How can I adjust the time a rheem furnace Classic quiet 80runs?
My heater over runs making the house uncomfortable befor it shut off.
Adjust the heat anticipator setting to match the amp draw on the 24 volt heating circuit
Posted on Apr 15, 2012
  • 334 Answers
Turn the thermostat down. If it's a mercury bulb stat, they are very inacurate and have a wide temp swing.
You could also just replace the thermostat with a good honeywell or white rodgers digital stat and get more accuracy, comfort and efficiency out of your unit.
Posted on Dec 27, 2008
How do i prime the water trap on a rheem classic 90
This trap will fill itself up when the furnace runs for the first time. It does not need to be primed to make it work. If you have the drain end above another p trapped drain.
Oct 28, 2014 | Rheem Classic Series 90%...
RHEEM CLASSIC QUIET 80 HEATER MODEL RGLN-07EAMER AUTO INGITER WORKS BUT BURNER WILL LIGHT AND GO OUT 2 SECONDS AFTER LIGHTING. WHAT SHOULD I TRY?
Hello, check the flame sensor, this is a metal rod on the opposite side of the igniter. Turn off power to the furnace remove flame sensor and clean it up with some steel wool, then reinstall and turn power back on to the furnace.
Mar 24, 2011 | Heating & Cooling
I have a rheem classic series super quiet 80 furnace. when the panel that covers up the control board is removed is there a reset button or sequence that mut be performed so the system will once again run.
no just repalce all the covers and then cycle to power to the unit and it should take off and go...be aware that the t-stat could take five minutes or so to recycle and star the unit also..
heatman101
Aug 11, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
The blower fan comes on several minutes before the
Bad fan switch. It may also be called a fan limit switch. If your furnace is less than 5 years old, the switch is part of the circuit board and you will need to replace the board.
Jan 11, 2010 | Heating & Cooling
I have a Rheem Classic Series Super Quiet 80 gas furnace. My problem is the furnace will turn on burner fires for a couple of seconds then burner turns off and fan blows. This cycle cotinues and eventualy...
Sounds like it could be a dirty or bad flame sensor.
When the burner lights ,there is a flame sensor in the flame and it is suppose to sense the flame and send a signal back to the control board which will keep the gas valve open, if it gets dirty or is bad it doesn't send the signal back to the board and the board will shut the gas valve off and after three tries it will lock out the furnace and you have to reset it to get it to work again.
The flame sensor looks like a wire and it's in the flame usually it will get gas deposits on it, then it won't work.
You can clean this sensor with an extra fine piece of steel wool, but before you attempt to do this DISCONNECT ALL POWER TO THE FURNACE.
Dec 29, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Classic Series Super Quiet 80 gas furnace problem
I have this same POS model. It is not the thermostat. this model is just garbage and cant wait to get something that works right. i have been fighting this thing for 4+ years now.
Dec 25, 2009 | Heating & Cooling
Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
Contact Rheem; the Burner control unit has lost comm with the remote...the part is warranteed for up to five years.
Nov 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
RHEEM HIGH EFFICIENT FURNACE-BACKDRAFT SHUTTING IT DOWN
It's the pressure switch on the unit. Make sure that the pressure switch doesn't have debris in it that keeps it from operating smoothly. Take the tubing off from the inducer side and breath in and blow out lightly while listening for a clicking noise. If that doesn't work then I would recommend replacing it. That should solve the issue.
Feb 20, 2009 | Coleman Propane Forced Air Heater...
Thermostat seems to be working, furnace does not always turn on
Joss sounds like the anticipator setting on thermostat i would replace it with a digital it will be more actturat . The furnace has to go over temp setting to turn off
Jan 15, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
