Parking lights come on. just headlights wont power on.
SOURCE: headlights wont come on, but parking lights work...i dont get it
Was sent in by another poster, just posting his results which fixed mine. Problem was relay $50.00 at GM only.
Check the relay module. 45 or 46. on the engine relay block. you can
swap the two they are the same part number, then you will know. Dont
start the engine, just check the lights. If it works replace the relay
module. You may have to order the part from the parts store. Or go to
the dealer to get it.
SOURCE: CHEVY 1500 TRUCK HEADLIGHTS TURN OFF WHEN YOU TURN ON SWITCH
If you have replaced the switch, and it is still doing it it sounds like you definately have a short somewhere in your wiring. On the other hand if the dimmer is in the turn signal arm ( forward bright back dim ) the problem could also be there in the dimmer switch, such as a short being caused by that dimmer switch being faulty.Auto Zone and Discount Auto Parts both test a lot of your electrical problems for free, and/or may have some knowledge to more accurately pin point the problem. Not sure about Pep Boys or some of the other discount auto part chains.
SOURCE: 1998 Express van Turn signals
You loose all turn signal lights outside? Do they blink on the dash?
SOURCE: 85 Chevy k10 pickup: Working headlights, but no park/tail or turn/hazard lights.
one of your bulb is blown one bulb will shut the rest off check all your bulbs.
SOURCE: 1998 chevy s10 no headlights or driving lights.
this may sound stupid, but how are the bulbs, also when they are out check for power and ground at the connector. hope this might get ya going. let me know if ya need more info.
Fig. Fig. 15: 1997-00 Pontiac headlights w/DRL chassis schematic
Fig. Fig. 16: 1998-00 Chevrolet headlights w/DRL chassis schematic
Fig. Fig. 17: 1997-00 Turn/Hazard lights chassis schematic
Fig. Fig. 18: 1997-00 Park/Meter lights chassis schematic
