Question about Apple eMac G4 Desktop
Monitor won't turn on - Apple eMac G4 Desktop
  • yourwebmonke Dec 27, 2008
    I just got this emac. The front panel light comes on but the Monitor does not turn on.
    Any thoughts
    Thanks so much
  • Martin Buck
    Martin Buck May 11, 2010
    Do you get any tones when you start up? Can you hear the hard drive spinning? If you get the normal start up tones try plugging an external monitor into the eMac and check for a display signal. It may be either video failure, or screen failure.
    Novelist:
    Champion:
  • 233 Answers
My eMac has no port for an external monitor. I've heard that there is a way to install one but it seems that to do this the computer must be partially disassembled. Being that there is like 8 million volts of electricity stored somewhere inside the CRT I would not attempt this yourself. You might get electrocuted. This is the problem with all in one computers. When the monitor goes it is an expensive repair.
Posted on Dec 30, 2008
Power flashes on for a second and then turns off completely
The most likely problem is that the power supply has failed.
Jul 19, 2013 | Shuttle XPC SD32G2 Barebone
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Monitor repair won't turn on
maybe have to replace a few capacitors inside monitor. Or maybe as block fuse.
Nov 01, 2012 | Computers & Internet
Monitor won't go on
What to you mean by Monitor won't go on? Are you saying the power on the monitor will not turn on? Are you saying the Monitor is on, but there is nothing showing on the screen? Also it would help if we know what kind of computer and what operating system.
Mar 22, 2012 | HP G60-235DX Notebook
Monitor won't go on
Mar 22, 2012 | HP Pavilion G60-235DX notebook
Vsonic flat screen monitor need blink codes
hi do you mean you are asking for the blinking codes on your viewsonic pc monitor?. usually lcd monitor for pc has no blinking codes, if your monitor just only a blinking indicator and won't turn on, you must check first the source from your pc if their is a signal to turn on the monitor. if just blinking only then won't turn on you must check the power supply of the monitor usually the main cause is bulging capacitor. just replace it with the same value and rating thanks for consulting the fixya good luck.
Feb 26, 2012 | Computers & Internet
When i turn on my pc, the cpu works perfectly while the monitor "syncmaster591s"....when i turn on the monitor the light (green) beside the button of the monitor is blinking
Try a different monitor...if the different one won't come up then the prob is your video card in the computer...if it does work then the monitor is defective...it would probably be cheaper to get a new monitor than to have the syncmaster fixed
Apr 27, 2011 | Computers & Internet
COMPUTER WON,T YURN ON
first of all,is your power cable properly connected to your system unit.if it is not,connect it properly and turn the system unit on again
secondly,make sure your signal cable from the monitor to the system unit is properly connected
after following these instructions,reboot your computer again.
thank you for consulting fixya with your problems
Feb 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
My monitor will either stay on and wont' turn off (even if you click the green button)
your Mnotitor Panel Switches gone bad replace all the switches and your monitor will be ok.
Ashok
Jun 08, 2007 | HP Compaq FP5315 15" LCD Monitor
Apple eMac G4 Desktop Logo
332 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
