Question about Metra Amplifier Installation Kits Pkbl1
Mounting bracket for mounting aftermarket in 99 grand prix
After following instructions I tried to slide my kenwood stereo into the dash slot in my 99 grand prix . the mounting screws that were supplied did not allow enough room to slide into the mounting slot...any suggestions
How do you take of the dash paneling to install a new aftermarket cd player?
  • Disconnect the negative battery cable from the Jeep Cherokee battery with the 10 mm wrench.
  • 2 Remove the five screws on the top edge of the dash panel with a Phillips-head screwdriver.
  • 3 Pry the trim panels surrounding the climate control knobs away from the dashboard with the trim panel removal tool.
  • 4 Remove the trim panel that surrounds the headlamp switches (located to the left of the steering column) with a trim panel removal tool.
  • 5 Remove the two screws behind the trim panel that surrounds the headlamp controls with a Phillips-head screwdriver.
  • 6 Pull the dash panel that surrounds the stereo and covers the instrument panel of the Cherokee, away from the dashboard by hand.
  • 7 Remove the two screws from the stereo mounting bracket. One screw is on the bottom left corner, the other screw is on the top right corner. Each screw can be removed with the 10 mm socket and drive.
  • 8 Pull the factory stereo from the stereo mounting dock.
  • 9 Disconnect the stereo wiring from the back of the factory unit.
  • 10 Connect the Jeep Cherokee factory stereo wiring to a wiring harness adapter. Connect the wiring harness adapter leads to an aftermarket stereo. Slide the aftermarket stereo into the stereo mounting bracket and replaced two screws at the opposite corners with the 10 mm socket and drive.
  • 11 Replace dash panel that stretches across the top of the steering column.
  • 12 Replace the two screws at the top of the headlamp control switch. Replace the trim panel around the headlamp switch.
  • 13 Replace the trim panel that surrounds the climate control knobs.
  • 14 Replace the five screws on the top edge of the dashboard with a Phillips-head screwdriver.
  • 15 Replace the negative battery cable over the negative battery terminal and tighten the cable to the negative lead post with the 10 mm wrench
  • Dec 24, 2010 | 2006 Jeep Grand Cherokee
    I disconnected my car battery now my sevilla 168 will not turn on please help
    GPS systems are standard features in many new vehicle . A GPS system communicates with satellites to provide directions through unfamiliar locations. However, older vehicles don't come with GPS, and many drivers purchase aftermarket systems for their vehicles. Installing a GPS system in your vehicle can increase its value and help make traveling a much more enjoyable experience.
    Instructions And Materials Needed Below.
    • Plastic putty knife,Flat and Phillips screwdriver set,Wrench set,GPS system
    1. Slip the edge of a plastic putty knife under the edge of the radio face and lift the plastic housing off. Most aftermarket GPS systems incorporate a radio or CD player to replace the old stereo.
    2. Loosen the bolts on the left and right side of the stereo and pull it gently out of the dashboard. Unplug the connections at the back of the stereo and unscrew the mounting bracket on each side.
    3. Connect the mounting bracket from the stereo to the sides of the GPS system. If you've purchased the correct GPS unit for the make and model of your vehicle, the bracket will attach with just a screwdriver.
    4. Plug the wires into the back of the GPS system and slide the unit back into the dashboard. The ports on the back of the unit will be color-coded to correspond with the proper wire plugs, so there is no confusion when connecting the unit.
    5. Secure the GPS unit by inserting the bolts back into the bracket and tightening them with the wrench. Replace the plastic cover over the face of the unit and press it down until the plastic holders click into place. Turn the vehicle on and follow the instructions on the screen to program your new GPS system.
    Good Luck.
    Dec 07, 2010 | Blaupunkt GPS
    My gps doesnt turn on even conected to the car,
    Good Luck.
    Dec 07, 2010 | Magellan Maestro 3225 Car GPS Receiver
    How do i change the brake pads on a 2005 grand prix pontiac
    remove the caliper, by removing the two holding bolts, then use a old brake pad against the pistons and a c clamp and push piston all the way in, next is to clean and lube pad mounting surface and the caliper slide pin, then install new pads on bracket then caliper and tighten caliper bolts, heres a diagram to help you,98c6b31.jpg150490f.jpg
    Apr 16, 2010 | 2005 Pontiac Grand Prix
    99 grand prix, Ac problems, problem with digital thermometer
    JUST A BIT OF INFO WHEN YOU CALL THE PARTS STORE, THE PART YOU WILL ASK FOR IS CALLED THE AMBIENT CLIMATE CONTROL SENSOR. THEY WILL NEED TO KNOW THAT OR THEY WILL TRY AND SELL YOU A BUNCH OF PARTS YOU DONT NEED.
    Jun 19, 2009 | 1999 Pontiac Grand Prix
    Im trying to find where i can gt a complete guide on how to install a car stereo from color coding the wires to installing a dash kit
    1. DISCONNECT THE NEGATIVE TERMINAL ON YOUR BATTERY!
    2. For an old stock stereo, you may have to remove the dash or certain parts of it to access the stereo. Do that by locating screws and bolts and taking them off. Make sure to keep them in a safe place.
    3. For an aftermarket stereo, insert DIN tools into each slot on the stereo behind the faceplate. Slide the whole stereo out.
    4. Disconnect the antenna wiring (The wire with the big metal tip)and the stereo head unit wiring (wire harness).
    5. Reconnect the antenna into your new stereo.
    6. Use **** connectors and wire crimps to connect the stock wire harness with a car specific one that is sold seperately. The color of the wires on each harnass should match up.
    7. Reconnect the negative terminal on your battery and see if it works.
    8. Slide the stereo back into the dash and remount the dash that you removed, including screws and bolts.
    hope this will help you
    Jun 05, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
    2008 Pontiac Grand Prix Factory stereo color codes
    attach both power and illumination wires to constant on car wires.... only way to have switched power is connecting the switched/ignition wire to a fuse
    Feb 02, 2009 | 2008 Pontiac Grand Prix
    I want to remove the stock stereo
    Remove the ash tray, if I remember correctly there are three or four screws that mount the ash tray bracket (two are vertical and require a very short screwdriver). WIth this bracket removed, it exposes the bracket that mounts the radio, two or three screws there as well, then the radio just slides out of the dash. The radio will pull out far enough to be able to disconnect the wiring and antenna cable.
    Jul 22, 2008 | 1990 Honda Accord
    Pioneer Super Tuner 3 Removal
    If it's been installed with the original DIN mount, there are 2 small flat clips that slide in a small slot on each side of the radio. The 2 pieces of metal are pushed in to release the clips holding the radio in the bracket. Then the radio pulls out
    Those clips come with the Pioneer stereo but should be available from a place that sells/installs car audio
    Oct 16, 2007 | Pioneer DEH-P690UB CD Player
    Metra Amplifier Installation Kits Pkbl1 Logo
    26 people viewed this question
    Top Metra Car Audio & Video Experts
    xxxxxx xxx
    Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
