Acer Aspire 5002 Wlci Zl5 - 5000 Series Laptop/notebook - Amd Turion 64 Logo
Anonymous Posted on Sep 19, 2012
How to remove cd/dvd drive on a acer aspire 5003WMLi
  • Anonymous Oct 19, 2012
    This particular model has 3 screws beside the hinges where the screen joins the body. when these screws are removed the keyboard and other internal parts are exposed and the screw holding the cd/dv can the be accessed.
Buddy Mcsparrin
Level 3:
  • Master 1,684 Answers
  • Posted on Sep 20, 2012
Buddy Mcsparrin
Master
Level 3:
Answers
1684
Questions
Helped
1011647
Points
4641
Turn the laptop over, on the bottom you will find a screw about 5-6 inches in from the cd-rom drive. The screw will have a little symbol of a CD next to it. If you remove this screw the cd-rom drive should slide right out. Be sure to do this with the laptop turned off, unplugged and with the battery removed.
2answers
How to change dvd rom drive from Acer Aspire 5738 laptop?
How to Remove Replace Install your Acer Aspire 5738Z Laptop CD/DVD Optical Drive
1. Check to see if your laptop requires a screws to be removed for the optical drive.
2. Find the CD/DVD Optical Drive release button.
3. Pull out your Acer Aspire CD/DVD Optical Drive.
4. Get your new replacement Acer Aspire CD/DVD Optical Drive and place it securely into the drive slot.
- Link:
http://www.laptopinventory.com/LaptopInventory.php/Acer/Aspire/5738Z/CD%20RW
2helpful
Acer aspire 5738 cd DVD drive not working
1.start>control panel>all control panel items>AutoPlay
change settings for each desired media
2.update the drivers for the DVD drive. search in all programs for the program name, go online and download the most recent driver
3. you may have mulitple programs that controll DVD/CDR reading ability. this will sometimes confuse/conflict the drive. try removing one using add /remove programs from the control panel.
1helpful
The disc drive on my acer Aspire 5742G will not read any music cd's or dvds. I makes plenty of noise as though it is trying to open it but nothing!
The CD/DVD drive may need reseating to make proper electrical connection. Remove this drive and insert it back into the laptop.
Next try cleanibg the drive.
The laser lens maybe dirty, use a CD/DVD lens cleaning kit to clean the lens int the drive.
If this does not fix your problem then the CD/DVD drive is faulty and needs to be replaced.
5helpful
3answers
How to reomve a faulty CD/DVD drive from the Acer Aspire 5510 to enable replacement.
Hello
With a number of software manufacturers using DVDs to distribute their software releases, having a Acer Aspire 5510 DVD-ROM Drive is not only convenient but is practically essential to keep up with software releases. Unfortunately, if your laptop doesn't have a DVD drive, installing one isn't quite as simple as it would be if you were installing the drive into a desktop computer. This doesn't mean that installing a laptop DVD drive is difficult, provided you purchase one that is compatible with your laptop. 1. Check to ensure compatibility between your laptop and the Acer Aspire 5510 CD-RW Drive you purchase. The best ways to do this are to purchase your DVD drive directly from your laptop manufacturer, look for compatibility information on the drive's packaging or ask a knowledgeable sales associate. If buying online, make sure to read all of the drive's profile to check for compatibility information. 2. Remove the Acer Aspire 5510 DVD-ROM CD-RW Combo Drive that your laptop currently has. Flip the laptop over, setting it on a sturdy surface with the side that the existing drive is on facing you. Depending on how the laptop is designed, you should find 1-to-3 screws holding the drive in place; these screws may be on the bottom of the laptop or on the side next to the drive. Unscrew the screws and set them aside for later use. 3. Flip the laptop back over. Carefully remove the old drive, pulling gently yet firmly if you encounter resistance/ This will be the drive unplugging from the laptop's drive interface, so a small amount of resistance is not unusual. Once the drive is free of the laptop, set it aside. 4. Slide the new Acer Aspire 5510 Combo Drive into the empty drive port. Make sure that you press it all the way in so that the drive will plug in to the drive interface. Once the drive is in completely, replace the screws to secure the drive. 5. Boot up your laptop. Your operating system will detect new hardware and will load temporary drivers for the DVD drive; insert the driver disc that came with the drive to install the manufacturer's drivers in order to get optimal use out of your new Acer Aspire 5510 DVD-ROM CD-RW Combo Drive.
Hope this helps, if so do rate the solution Good Luck
1helpful
MAY U PLZ ASSIST ME WITH MY ACER LAPTOP ASPIRE 4330 THE DRIVE IS UNABLE TO WRITE ALL THE DVDS BUT IT IS ABLE TO READ DVDS THE ONLY PROBLEM IS BURNING DVDS. HOW CAN I ENHENCE MY DVD/CD-RW COMBO TO WRITE THE...
No Sir, Acer Aspire 4330 comes with different Optical Media Loadings, ( You can see a pdf file here )
Like;
  • DVD/CD-RW combo drive
  • 8X DVD-Super Multi double-layer drive.
But you have the first one, The Combo drive not the super so you can READ both CD's DVD's but can write only CD's.
Hope this removes your dilemma.
If helpful, kindly do Rate!
How do you remove the cd/dvd drive in a acer aspire 5002 wlci
Look for screws underneath the cd drive. After you remove them it should just slide out.
2helpful
2answers
Unable to find CD/DVD Drive on Acer Aspire 5610Z
1. Disconnect your CD/DVD
2. Uninstall magic iso
3. Use a good anti-virus and scan all your hard drives.
Reconnect your CD/DVD. Verify if it works.
4.If not, right-clic "My computer", manage, select disk manager, assign a different drive letter to all drives but C:. Reboot. Verify.
5. Lastly, make a backup, reformat all your drives, reinstall Windows.
DVD/CD Combo drive, removal/installation.
I believe that this model has a built in drive the only way to remove it is to remove cover to the laptop. If the drive isn't working go into hardware profiles right hand click on the drive and select remove. This will remove it from windows then when you restart windows should find the drive and install the drivers. Make sure you have the software drivers before you do this.
Thanks J
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
