C language is not running in full screen mode
Windows Vista takes away a lot of support and convenience for the sheer attractive of flashy user interface. One major feature is the ability of open full screen window for command prompt shell in Windows Vista. When you attempt open or run DOS .com applications, .bat batch scripts or games that relies on command prompt, and including cmd.exe itself, you will encounter the following error message:
This system does not support fullscreen mode. Choose “Close” to terminate the application.
The lack of support for full screen DOS command prompt in Windows Vista is a big annoyance especially for those who still playing games for DOS and Windows 3.1/9x era, use legacy software such as WPDOS or programmers who frequently switch to command prompt to use DOS based programming language such as PASCAL.
There is no simple solution to this no support for full screen window in Windows Vista. In almost all possible workarounds, you are almost guaranteed that your Vista will be broken in some way, at least on the part on Windows Aero. You will lose the nice Aero Glass interface if you attempt any of these trick, plus other unknown side effects.
Workaround to Run or Open Full Screen Window Mode
Workaround 1: Use XDDM driver instead of WDDM driver for video graphics adapter
In another word, install the Windows XP video card driver for use in Vista. If the video graphics card hardware supports Windows XP driver, you can download the Windows XP driver for your video hardware and install it under Vista. However, be warned that using XP driver on display adapter may crash your Vista system randomly, so save your works before proceeding and use with care.
Note: This solution has been recommended by Microsoft in KB926657.
To install a Windows XP video driver under Vista, just follow the procedure listed in the guide below. The steps should work for both NVIDIA and ATI video graphics accelerator card.
Download the Windows XP driver installer for your graphics card from NVIDIA or ATI.
Run the installation setup program just downloaded. Confirm any User Account Control permission warning when prompted.
The installer will first extract and unpack the files required by installation to proceed to a folder/directory. Note down the path to the folder. For ATI, the folder for these installation files usually located in a directory with a name that resembles C:\ATI\SUPPORT\7-5_xp_dd_46743\Driver or C:\ATI\SUPPORT\7-5_xp_dd_ccc_wdm_46743\Driver, with the only different been the number to indicate the version and build number of the driver
