your device has not enough satts it wil not be able to calculate its correct position. when its loosing the plot you can have a look howmany sats he receives. if it are only 2 or 3 it can be the problem. what you can do to make it receive more satts, is go online with tomtomhome and load newest quick gps fix. thats a file with satt info for the next period of two months. it will search faster and know more satts. good luck.
Feb 16, 2010 | Tomtom ONE GPS Receiver
All I have is a flashing signal that says waitig for valid GPS signal
Another thing to try:
Tap the satellite bars in the lower right corner. This will bring you to a screen called "Status summary." You'll see satellite bars on the right-hand side of the screen. Tap them.
This will bring you to GPS Status. Tap "Configure" in the lower left corner. Change the coordinate display to D.D (or if it's on D.D right now, change it to DM.M). Tap "Done" then "Done" again.
Has that fixed the problem?
Nov 24, 2009 | Tomtom One XL GPS Receiver
Sat nav just stopped working today in perth wa, not picking up any sat signal. any way to fix this? is it my sat nav or the sats?
It isn't the sats. They're fine.
Try resetting the unit. Use a paper clip to press the button in a small hole on the bottom.
Try to reset the sats. To do this:
Tap the satellite bars in the lower right-hand corner.
Then, on the next screen, tap the satellite bars in the right-hand margin.
On the next screen, select "Configure." Choose a different configuration. Tap "Done," then "Done" again on the next screen.
Did that help?
Nov 03, 2009 | Tomtom GO 300 GPS Receiver
My tomtom keeps losing sat sig?
update your sat nav by going to the quick gps fix. I recently couldn't get a signal and wonderd why this was happening. You need to do the gps update /fix - I did last night and I tested it this morning and now everything is back to normal!
Jun 23, 2009 | Tomtom ONE XL GPS
Wont lock Sats
Update it at Garmin to resolve GPS problems.
Regards.
Apr 13, 2009 | Garmin zumo 550 GPS Receiver
Sat Nav, Online mapping not good
Check out the Terracrosser software, this uses Google maps but allows you to use downloaded maps. Terracrosser works on my S620 although I haven't been able to get my BT GPS unit to function properly with any mapping software. I have tried setting it to COM 6 as previously suggested.
Jan 29, 2009 | HTC S620 Smartphone
My garmin gps will not pick up satellite
Try updating it Garmin.com/web-updater,
Jack it to the Pc and download/run it,
Sometimes Cure's sat problems.
Regards.
Jun 23, 2008 | Garmin Nuvi 350 Car GPS Receiver
Navman510
It will take ages to find a signal the first time it tried. Once locked on it should pick up the sats really quickly the next time you turn on the device.
If you turn it off completely (battery switch to off) then it will take ages again the next time it is turned on.
Hope this helps.
Mar 25, 2008 | Navman iCN 520 GPS Receiver
Garmin 310 sat nav ~ "Full Memory"
first thing i would do is make sure you have the latest software and firmware
http://www8.garmin.com/support/download.jsp
Jan 15, 2008 | Garmin nuvi 350 GPS Receiver
Garmin gpsmap 60csx won't acquire satellites
I found the solution that fixed my 60CSx. You need to make sure you have the latest chipset installed on your device. Go to
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00422-00&cID=145&pID=310
and download the chipset type G ver 2.9.
After you have loaded it on your 60CSx, you should be good to go. Just turn it on like you normally do and now you'll see your device retrieving locks w/ the satellites.
Let me know if this helps you out.
Charles
Dec 10, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Tomtom ONE GPS Receiver Logo
35 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
