Question about Sony KV-32S42 32" TV
No picture I am unable to get a picture or audio when using the S video and A/V connectors
    Scholar:
  • 77 Answers
Some tvs will not let you use both composite and s-video at the same time if theyt share an input, obviously check your source and be sure your looking at the input you have connected. Beyond that it is odd for all inputs to be bad, but if so you may need a pro to have a look
Posted on Apr 21, 2007
No picture
A bad coax connector would still leave you with snow or noise on the screen, you tried a video input as well?
Dec 18, 2012 | Zenith Z19A02G 19" TV
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 10, 2011 | Televison & Video
I have a Sanyo DWM-390 DVD player and I can't get the video on my TV. I have the DVD player going directly to my TV versus my cable box. I have the video and audio chord in the corresponding audio and...
3 possible solutions to your problem starting with the easiest:
1. The audio/video cable is bad. It is possible the video side of the cable has a short.
2. Inputs on the back of the TV are mislabeled or aren't matching up with how you are connecting or using the inputs. Feel free to post a picture of the back of the unit with your cords attached and I can tell you for sure.
3. Some dvd players require you to select which video output mode to use. Most of the newer ones come defaulted to hdmi output and might need a menu selection changed to output using component or composite outputs (whichever you are using). Composite will just have the red and white connector for audio and a single yellow connector for video. Component uses the same 2 audio connectors and then red, green, blue conectors for the video.
Let us know more detail and I can help further.
Jun 14, 2017 | Sanyo DWM-390 DVD Player
Unable to download video to my Mac
Google a program called
Video Download Studio
then you can use it FREE download video or audio form YouTube, google, metacafe, redtube, dailymotion etc. attention: download function is no need to register
you can also use it to convert video to audio, video to video, audio to audio.
use it convert video to mp3 mp4 for your iPod
tutorial;
http://www.downloadvideos-convert.com/how-to-use
Jun 30, 2010 | Canon VIXIA HF R100 High Definition Flash...
I need to know how to hook up to dvr player
In order of picture quality:
Best way is with an HDMI cable if they have that but seeing as that seems to not be HD it probably won't.
Second would be to use component if it has that. That where the picture has 3 cables and then you have the 2 audio cables. They use RCA connectors.
Third would be S-VHS for picture. This looks different than the others, the input will look round with a bunch of holes for the pins of the cable. Again, use the 2 audio cables.
Last, which may be the only thing that dvd/vhs has is use composite video cables. This is where you have one video cable and the 2 audio cables. They are color coded, yellow is picture and the 2 audios are red and white for R and L. If you don't have a cable for that, this is what you need:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10241&cs_id=1024101&p_id=6026&seq=1&format=2
Now if both decks don't have the same connectors you can get cables with different connectors on each end. You can find them at the same place as the above link.
Once you determine what cable you need you pretty much just need to connect them based on the color coding of the cables and inputs on the components.
Nov 15, 2009 | Emerson EWD2203 DVD Player/VCR
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Ive connected my ps2 to a flat screen LG but the picture is jsut black and white. i ntoice the component part had a exstra 2 connection for video output where the cable i use has onle 2 audio and 1 video...
You have to purchase a component cable with blue, green and red connectors. This is a pcb set up. Also you will have to use your audio connections (red & white0 that correspond with the video imput you are trying to use. What it is doing is only getting one video signal through your yellow connector therefore displaying no colors.
Sep 24, 2009 | Sony Video Game Consoles & Games
XBOX 360
Your tv could have a losse connection on the video input. Try moving it around to see if you get any picture. Either that or u need a new audio video cord for your console
Feb 15, 2008 | Microsoft Xbox 360 Console
Sound and picture
Check that you have connected the component video lead to the correct sockets in both the TV and the HTS9800W.
There are two sets of Phono (cinch) connectors, which are grouped together.
Red / Green / Blue - Component connectors - video only
Red / White / Yellow - Stereo audio and composite video connectors - audio and vide
If you have inadvertently connected the red audio connector to the red component input on the TV, it would cause similar symptoms as you describe.
Jan 13, 2008 | Philips Cineos HTS9800W System
Open Questions:
See all Sony KV-32S42 32" TV Questions
Sony KV-32S42 32" TV Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
