Question about Panasonic CQ-DF783U CD Player
Amp won't power up
I have wired the Amp corcetly to the Best of My knowledge, (12v to Battery, Ground to a GOOD ground, Remote To the Blue w/ white stripe Rca From Amp out puts and Speakers out) The Amp is Good, works fine in other vehicles, Head seems to be in great shape, But the Amp will not come on. Am I doing something wrong, any help would be great Thanks alot David
    Novelist:
    Champion:
  • 219 Answers
If you are saying that you wired the remote to the RCA from the amp outputs then that won't work. A good way to make the amp just turn on is to have NO speakers attached, no input RCA's attached. Just have ground to ground and B+ to 12 (battery). If your then temporarily jump 12volt from the B+ terminal to the remote terminal then the amp should turn on and stay on as long as the jumper is in place. In a normal hookup, the remote 12volts is supplied from the radio (head unit).
Posted on May 05, 2007
Wiring diagram pioneer dxt-2369ub
----POWER---
Yellow = Radio Constant 12V Batt +
Red = Radio Switched 12V Acc +
Black = Radio Ground Neg -
Blue/wht = Remote Amp turn on or Pwr Ant
----SPEAKERS----
White = Left Front Speaker Wire (+)
White/blk = Left Front Speaker Wire (-)
Grey = Right Front Speaker Wire (+)
Grey/blk = Right Front Speaker Wire (-)
Green = Left Rear Speaker Wire (+)
Green/blk = Left Rear Speaker Wire (-)
Purple = Right Rear Speaker Wire (+)
Purple/blk = Right Rear Speaker Wire (-)
RCA = Output to Amp
Nov 30, 2011 | Car Audio & Video
Free pioneer DEH-5 wiring guide
Here ya go...
Power and Accessory Wiring:
Red = 12v Switched Source (Ignition)
Yellow = 12v Constant Source (Battery)
Black = Ground (Chassis)
Orange = Illumination (Dashboard Lights)
Blue with White = Power Antenna Up / Down Signal
Blue = Amplifier Power On / Off Signal
Speaker Wiring:
White / White & Black = Left Front speaker + / -
Green /Green & Black = Left Rear speaker + / -
Gray / Gray & Black = Right Front speaker + / -
Violet / Violet & Black = Right Rear speaker + / -
Oct 05, 2011 | Car Audio & Video
I have a rockford fosgate punch 800 car amp and the problem i seem to be having is everytime i connect my remote wire to my stereo deck and i turn my stereo on it burns the fuse its only when i connect my...
Check the wires at the amp. Make sure that the wires are neatly bundled and clean cut when connecting them, a stray wire may be going under one of the connections from the battery input to the ground input of the amp, there for causing a direct short and blowing the fuse. I am assuming you mean that the amp's fuse is blowing. Get yourself a test light and test the wires for power. battery power?(12V) is always on and remote power(12V) comes on only when the radio is on(it should be the blue wire in color). Then make sure you have a very good ground, I always use the seat belt bolt or car seat bolt(direct to chassis). If you checked all these steps with no luck then the culprit may be your amp.
Jul 22, 2011 | Car Audio & Video
Need a radio wiring diagram for a 97 Nissan Altima i found one on line but it wasnt nothing like the colors of the wires in my car.
red = 12v ignition/acc
yellow= 12v battery/memory
black = ground
blue = power antenna
blue/white = amp turn on
black/white = amp ground
orange = illumination
orange/white = dimmer (+)
orange/black = dimmer (-)
brown = mute phone
speakers---
grey = right front positive
grey/black = right front negative
white = left front positive
white/black = left front negative
violet = right rear positive
violet/black = right rear negative
green = left rear positive
green/black = left rear negative
Dec 30, 2010 | Car Audio & Video
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
Need a wiring diagram for the gta4...please advise.
im not to familar with your amp but iv wired a lot of amps. You should just have your power ground remote and your sound. For your 12v+ You should not use anything less than about a 4 gauge wire fuzed and ran strait to your battery for this hook up your ground wire is to be no futher than a foot from your amp grounded to the vehicles chasis not over painted surface but a solid metal to metal contact with a good fitting for you connection on both ends. Then of coarse your remote which is labeld remote on your amp it is the only power source use to power your amp up and down it both completes the circuit and alows your amp to be manualy triggared with when you car reciever is on this remote wire is very important if you are doing the hook up your self you will want to make sure first that you if you have a factory radio in your vehicle to isolate that wire using a 12v tester. If you have an after market stereo in your vehicle such as a jvc kenwood alpine sony ect then you should have a blue wire with a white stip that is on the exsisting harness. That is your remote amp wire and it will tie in to your amps remote wire to power it up when the reciever is on or power it down when the reciever is off. My names Josh good luck with wiring the amp.
Mar 06, 2010 | Blaupunkt GTA 4 Car Audio Amplifier
I need a fuse diagram for 2001 Nissan Pathfinder
Do you want to install a new unit or wht ? u may use this reference to work upon ....
Get yourself a digital multimeter. Find the +12V constant, 12V remote, and ground. Connect them to the new head unit. For speaker wire get yourself a 9V toy battery and listen to poping noise. If you have a factory amp you need to power up the factory amp. Use the wiring diagram below to serve as a guide. Test your wire first before connecting them.
NISSAN
P o w e r
Memory (+12v Constant) Red
Ignition (+12v Switched) (varies) Brown or Green
Ground (-) Black (varies - most don't have one)
Illumination Red/White
Dimmer Red/Black
Power Antenna Green
S p e a k e r s
Right Front (+) Brown
Right Front (-) Brown/White
Left Front (+) Black
Left Front (-) Black/White
Right Rear (+) Blue
Right Rear (-) Pink
Left Rear (+) Red
Left Rear (-) Green
Feb 04, 2010 | 2001 Nissan Pathfinder
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
My wife bought a kenwood z828/uf4. there are wires in the back but none of them are labeled. can anybody help me
red - 12v ignition
yellow - memory 12v cont.battery
orange - illumination
black - ground
white- front right speaker +
white/black stripe - front right speaker -
gray - front left speaker +
gray/black stripe - front left speaker -
violet - rear right speaker +
violet/black stripe - rear right speaker -
green - rear left speaker +
green/black stripe - rear left speaker -
blue - remote, amp
blue/white stripe - power antenna
if you don't have a blue/white strip wire than the solid blue wire goes to power antenna, amp and remote...........
hope this helped you
Feb 26, 2009 | Kenwood Car Audio & Video
Dual xdvd710 wire code
RED..................... IGNITION 12V (+)
YELLOW.............. BATTERY 12V (+)
BLACK................. CHASSIS GROUND (-)
BLUE................... POWER ANTENNA (+)
BLUE/WHITE........ AMP TURN ON (+)
WHITE/BROWN.... REVERSE LAMP (+)
YELLOW/BLUE..... PARKING BRAKE (-)
~AUDIO SPEAKER CONNECTION~
GRAY................... RIGHT FRONT(+)
GRAY/BLACK....... RIGHT FRONT(-)
WHITE................. LEFT FRONT(+)
WHITE/BLACK..... LEFT FRONT(-)
VIOLET................ RIGHT REAR(+)
VIOLET/BLACK..... RIGHT REAR(-)
GREEN................. LEFT REAR(+)
GREEN/BLACK..... LEFT REAR(-)
May 26, 2008 | Car Audio & Video
Panasonic CQ-DF783U CD Player Logo
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
