Question about Fujitsu 18C1 Air Conditioner
Fujitsu ASTA18JCC Operation light and timer light blink simultaneously twice then operation light blinks 4 times.? any ideas what error message is?
5 Suggested Answers
SOURCE: Fujitsu Heat Pump - problems
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Posted on Aug 08, 2008
meBNme
  • 334 Answers
SOURCE: Operation light and timer light blink 5 times?
Locate the manual, or the wiring schematic (usually located on the main cover panel inside for the unit.) and look at the flash codes.
This will tell you what the 5 flash and single flashes mean.
We can then help determin what needs to be done from there.
Posted on Dec 13, 2008
  • 288 Answers
SOURCE: HI, I have a Fujitsu ASTA18lCC. Fan working but
trying to get the compressor to operate. it could be a bad capacitor and the compressore wont start or maybe the compressor is burned up
Posted on Dec 15, 2009
Testimonial: "Thanks for the advice. It turned out that we had a blackout after the AC had started playing up. The blackout seems to have sorted out the problem.Thx"
  • 10 Answers
SOURCE: I have a fujitsu asta18lcc when you turn it on
Below is an extract straight from the fujitsu service manual:
Compressor location error
The compressor speed does not synchronze with the control signal. (Including start up failure of the compressor).
> permanent stop.
[Diagnosis Point]
Check if 2-way valve or 3-way valve is left open.
Check the compressor (Winding resistance value, loose lead wire).
Refrigeration cycle defective (Refer to after mentioned "refrigerant cycle diagnosis")
Posted on Jul 15, 2010
What does error message mean on Fujitsu inverter aircon model ASTA30LCC. red operation light flashes on 5 times with green timer light flashing on twice. Can someone please tell me what the fault is?
This is an "Outdoor unit control error" - specifically, a "Current trip error". There is a problem with one or more of the outdoor boards and you will need a tech to diagnose.
Jul 18, 2016 | Fujitsu Heating & Cooling
We have fujitsu inverter plasma airconditioner mpdelastb09ldc ths fan runs but timer light blinks 3 times but outdoor does not start
Hi Rajneel,
I hope this link is of some help to you
Good luck
http://www.climatecenter.co.uk/wcsstore/ClimateCenter/Attachment/downloads/fujitsu-trouble.pdf
Feb 10, 2015 | Fujitsu Heating & Cooling
How to turn off the timer on the Fujitsu AC Model AR-RAC3E?
Hi Rismita,
I hope the following link is helpful for you
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Jan 18, 2015 | Fujitsu Heating & Cooling
Fujitsu ASY12RSE-W. Unit not working at all. Timer lamp blinking & operation lamp flashing twice
It's showing an error code for the outdoor unit no communication from the outdoor circuit board.
Jul 30, 2013 | Fujitsu 24C1 Air Conditioner
Timer light flashes twice on my asta09lcc but it wont work
If operation light is normal and timer light flashes twice, the error is:
Serial signal (reverse) error, at operation start up
Most likely a faulty outdoor controller PCB. Around $250 for new board plus labour.
Jul 09, 2012 | Fujitsu 18C1 Air Conditioner
What dose 3 blinks on a fujitsu asta18lcc
Return air sensor short circuit. Replace it. Thanks.
Feb 04, 2011 | Fujitsu 18C1 Air Conditioner
Model#asu9cq error code
need model and make, and serial if you have it, its an error code, but without make, cant tell u!
Aug 05, 2009 | Fujitsu 18C1 Air Conditioner
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu Heat Pump - problems with timer? When starting the heat pump - the operation light, together with the timer light blinks twice, then the operation light blinks another five times. Then the...
Jun 24, 2008 | Fujitsu Heating & Cooling
Fujitsu 18C1 Air Conditioner Logo
286 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
