Question about Epson Stylus C84 InkJet Printer
Both red lights come
The printer when turned on the two red lights come and the paper will not feed into the printer. And when the one red light button is press to center the ink cartigaes it will do nothing. The two red lights will go out they come on and stay on.. The paper will not feed and the light will not go out. Can you tell me what the cause of the problem is the reason is that the printer is not working.
  • Epson Master
  • 541 Answers
This may mean the waste pads are full and needs to be rese with software has i cant give you my email to give you the software messge me on here and i will try and help you
Posted on Feb 27, 2013
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
Printer shows a red light for paper. It will not
Remove the paper tray and clean the feed roller with alcohol or water.
Oct 04, 2009 | Brother HL-2040 Laser Printer
Printer stopped working Epson C86 and red middle light button on
The red middle light is the paper feed indicator. If it is on, it means the paper feed is (or the computer thinks it is) jammed. Remove all paper from the hopper and make sure all bits of paper are removed from the feed mechanism. Press the paper feed button (the middle one) a few times during this process to try to feed through any jammed pieces. If this doesn't work, you have an internal jam or broken feed system, or your main board has gone haywire.
Any further investigation requires you to remove the printer top cover, which you may or may not feel like tackling. If you don't, take your printer to a technician, or sell it on E-Bay for what you can get. If you do, post a new comment to this effect and I will provide a tutorial on removing the top cover. It's not difficult if you know how.
Apr 10, 2009 | Epson Stylus C86 InkJet Printer
Paper Jam
from fixya knowledge base I found this solution
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Let know if working and don't forget to rate solution
Jan 11, 2009 | Brother HL-2040 Laser Printer
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
PRINTER PROBLEMS
NECESITO LOS DRIVERS DE ESTA IMPRESORA. FAVOR ENVIARMELOS A DLFNA207@GMAIL.COM
Jul 16, 2008 | Epson LX-300 Matrix Printer
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
Epson Stylus C84 InkJet Printer Logo
222 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
