Question about Dual XDVD8181 Car Video Player
Fm radio station
How can i set de fm station
  • 8,197 Answers
You hold down the number on the face plat where you want the station set to.
Good Luck Please Rate
Posted on Dec 27, 2008
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
DEH-P7900 BT US model. Isthere any way I could change the tuner frequency to european one. Thanks.
The DEH-P7900BT is almost identical to the DEH-P85BT sold in Europe.
This is a US model and will tune most AM/FM stations in the UK/Europe. The FM broadcast band is 87.8 to 108.0 MHz. so it will not pick up any FM stations outside this range. Also, the tuning is in odd increments (such as 96.1, 96.3, 96.5, etc.) so some stations with even frequencies will be slightly distorted, depending on the power of the signal the station generates.
I found this bit of info for you but ill keep looking and let you know what i find out.
Also have you tried it in europe to see if it does work or not let me know ok
Mar 30, 2008 | Audio Players & Recorders
No Sound
It seems to be that the antenna is at fault. If you can take it apart, you should resolder the antenna.
Nov 10, 2007 | Aiwa CR-LD120 AM/FM Radio
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
My radio only works for a short distance then goes staticky, also can't set the time
the operator guide in the glove box , covers time set.
all radios do that.
and if not normal, the antenna is broken or fell off the rear of radio.
if got static switch to FM ,
many AM stations, broadcase to am and fm same content.
so use FM. its static free. (by design) but does fade sooner.
you can in fact hear AM station 12,000 miles away it night
called super stations, 50,000 watt stations. ive done this many time.
did you try another car, in same spot , and same station?
are you in under ground parking?
Aug 13, 2013 | Jeep Liberty Cars & Trucks
In my settings there is no fm transmitter selection available
As far as I know, there is no transmitter in a Sirius Radio. I had an XM, and there was no selection for fm stations. They just figure you can tune the car radio to any fm station, in case you want to listen to fm. Hope this helps, but refer to your manual for details about what the unit can do.
Jun 12, 2010 | Sirius Sportster 5 Satellite Radio...
What fm station do I set my radio on?
i have a ford explorer, 1995 it came with a 10disc cd changer only trouble is we dont know what radion station we need to use for it can you help?
Apr 15, 2010 | Xtreme Sound WMS6100RW 10-Disc CD Changer
It will scan but not hold a station
Hi
i think the fm settings is not lock in to fm scanner! or program the fm station then lock it in ti memory
Thanks!
Jun 05, 2009 | Coby CX-61 FM Radio
Wireless FM modulator
first you have to set a channel in your sat radio then tune your car radio to that channel go to menu and then to set fm frequency in your sat radio and choose one try to get one that does not have a station on it whatever you set it at just tune your car radio to that frequency and it will work
Dec 05, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Feb 20, 2008 | SanDisk Sansa Clip MP3 Player
Dual XDVD8181 Car Video Player Logo
75 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
