Question about NEC MT850, MT1050, MT1055, MT1056 Replacement Projector Lamp - MT50LP Projector Lamp
My nec Mt850 has double image shadow letters blue and purple
Both projectors bought at the same time and have the same problem blurry sand shadow image
  • randydowning Dec 31, 2008
    what is a backlight?
    Genius:
  • 1,550 Answers
Try hard reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
Also check for any blown fuse or check whether backlight is damaged .
Posted on Dec 27, 2008
The status light is on our NEC MT850 and the bulb looks fine. What other problems could it be?
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
turn on the projector ,at the same time ,if you can hear a continuous beep beep sound (the ballast igniting the lamp)
means the lamp may be fault,and other parts is working well
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 19, 2012 | NEC MT850, MT1050, MT1055, MT1056...
I have an nec mt850, my picture is upside down...how do i fix that?
Unit is probably set for ceiling mount or reverse screen projection. In the options menu there will be settings to alter it back to normal aspect.
Apr 28, 2012 | NEC MT850, MT1050, MT1055, MT1056...
Hi there! i have this nec mt1030g+ projector and its video hv sumthing like a copy of image with is like shadow of the real image in blue colour! i wanna know if its lamp fault or sumthng elsa! thanks
It sounds like a polarising lens has failed, if so it will probably be cheaper to buy a new NEC NP115 which has probably got the same if not better specification.
Hopefully I was of help to you
Feb 04, 2011 | NEC MT1030G Replacement Projector Lamp...
MT850 has double image or ghost image, how do you fix that?
one of the lcd panels or more then just one r bad.
cost of thuse lcd panels r more then what this old projector worth
Jan 20, 2010 | NEC MT850, MT1050, MT1055, MT1056...
Red coured picture Nec MT850
I don't think it's globe related, I'd be getting a quote on the electronics.
Mar 23, 2009 | NEC MT850, MT1050, MT1055, MT1056...
I turn my mt850 on & the picture is blue
You most likely have a defective blue LCD panel which is a common problem for a projectors this old.
This is an exspensive repair if parts are still available, probably not worth fixin.
Mar 17, 2009 | NEC MT850, MT1050, MT1055, MT1056...
My NEC MT850 projects with a pink picture you can still see image but it is a very bright pink.
A pink image normally means a loss of green signal.If you are using Computer input you should try replacing your input cable to see if this is the problem. If it is pink with video also then the projector most likley has a internal problem.
Mar 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
NEC MT850
As there were no indicator lights lit I focused on the AC. The projectors work as they should in another location and as such I am fairly certain the problem is associated with the AC power in the particular room. I haven't isolated the exact condition as yet.
Thanks
May 20, 2008 | NEC MT850, MT1050, MT1055, MT1056...
How do I align the color on an MT850
Hi
pls check the board before the color wheel, as it is noticed that this problem comes with the main PCB Board.
Viren
Nov 19, 2007 | NEC MultiSync MT850 Multimedia Projector
478 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
