Question about HP (158800-001) for Compaq Presario 1246, 1247, 1277, 1279 Cooling Fan
Emachines T2958 overheating and shutting down
I get this message and an alarm goes off when i turn on my pc ... also it shuts down after a short time ... can you help?
  • Anonymous May 01, 2009
    gateway mx6440 same error, overheats n comp shuts down to prevent overheating, although it is very hot im thinking it may be a heat sink that the fan attaches to.
    best of luck, if this continues happening i think its about 45 bucks for a new heat sink with fan
    President:
  • HP Master
  • 1,314 Answers
Your computer is automatically shutting down to prevent damage to the CPU because it is getting too hot. This can be caused due to a malfunction fan, heatsink, or dirt inside the CPU.
Remove the side cover of the CPU. Using a can of air (which can be purchased at most electronics departments), blow out any dust inside the case, paying specific attention to the fan and the heatsink mounting the CPU. Also blow out all vents and anywhere else you see dust. Do not shake the can of air and keep it as level as possible. If you do not have a can of air available, an air compressor will work. Alternatively, you may vacuum the dust up with the hose of a vacuum cleaner but do not use any attachment with brushes on it.
If the inside is relatively dust free, check to make sure all the fans are functioning properly. If the one on the CPU is not, then that fan will have to be replaced.
And one more thing, please give this solution a fixya rating. Thanks! :c)
Posted on Dec 27, 2008
Evinrude 40hp outboard
First, the over heating alarm is for YOU to shut the motor down...
Replace the water pump assembly..(have a different mechanic do it!!!!!!!!!!!!!!)... they are NOT all created equal!!
May 17, 2017 | Boating
Computer shuts down by itself
open your computer case and check the microprocessor fan, it should be either dead or if filled with dust, clean it, it should fix the issue.
Please rate
Jul 25, 2013 | E-Machines eMachines Desktop PC
Emachine will not shut down
Back up and reinstall the operating system,can't help without knowing what is the actual problem...
Mar 28, 2012 | E-Machines eMachines Desktop PC
Emachines ET1810 desktop computer randomly powers down for seemingly no reason. Doesn't crash or freeze, just turns off, as if the plug was pulled. Started about 5-6 months after buying.
It could be overheating, and automatically shutting itself down, to avoid any damage.
Did you get the standard 12 month warranty when you purchased the computer? Did you purchase "extended" warranty? If so, contact Emachines, and get them to trouble-shoot and fix it.
Jun 11, 2010 | eMachines ET1810-01 PC Desktop
PC shuts down. When you turn on the pc it shuts
try to change the source, that should solve the problem. But before try reset CMOS. (if you don`t know how to do it by jumper simple remove the battery from the mainboard for 5 minutes and then plug it back on..and after that turn on your computer and press F1 for default settings)
Oct 27, 2009 | E-Machines eMachines Desktop PC
Emachines w2828 keeps shutting down reboot/Screen Freeze
I dont thing this is a virus problem but a heat problem. if you dont mind getting inside the box see how clean it is and put your hand on the power box case .. then unplug all the hardware except the mother board then turn the unit on, if it goes on then plug 1 hardware at a time.
Sep 04, 2009 | E-Machines eMachines Desktop PC
Emachine not turning off.
you can checkit by unhooking it on the inside from the mobo panal just remember where it ogoes back take a small flat head and cross the two prongs it comes of off then shut it down if it works look on ebay for a complete front panel with switch or order from emachines.
Oct 29, 2008 | E-Machines eMachines Desktop PC
Go to emachines.com and see if there is a firmware update for your computer BIOS. Some thermostat errors are cause by a BIOS fault that can be corrected with a firmware upgrade.
Aug 18, 2008 | Computers & Internet
Emachine shut down
No, it's just the USB ports that are still being powered.
Totally normal in most new computers. Same thing with the PS2 ports.
There are jumpers on the motherboard that can change this if you really want. It's designed like that to keep things like you have powered for when you do turn it on and need them.
Apr 16, 2008 | E-Machines eMachines Desktop PC
HP (158800-001) for Compaq Presario 1246, 1247, 1277, 1279 Cooling Fan Logo
274 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
