Question about HP PSC 1315 All-In-One InkJet Printer
Paper thickness allowed
Could youlet us know the paper thickness (gage) allowed?
Is 180gsm acceptable?
  • 57 Answers
Type Paper weight Input tray capacity Plain paper 70 to 90 gsm (20 to 24 lb) 100 Cards 200 gsm (110 lb) 20 Envelopes 75 to 90 gsm (20 to 24 lb) 10 Transparency film N/A 20 Labels N/A 20 10 x 15 cm (4 x 6 inches) Photo 236 gsm (145 lb) 20
Posted on Dec 27, 2008
R320 printer won't print on thick photo paper anymore. Regular copy paper works fine. Are there rollers or sensors that I can get to so I can clean and check? Is there a fix for this problem?
  • Make sure that the paper meets paper specifications of the product.
  • Spray compressed in air.
  • If it is a non-Epson brand paper, try Epson paper
  • Make sure that settings are setup properly, Some Epson products have a Thick paper and envelopes or Thick paper to allow it accommodate thick media
Feb 14, 2013 | Epson STYLUS R230 InkJet Photo Printer
My Konica-Minolta-Bizhub-C350-Color-Copier-Printer paper keeps jamming, why?
well could be several reason incorrect paper size incorrect paper weight are you running Thick 1 or Thick 2 to paper. Do you know how to read paper weight? on out side of the paper package is words 20lb or 36lb mite also see the something like 75 g/m2 that is the weight of paper in the metric world (Every one else except the GOOD OLD USA.:):):) we use the lb. system . select paper on the control panel and make sure the paper weight matches most paper copy are putting both lb. and metric but if it is only metric then use the control panel to figure it as you select the thick 1 or 2 you will see the g/m2 on the control panel, if you using paper off the shelve and don't know then call the company where you get the paper from and ask them. Are using the bypass tray make sure that you follow the icon on the screen when it says load paper in the by pass tray does the little icon show portrait or landscape. if you using legal size paper did you pull out the extention tray to allow additional sensor to come into play for the longer paper. Does you print properties on the computer screen match what is in the draws? IF the paper come wrapped an only has lb. # then you will not find it on the control panel you need to get your operation manual out in that manual will be a chart that show what lb. # equals what thick 1 or thick 2.
Jan 05, 2012 | Minolta C350 Printer
What is the maximum paper weight I can use on a Canon iR2200-3300 PCL6 printer
hello. 180gsm is a comfortable thickness for it. anything higher seems to "stagger" a bit as it is being pulled through.
Regards GM
Aug 01, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Epson Stylus R1800 refuses to accept art paper through the single sheet feeder at the rear When loading the paper the unit will pull it into the correct location and then on print command it backs the...
First check to see if there any any bits of paper stuck by checking the front and the rear feeder.
Also consult your manual to see if it accepts that thickness of paper.
It can be found here:
The steps in the manual to clear a jam are on page 89 and types of accepted paper are on page 11.
Hope this helps.
Mar 20, 2011 | Epson Stylus Photo R1800 InkJet Printer
When i use card stock it acts like a paper jam,with a little help it prints fine
Make sure that you are setting the proper paper type before printing any paper other than "plain" by going into the printer's "properties/preferences". If it's thick paper, choose "thick" or "heavy" or "cardstock" in the drop-down arrow.
Unless, of course, your printer doesn't accept cardstock at all, then you're out of luck.
Hope this helps. :)
Sep 29, 2010 | Dell Office Equipment & Supplies
The MX700 will no longer feed from the bottom. It does want to grab the paper but only gets anout 1/8 in and makes a weird noise when trying to continue. Feed from the back is fine. This seems to have...
Ok dont exced the normal paper typeing Like thickness( you need to read your brochure
and check for acceptable thickness and paper class
The bottom is normally a reserve tray for paper
Oct 19, 2009 | Canon MX700 Office All-In-One InkJet...
Problem to feed photo paper
pls... change the a3 photo paper to 230 gsm because the sensor can not load because of the thickness of your photo paper. change it to small gsm.
Sep 29, 2009 | Office Equipment & Supplies
Dx8400 will not take 260gsm photo paper
Maximum thickness allowed in this printer is 250gsm for Premium Glossy, therefor the paper appears to outside the specification of the machine. Only answer is use slightly lighter paper.
Nov 18, 2008 | Epson Stylus Photo R300 InkJet Printer
Insert sim card message
i got problem with my phone n-gage,after i turned my n-gage on..itssays "insert sim car"..i already put my sim card inside of it
Mar 01, 2007 | Nokia N-Gage QD Console
HP PSC 1315 All-In-One InkJet Printer Logo
227 people viewed this question
Ben Johnson
