I wont shut properly it make like a clicking noise when it hits the catch but wont shut
See this causes, and use the common sense. God bless you
When your dishwasher door has a problem, check these:
Latch
Springs
Hinges
Door seal
Latch
The
latch on many dishwashers is adjustable. If your door is easy to close
but difficult to latch, adjust the latch to let the door close more
easily. If you can't see any way to adjust the latch, yours may be fixed
in a certain position. Check for other reasons for the latching
problem.
If
the latch has worn out in a way that makes it impossible for you to
close the door properly, you probably need to replace the latch.
Springs
Your
dishwasher has two springs that counterbalance the weight of the door.
If either or both of these are broken, the door feels quite heavy and
you need to replace both springs.
Hinges
The
hinges are important to the door closing properly. If they're bent or
deformed, you probably need to replace them. Once bent, only rarely can
they be straightened well enough.
Door seal
If
your dishwasher is new--or if you have just replaced a door seal--the
door may be difficult to latch for a week or two. If the tightness
persists, though, try adjusting the latch, if it's adjustable. If it's
not adjustable, there's probably nothing you can do immediately. But try
running the dishwasher on the highest heat cycle to help the seal
conform to the door. Otherwise, the seal should compress over time.
SOURCE: door not clicking shut
I had the same problem. There is a spring on the catch mechanism that breaks. Replace this and it fiexes the fault.
