Question about Sony DXC-190 Camcorder
USB Driver cannot be installed in Windows Vista
Pixela USB Driver of Sony Handycam DCR TRV-19 cannot be installed in Windows Vista
5 Suggested Answers
SOURCE: Driver software of Sony Handycam DCR HC30E for windows vista
i hav lost the cd for driver installation..i need the software win XP..plz help me with the software online..wer can i get it??
Posted on Jan 06, 2009
  • 489 Answers
you only need to find which one is your model.
hope it works
pls rate this.
Posted on May 29, 2009
  • 32 Answers
SOURCE: usb driver for vista
Posted on Jun 08, 2009
  • 497 Answers
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!!!!!!!!
Posted on Sep 12, 2009
SOURCE: where can i get free usb driver for windows 7
Posted on May 28, 2010
0 characters
1 Points
Where can i get free usb driver for windows 7
May 28, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
I have windows vista and i cant install the usb driver and pixela programs for this handycam please help me.
the usb driver and pixela application is not compatible with windows vista. usb streaming is not supported by windows vista and 7 OS. however it would still be possible to transfer videos from your dv camcorder using the dv interface (ieee1394 or ilink) connection. you would need to have an ilink (ieee1394) card installed in your computer. you can check by going to device manager window. if you don't, try checking with your PC manufacturer recommendations for an ieee1394 chipset or card.if you do, all you need is an ilink cable (btw, the cam uses 4pin jack).get the correct cable for use with the PC and camcorder, and use windows moviemaker for your video capturing software.hope this helps.thanks :)
also, here's the support site for your unit:
Mar 31, 2010 | Sony Handycam DCR-PC101E Mini DV Digital...
I want to download from sony handcam dcr-140
I have same camera and computer. I use IEEE1394 FireWire(CardBus PCcard). It works for Ulead DVD MovieWriter which is in my Vista.
Oct 25, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
Vista Driver for Sony TRV330
No driver required. Plug the supplied cable into the computer firewire port and the Sony "i-Link" port on the TRV-330 and turn on the TRV-330 in VCR mode. Works in XP and Vista out of the box.
Apr 12, 2009 | Sony Handycam DCR-TRV330 Digital Camcorder
DCR DVD 201E Handycam and Windows Vista
I have the same problem; however there is a workaraound. If you plug your camcorder in to your usb drive and power on so that the Vista Plug 'n' Play can automatically install a driver for using as an external drive (bit like a usb stick)
When you go to my computer you will see an extra drive explore and see no files!
Well in the camcorder itself, there is a function to finalise the disc, perform this action and you should be able to see the files including the dvd menu files on the disc in my computer.
Drag and Drop to your computer. And use with what ever Software you want to.
This could also depend on the recording format you have set in the camcorder.
Hope this works for all.
Apr 05, 2008 | Video Cameras
Sony DCR-TRV 140E
Yes got to sony
pick your camera at the bottom, get the USB drivers and that should do. Programs it will work with include Pinnacle Studio etc
Jan 23, 2008 | Sony Handycam DCR-TRV140E Digital...
Sony DXC-190 Camcorder Logo
590 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
