Error type P12: System ErrorError point 309: Master-compression-motor encoder sensor count did not change as the master compression motor activated in the compress direction and moved out from the home position. Try this: Press reset-key. If recovery fails you machine needs service.
I have the same problem..but i fixed that. if u have the same type with mine; TCL split type ac, TAC-42CF/A,380V 3N~. Then u can try this.
1. open indoor panel.
2. find 2 cable in socket pcb that is p11 And P12, u plug p12 on p11,and p11 on p12.
3. if not solved, try the same just like point 2 on power suply 3phase cable R.S.T try S to R, or else.
4. hopefully ur problem solved.
Windows 7 is usually great at finding and installing compatible drivers for digital cameras, etc.
Please click or paste the link below and click "download".
It refers to the kodak "easyshare" software which may include a driver in the package.
Hope this helps :)
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken. Check Door Lock/Switch Assembly for foreign objects Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) Door Lock/Switch Assembly Failure
If it is a cabrio: dU flashes if the following conditions occur: Excessive force on door lid is preventing lock bolt from retracting. Wash media buildup is preventing lock bolt from retracting. Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock Perform the following checks if washer fails to lock (or unlock). 1. Perform Manual: Door Switch and Manual: Door Lid Lock tests. 2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies. 3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1. 4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the resistance values....
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/ Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4 Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7 Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power. Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Door Unlock Error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem exists in the door lid lock. Replace the door lid lock. 5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power. Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Door Unlock Error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Door Unlock Error
Door Unlock Error
