Question about Nextar MA933A MP3 Player
When i plug my mp3 in to the computer ........
It would turn on but when i disconnect it from the computer it goes off and then i press the power button and it would not come on so i would like to no whats wrong with it
  • Anonymous Dec 27, 2008
    my nextar mp3 player will not come on after i would disconnect it from my computer. how do i solve this problem/
Right now im losing my mind as well please let me know if you finde out how to download songs on this mp3 im ready to return it.
Posted on Dec 27, 2008
It will not turn on except for when it's connected to the computer and when I disconnect it the screen automatically goes blank and will not turn on. Please help?
Maybe the internal battery is damaged, that's why when you plug in the computer it goes on because is working with the power of the PC . .. If you have guarantee you may apply. . .
Mar 08, 2011 | SanDisk Sansa m230 MP3 Player
Hip street hs3245 mp3 player wont charge
my problem is my mp3 wont turn on. it turn on just when i plug my hip-streed on my cumputer, but when i disconnect it it wont turn on...
Jan 12, 2011 | Kobian HS-3245 MP3 Player
Need help with set up on SMPK8099. When loading software on my computer from the disk I got a warning that further installation will damage my computer which uses XP. I disconnected the player, ejected...
I got the same thing on my computer when I put the disc in. Really I didnt even need to load it in my computer. I use MP3 rocket pro and load all my songs syncin them with windows media player. I also did not see the battery icon flashing but I left it plugged into the computer and let it charge a while. When you turn the power on ant the top of the mp3 player turn power on and press power button on the keypad on front surface of mp3 player. It is the bottom button at 6 oclock try that and see what happens. Make sure to hold button in for a couple seconds.
Dec 31, 2010 | Sylvania Audio Players & Recorders
Can't make the player turn on. What do I do?
First try and reset the player.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
If that does not work try this,
Remove the battery - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
STEP 1 - Connect the device to the computer
1. Remove the battery from the player's battery compartment.
2. Put the hold/lock switch to lock.
3. Plug in your device to the computer.
STEP 2 - Format the device
1. Double-click My Computer.
2. Right-click on the player, which might show up as a Removable Drive, select Format.
3. Click Start.
4. Click OK when a "Format Complete" dialog appears.
5. Click Close.
Nov 12, 2010 | SanDisk Sansa m240 MP3 Player
When i plug my mp3 into the computer it won't even charge
Re-seat the battery. You can pull the battery and re-seat it in place.
Have you tried all the normal stuff? Hook up the player on the rear of the computer these ports on the rear are more suited for power requirements of charging devices. Next do you have the right USB cable for the player, many may fit but they are not all alike. Have you tried to reseat the battery?
  • Then try all this.
Reset the device.
  • 1. Press and hold the Power/Menu button for approximately 20 seconds.
  • 2. Release the Power/Menu button.
  • 3. Press the Power/Menu button again to turn on the player.
Then you can do what is called a power cycle.
  • Remove the battery.
  • 1. Connect the device to the PC.
  • 2. Leave the device connected for about 2 minutes.
Turn on the device
  • 1. Disconnect the player from the PC. and Quickly
  • 2. Insert a fresh AAA battery into the player.
  • 3. Turn on the player.
Feb 07, 2010 | SanDisk Sansa m240 MP3 Player
Mp3 player froze when plugged into pc. screen is blank but lit. is charged. what do i do?
Make sure the player is fully charged.
  • 1. Connect the player to your computer.
  • 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode,
  • 1. Turn device OFF.
  • 2. Slide the Hold switch down to Lock (orange color showing).
  • 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC.
Next Be sure the battery is charged
  • 1. Leave the player connected for approximately 2 hours to charge.
  • 2. Disconnect the player from the PC.
  • 3. Verify if you can turn on the player.
  • 4. Reset the player if necessary.
To reset the player:
If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery but hooked to your computer.
Feb 02, 2010 | SanDisk Sansa e250 MP3 Player
Mp3 will not work
disconnect the USB cable and let the battery run down when the screen goes blank you can reconnect the USB cable and the device will rechange and you can do you thing
Jan 04, 2009 | SanDisk Sansa Fuze MP3 Player
Creative nomad zen- wont turn. Power light on continuosuly
ash the problem is with vista.find an xp computer and install the newest firmware into your mp3 player.go to creative's website and find the newest firmware
Jan 23, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
My player won't turn on!!!
The m25 will not power on if LOCK/UNLOCK is in the locked position. If you press the POWER button, a padlock will appear on the LCD to remind you that the unit is locked. Confirm that the LOCK/UNLOCK switch is not in the locked position and press POWER to turn it on. If nothing happens after pressing the POWER button, the battery is probably discharged.
Nov 24, 2005 | Motorola Mobility M25 MP3 Player
Nextar MA933A MP3 Player Logo
27 people viewed this question
Top Nextar Audio Players & Recorders Experts
skyocean
Level 1 Expert
Joseph Hoffmann
richie46
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
