Question about Garmin Nuvi 350 Car GPS Receiver
Garmin gps won't charge while driving
Nuvi 350 battery won't charge with the charging port only with the usb port and then you can't drive and have it plugged in to be charging.
  • 2 more comments
  • almaadamson Dec 29, 2008
    My GPS won't charge in the car either. I bought a new cable for the car but it's not working either. I know it's not a problem with the cable nor my car. The only way to charge it is on the computer via USB, which doesn't last for too long.
  • susie j Jan 04, 2009
    I have the same problem - nuvi won't charge in car; only with USB and charge doesn't last.
  • kwarren1970 Apr 10, 2009
    My Garmin Nuvi does hold a charge and works fine when it is charged. I can only charge it via its USB port. My nuvi doesn't seem to receive a charge when I have it plugged into the car. Nothing is wrong with the car as other things charge just fine and I've used it on other cars.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Sounds like you might need a new battery. Please see this link for more info. Too much to copy and paste here.
    http://www.sharc.net/nuvi_battery_repair...
  • 19,396 Answers
If the Nuvi won't charge when connected to charge but charges on USB, then the charger port is faulty.
If the Nuvin does not charge at all , then the battery must be replaced.
Posted on Apr 13, 2009
My gps shows a picture of a pc when i plug it in . it never used to do that :(,i cant drive n use the gps while its charging,
Posted on Aug 16, 2012
Garmin nuvi takes days to charge on house current, will not charge in car... new battery, new cables, no help.
Have you inspected the USB port? Common failure on these units are loose/broken USB ports. A broken port will prevent the battery from charging.
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Sep 29, 2014 | Garmin nuvi GPS
Shut off
You should only see the computer icon when plugging the 350 into a USB port on the PC. If you see it when plugging in a car charger/adapter, then there may be a problem with the mini-USB port on the 350 or the charger is an after-market charger that is not electrically compatible with a Garmin charger. Please see this link for more info:
http://www.sharc.net/gps_charger_repair.htm
May 29, 2013 | Garmin Nuvi 350 Car GPS Receiver
HOW DO I CHARGE MY NUVI 1450 ?
use small size USB cable, connect with PC
Mar 28, 2011 | Garmin GPS
Garmin nuvi 255 can310 ser #1BV565833 HOW TO RECHARGE THE BATTERY ? I HAVE USB CABLE. CAN I CONNECT TO MY COMPUTOR TO RECHARDE?
If you have a USB port with a high enough power input then you can charge the unit off a USB, but not all USB ports will have enough power to charge your unit.
Hope this helps!
Feb 23, 2011 | Garmin nuvi 255W GPS Receiver
I cannot use the GPS unit while in charge mode(NUVI 350)
Are you using a USB cable & charger to operate the GPS?
If so, you should stop and use the supplied cradle / power cord to power the GPS instead. The USB cable is used to transfer data to and from the GPS and on other models (maybe your 350, too) to slow charge the GPS battery when completely discharged. Powering with the USB cable will power up the GPS, but does not allow navigation, mapping, etc.
Oct 12, 2009 | Garmin Nuvi 350 Car GPS Receiver
My Garmin Nuvi 300/350(2 years old) comes on and
I solved the problem by charging internal battery using the 120V. charger that came with the unit. I was not aware, that the cord in car was not charging my Nuvi and that it was running OK. until the battery was low and quit. I have to check this cord. Peter W.
Oct 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin nivi 200 won,t turn on
The mini-USB jack needs to be either resoldered or replaced. When the jack is loose, you will not be able to charge the internal battery. The jack becomes loose from overuse. The jack needs more mechanical support to the pronted circuit board. I have fixed this problem many times.
- Jim
Aug 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 255W
No, it may take a little longer if you are charging through the USB port. I normally have mine plugged in while driving, it charges and is in use too. To use GPS with USB. First turn the GPS on (without USB plugged in). Press Battery symbol on screen for about 10 seconds, a test screen will come on. Plug in the USB (bottom of screen shows USB connected). Tap EXIT to return to maps. You can now use it while USB is charging Make sure you turn GPS off before removing the USB cable
Apr 08, 2009 | Garmin nuvi 255W GPS Receiver
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
3,206 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
