Question about Epson Stylus C86 InkJet Printer
Epson c62 print head clogged
Put in new color cartridge one nozzle completly blocked, two partially blocked. tried alcohol in the pipes. any other way? can i take nozzles out and clean them?
    Novelist:
  • 140 Answers
The first thing is that you need to get some compressed clean air and blow all that mess up. There is compressed clean air that comes in a can kinda like wd-40 with a small straw. You can buy it at Radio Shack or some electronic supply place. That will do the trick. God Bless.
Posted on Jan 12, 2009
Problem solved.. the compressed air the other reader mentioned works well, but is expensive. buy a can of carplan brake and clutch cleaner. making sure that all power is off to the printer. (( this cleaner is explosive )) and make sure the room is ventilated but it strips all the nozzles of any build up inks etc.. hope it works for you .. it did mine.
Posted on Jan 22, 2009
Replaced both color and black cartridges. Prints only color when I try to print a flyer with both text and picture.
The black print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
Sep 25, 2012 | Epson Stylus CX3200 All-In-One InkJet...
I have been using an epson stylus color 880 for years. One day it would not print. Replaced the cartridges and still will not print. It goes through the printing procedures but nothing shows up on...
The print head nozzles may be clogged. From the Utility section found in the EPSON printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, try replacing the ink cartridge. Any ink cartridge installed into the printer must have a blue label on top of it. If the blue label has been removed from the ink cartridge, do not install the cartridge. Using an ink cartridge, which does not have the blue label on it, may damage the printer. Caution: If you have already installed a cartridge which is missing the blue label, or if a previously installed ink cartridge was missing its blue label at the time it was installed, and now head cleanings do not help the nozzle check pattern to print completely, your printer may require service and you should contact the EPSON Connection for further assistance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 08, 2011 | Epson Stylus 880 InkJet Color Printer
I replaced the color catridges of my Epson C84 with full compatible non Epson brands. The cyan works all right but the yellow and magenta's don't. The nozzle test displays vague black strokes. Could the...
The ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away.
Here's how to clear blocked print heads, given you've run the cleaning of the print heads or nozzles from the printer at least 5 times:
-remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Feb 03, 2011 | Epson Stylus C84 InkJet Printer
New ink no print
Hi Good day!! Try to do a printer maintenance
Cleaning a Clogged Print Head
1. Press the cleaning button located on the front of the printer. Hold it down for 3 seconds to begin the cleaning cycle.
2. Run a cleaning cycle using your Epson printer utilities program. In Windows, go to "Start," "Printers and Faxes," right-click on your printer and choose "Printing Preferences." Select the "Utility" or "Maintenance" tab, depending on your printer model, and click "Head Cleaning." When the head cleaning cycle is complete, run "Nozzle Check." Repeat the head cleaning and nozzle check one to three times.
3. To access the Epson printer utility in OS X, select the Epson Printer Utility icon in the Applications folder in Macintosh HD. If prompted, select your printer from the Printer List, then click "OK."
Clean the print head manually. Remove the ink cartridges from your printer according to the instructions in your owner's manual. Turn off your printer. Dip a cotton swab in isopropyl alcohol, ammonia or hot water and rub the swab against the print head. Let the printer sit overnight.
Remove the print head according to the instructions in your owner's manual. Soak the print head for at least an hour in a small dish of hot water or isopropyl alcohol.
Preventing Clogged Print Heads
1. Use your printer at least once a week. Regular use will keep dried ink from clogging your print heads. If you have a color inkjet printer, print full color pages in addition to black-and-white documents.
2. Turn your printer off when not in use. This will prevent warm ink from bleeding onto the print head. If you have to store your printer, remove the ink cartridges.
3. Use a cleaning kit regularly. A cleaning kit usually includes a tube of ammonia that you spray on the printer head to clean dry ink.
Thank you for using FixYa
Please accept if my solution helps you
Nov 18, 2010 | Epson Stylus C84 InkJet Printer
Full cartridges = empty :S
Solution 1
Once you remove the ink cartridge from the printer, you can make use of the Isopropyl Alcohol, and put at maximum of 10 drops in the ink cartridge. You will find a hole there, in which the ink usually runs from the ink cartridge to the head of the printer. When done, you can put the cartridge back in the printer and run the auto cleaning process from the printer's option in order to clean the blocked holes of the cartridge. I would suggest you to run print tests first and once you are satisfied with the results, you can start using the printer normally.
If you want to go further:
* Remove the tank.
* Connect a hose directly on the inlet ink.
* Locate the sensor of reservoir and press it to make as if a cartridge is available.
* Close the cover of the print head and clean the head by injecting air (under pressure) through the pipe.
* Replace the tank up and do a test print.
* Repeat the procedure several times if the nozzles are clogged.
Solution 2
Using a syringe and some alcohol to unblock the holes can also be very effective.
* Step 1: Remove the cartridge from the computer
* Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
* Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
* Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
* Step 5: Run some test prints before using the printer normally.
Note: I would suggest you to do an automatic head cleaning each time before any printing task. Hence it will reduce the risk of having the print heads blocked by dried ink.
Jan 02, 2010 | Epson Stylus 880 InkJet Color Printer
I bought new cartridges for my Epson Stylus CX4200 All-in-One, but the yellow and Magenta barely print. I have run the head-cleaning program on the computer, the one with the colored lines, and it...
Use "spet" (tube only). Add flexible pipe (cut from oultet pipe of head cleaning mechanic). Connect to nozzle. Fill tube with cleaner. Move head to parking position. Do suction from outlet pipe of head cleaning. It's the safely way to clean print head manually.
Jun 21, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Epsonr220 does not print megenta or light megenta colors
The problem seems to be the printhead nozzels are plugged or burntout. I beleive on the Epson, to remove the printhead for cleaning, you must partially disassemble the printer. If you are not up for this, Quit here. If you game, remove the cartridges and tape over the outlet and air hole of each. I find electrical tape the best. Tape snugly but not too tight and once around the cart. If you have a digital camera or a webcam, take photos along the way to help in re-assembly. Remove the drive belt and disconnect the guide rod the printhead slides on at each end. Try and remove the guide rod and print head as one unit. Use alcohol and/or water to clean the print head nozzels, or completely wash the print head with running water. Blow it off and let dry. Put the guide rod back in the print head and put that assembly back in the printer. Attach the guide rod at each end then put the belt back in place. Put the cartridges back and do a nozzel/print head check. If the printer works completely, then you are set. If the magenta still doesn't work, the nozzels may be burnt out. I don't think you can get Epson Print heads, That means a new printer. Lastly DO THIS AT YOUR OWN RISK. I can't even guarantee my work!
May 28, 2009 | Epson Stylus Photo R220 InkJet Printer
One of the 3 colors will not print
This problem may be due to blocked nozzles, faulty cartridges or a faulty print head or main board. The first thing to do is eliminate the cartridges. Do a proper cartridge change on both printers, but swap the yellow and cyan (blue) cartridges between printers rather than fit new ones. If either (or both) of the missing colours now appear, you know the problem is the cartridges; replace it (or them) with new ones.
For example, take printer A, with yellow missing. Do a cartridge change procedure on printer A, but instead of fitting a new yellow cartridge, put in the yellow cartridge from printer B (since you know this yellow cartridge works). If yellow now prints in printer A, you know the cartridge you took out is faulty - put a new yellow in printer B, and throw away the cartridge you removed from printer A. Repeat this process for printer B with the Cyan cartridge.
For one or both printers where the above does not solve the problem, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head across fully into its parking position on the right, so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean or two. If the missing colours now start to appear, try another clean or two. If still not perfect, leave for 24 hours and try again. If still nothing, report back.
Feb 08, 2009 | Epson Stylus C62 InkJet Printer
Serious Color Printer Issues
This is to do with the way in which the cyan, magenta, yellow and black ink is mixed to produce all the colours e.g. to print "red" requires both magenta and yellow ink. Thus, if the magenta ink is not flowing for some reason, for example, the "red" will print out as yellow. So, make sure all your cartridges and nozzles are working properly.
If you need further help with this, please post a new comment to this effect.
Oct 18, 2008 | Epson Stylus C62 InkJet Printer
C88 only green and yellow
You are out of black and magenta (tricolor cartridge) ink or ink has dried up.
Try touching the nozzle plate (underneath print cartridge) with a water dampened cloth (not alcohol) for cleaning clogged nozzles (do not rub).
Ultimate remedy : put in contact nozzle plate with hot water for about 5 seconds.
If color still missing your printer need new cartridges.
Jan 06, 2008 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C86 InkJet Printer Logo
690 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
