Red & Green lines rolling from the bottom to the top
Hdmi cables with a motorola dvr. been hooked up for 4 days. the screen all of a sudden started rolling red and green lines from the bottom to the top. hd channels faint but still there more noticable on non hd channels. I have checked all cables plugged in tight.
    Problem Solver:
  • 8 Answers
You could have a ground loop problem. To test plug DVR and TV into same outlet.
Posted on Apr 30, 2010
How do i hook up my H.264 4ch DVR to my computer directly my router has upnp enabled
If you want to hook up the PC to play media, I suggest you install software called Plex for free (plex.tv). The Roku has the Plex app so you can play through the Roku or most smart TVs, Amazon Fire, or directly via an HDMI cable from your PC to the TV. It will automatically sort your media once you go through the setup and it is probably the best variant of the KODI/XBMC media systems out there for all platforms.
If you want to record from your DVR to your PC, that gets more complicated. The HDMI cord usually has certain protocols that keep you from recording copyrighted programs DMAC (Digital Media Access Control) so you'll need a video input card that has RCA inputs for red/green/blue or a yellow video input and either a red/white RCA input for sound or an SPDIF Infrared (IR) sound cable and use the software that comes with the tuner card.
Jan 15, 2018 | Swann Communications dvr-9000 DVD Recorder
Hi Have Vizio Flat Screen and a Denon 3803 receiver. The Tv a Vizio 65 Inch flat screen was here. Out of the wall is a power cord and red,blue,green monster cable. Red and Blue is audio and green video I...
Red, Green and Blue cables together typically denotes a component video signal - an Analog, High Definition transportation for video. This cable does not carry audio, you need another cable to hook up audio between the DVR and receiver. You can use either an RCA stereo cable (red and white), optical-audio, HDMI, or a whole plethora of other audio cables. I would recommend optical or HDMI to get the most out of your system.
Jul 16, 2010 | Denon AVR-3803 Receiver
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Sep 10, 2009 | Bose Lifestyle 48 System
Screen flashing ribbons of color over picture
i think its your cable box. check it carefully.
May 25, 2009 | Vizio VA26L 26 in. LCD HDTV
HDMI connection not working
I have a DCT6416 which is essentially the same unit but with a bigger hardrive. I just had the same problem and was able to fix it.
First connect your DVR to your TV with the composite RGB cables and disconnect the HDMI. Then power your unit on. Then power it off (using the power on the DVR not a remote) and immediatly press the menu button on the DVR (not the remote). A white screen with black writing will come up. Using the down arrow buttons on your DVR go to the bottom line where it says "reset factory default" Toggle down to that and then use the right arrow key and your settings will be reset. Then exit out of that by powering off. Now remove your composite cables and replace the HDMI. You should be back up and running.
Feb 06, 2009 | Arris DCT6200 DTV Receiver
Green Line in Philips 42TA648BX/37 42" LCD
Just a guess. Try to get hold of a different cable box & see if you have the same problem. If so, problem is with cable box.
Jan 15, 2009 | Televison & Video
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung LTP326w
After few years of service with different TV providers I have problem with my TV. Last night my Samsung LTP326W just did the same think on HDMI connector and no mater what you do it will not turn HDMI video... it's connected to Verizon/Motorola DVR I called Verizon and they promptly replace DVR and HDMI cable but it didn't help at all, also sometimes when you power on/off I get message: The HD Content Protection of your display has been compromised Please use the YPBPR outputs for your HD connection...
When I switch to component cable it works just fine.
Feb 09, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
PS3 video issues using 1080i
the best cable to use is an hdmi cable, so long as the tv has hdmi sockets. you shouldn't pay more than 20 pound or 40 dollars for a good one. hope this helps
Jan 18, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
325 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
