Question about Compaq Presario Notebook
Graphics drives if we install graphics drives , there is some dotted black grains in the screen. how it overcome
  • Jesse Lohse
    Jesse Lohse May 11, 2010
    Sounds like it might be dead pixels in the have to get the monitor replaced if so.
  • moloch30 May 11, 2010
    Which pc - specs? Which graphic card are you installing, which version of drivers?
  • 520 Answers
Check youve installed correct drivers
check settings (click right mouse select properties
select settings.
check screen res and colour settings
Posted on Jan 05, 2009
I have (suddenly) a single dotted black line about a quarter wasy down my screen on laptop. Can I get rid of it?
First, you need to verify if the dot is cause by faulty graphics chip/card or LCD/LED. To do this use external monitor, if you cant see dot on your external monitor then you have faulty LCD/LED if you see dot like in your laptop the you have graphics chip/card problem.
Oct 09, 2014 | Acer Computers & Internet
Monitor is Black, Computer won't boot, computer screen is black.
If you have power and you hear your computer running but screen is black, your cables are connected and screen power button is on, No dots, dashes, words at all, usually that indicates the graphics card or ram is blown. Much more rarely a bad CD/DVD drive defect can block motherboard monitor drive.<br />Usually there is a used computer parts dealer in major cities and fault confirmation can cost under $10.00 if you can switch graphics cards yourself. Take your card in with you for slot style matchup. Nearly all computers can handle a card switch without data loss. Labor and time saving to try a card with Windows drivers resident, buy a universal or common brand.
on May 24, 2011 | Computers & Internet
Black screen card
Make sure that you have the latest display (Graphic) driver installed on the comuter. If you are still facing this problem then it might be that your computer graphic card is old and does not support the required graphic resolution which is required to play this game.
You can try--
Most of the time DPI (Dot per inch) setting also fix this type of issue.
You can change the DPI settings in windows Xp by following these steps:
1. Click on Start then Control Panel.
2. If control panel is set at Classic View, then double-click on the Display icon
3. A box will pop up. Click on the Settings tab.
4. Click on Advanced.
Change the DPI setting to Normal size (96 DPI). You can also change the DPI size to any other value. Click OK and your computer will ask you to reboot your computer. Click Yes
Nov 16, 2013 | NovaLogic Delta Force 2
Dell Desktop monitor has flashing dots, black and white, all over the screen.
Check have you installed graphics driver properly in order to as per your monitor and as per your system or not.
Jun 20, 2012 | Dell U2410 24 inch Monitor
Wont Display Anything , Black Screen !
The screens brightness might be set to the lowest number as a joke. Try to change that.
Dec 09, 2011 | Texas Instruments TI-84 Plus Silver...
Yesterdy i was working on an optical drive issue with a comp, got it done by removing an extra drive from this computer...but...the video on this computr is not wrkong now...what issue? what is the...
What is the Resolution
Refers to the sharpness and clarity of an image. The term is most often used to describe monitors, printers, and bit-mapped graphic images. In the case of dot-matrix and laser printers, the resolution indicates the number of dots per inch. For example, a 300-dpi (dots per inch) printer is one that is capable of printing 300 distinct dots in a line 1 inch long. This means it can print 90,000 dots per square inch.
For graphics monitors, the screen resolution signifies the number of dots (pixels) on the entire screen. For example, a 640-by-480 pixel screen is capable of displaying 640 distinct dots on each of 480 lines, or about 300,000 pixels. This translates into different dpi measurements depending on the size of the screen. For example, a 15-inch VGA monitor (640x480) displays about 50 dots per inch.
Printers, monitors, scanners, and other I/O devices are often classified as high resolution, medium resolution, or low resolution. The actual resolution ranges for each of these grades is constantly shifting as the technology improves.
Solution :
If you not get the proper video image in your screen that mean you have remove the driver of video, for installation the driver, put the Driver -CD in rom, and start the setup is simple set you get the driver.after installing the driver restart your PC
If you change any display setting then also you get the occur.for set the resolution go to the control panel and select the Display and go to setting tab set the ' Screen resolution" as before.
If you still not get the display then open you PC and remove the RAM and put again,and try again.
God Luck
Sep 15, 2011 | Asrock P4I45GV R5 Motherboard
Black screen white dots
This is likely due to Hardware Failure. Your GPU (Graphics Processing Unit) has likely overheated to the extent of artifacting which is when the device begins to have trouble rendering objects and images and crashes constantly. The only viable solution is to send it in if you still have warranty, Otherwise, you'll have to either buy a new Xbox 360 or send it in for repairs from microsoft.
Hope this helps.
Jul 13, 2009 | Microsoft Xbox 360 Console
Black dots during gameplay only on 360
I had this problem with my very first Xbox 360. It started showing little white dots instead of black though. I just dealt with it for a while, and it finally got to the point where it would fill up the screen fully, to where I could only see my gun in Halo 3 and that was about it. I was forced to call Microsoft and have them fix it.
Mar 10, 2008 | Microsoft Xbox 360 Console
Coloured And Dotted Lines Across My Screen
Firstly, start your pc in safe mode (f8) on boot up. This will start your pc in vga mode, and hopefully the lines are still there, which will indicate a faulty graphics card, if they aren't it may be a problem driver. If no lines, go to Add/remove programmes and uninstal your graphics driver. Re boot pc then when it finds your card make sure you point Windows to the folder in which you have saved the driver files. The driver should then install, see if any change. You may have to try some older drivers, as Nvidia can be awkward at times. I have had varying problems with Nvidia and replaced with ATI cards with no problems.
Dec 01, 2006 | XFX GeForce 6200 Graphic Card
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
