Question about Coby DVD-224 DVD Player
DVD Player not working
Hi I'm having a problem with my DVD player. Though the player is showing the power on but non of the buttons on the player as well as the remote is working. Thnaks, Saikat Bose
I have the same problem this is the 2nd one i have bought and this is the only one i have gotten a problems with when ever i find something i'll let you know
Posted on Apr 22, 2007
SOURCE:
What's wrong with my sony dvd player?
I would just replace it rather have repaired even if that's possible , they don't cost a fortune and are easy to fit.
Oct 20, 2014 | Sony Televison & Video
How do you get DVD picture to show up? Power is
You DO NOT use "Channels" to View a DVD player it usually connected to the AV External input. via AV, Yellow, (Video) Red & White, (Audio) or Component Video, Blue, Red & Green. (Video) + Red & White (Audio). These are selected via the External Inputs.
Feb 18, 2010 | Zenith ZDA311 DVD Player
I want the code to play Zone 2 DVDs on my DVD which is set for 4
1) Turn on the player with no disc in the tray
2) Press the Open/Close button to open the tray
3) Press the info button, the firmware version shows up (
4) After the version info disappears, close the tray again by pressing the Open/Close button
5) At this point, it will show "no disc" at the top. Press the Info button again, and this will disappear. If the "no disc" does not disappear then try again by using the REPEAT button
6) Now type the code that applies for your region (R2 is 57538). A '2' will briefly show up at the top left corner
7) Now press 9, and 9 will show up in the top left corner
8) Power off the player, and turn it on again. You'll have a multi region player
I've found the following codes at the 1080P7 hack:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
This worked on my dvd1080p9 R2 DVD player
Oct 17, 2009 | Samsung DVD-1080P9 DVD Player
My dvd player wont let me push anything it just says hold on..i can use the remote though..
To enable the hold function, on the front of the DVD player, slide the POWER/HOLD switch to the right.
****To disable the hold function, slide the POWER/HOLD switch to the left.
NOTE: When the hold function is enabled, the buttons on the DVD player are locked so they will not work if accidentally touched.***
Aug 25, 2009 | Sony DVP-FX730 Portable DVD Player
Pioneer Dv 285 powers down after 15sec
Hi There, I've got the same problems with my DV 285. My power started going off approximately 5 to 10 minutes into the DVD. The only button that seems to work is the OPEN/CLOSE button. Once the tray closes, the unit shuts off. I can't even use the on/standby button to turn it on.
Feb 22, 2009 | Pioneer DV-285-S DVD Player
Installed memorex mvd2042 dvd player, receive message "root"
Aha. I just found a solution. Press DVD menu on the lower left.
Dec 29, 2008 | Memorex MVD2042 DVD Player
I want to buy a dvd player bush modelDVD2054DIVX or a wharfedale with HD upsscaling in IRELAND and bring it to MAURITIUS.I want to know if they will play normally or there will be region code or something...
Heres the code for the bush. don't know about the other one though.
To convert this player to multi-region
1. Power off your DVD player
2. Power on your DVD player
3. Press the Open button on your remote control to open the drive tray
4. Press the 1 button on your remote control
5. Press the 0 button on your remote control
6. Press the 3 button on your remote control
7. Press the 0 button on your remote control
8. Press the 0 button on your remote control for multi-region playback
9. The onscreen display will indicate the currently selected region
10. Power off your DVD player
11. Power on your DVD player
Jul 28, 2008 | Televison & Video
HELP - Samsung DVD player P347
From the manual...
Connect the DVD to the TV via S-video or Video outputs (not component video) and...
• Press power on from a cold start with no disc in the unit. Press the
SEARCH/SKIP ( ) button on the front panel for 1 second.
The SELECT MENU LANGUAGE display will appear.
Select the number button of the desired language.
regards, Glenn
keraurus (at) gmail.com
May 17, 2008 | Samsung Televison & Video
Disk stuck inside player, LOCK shows on display
Try pushing and holding the power button until lock is cleared. I have a different model daewoo dvrs04 but that's how it works for my dvd. Hope it helps
Mar 16, 2008 | Televison & Video
DVD screen has coloured line going all the way though it
what comes to mind that u droped it... not enough info to know take it to a pro
Jan 06, 2006 | Samsung DVD-L70 Portable DVD Player
Coby DVD-224 DVD Player Logo
104 people viewed this question
Top Coby Televison & Video Experts
Steve Allison
Steve Allison
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
