Question about Garden
Electrical in a scat trak skidsteer with a 42hp kubota deisel
No matter what battery and combo with jumper cables to a truck it will not generate enuff power to start-injectors not spraying enuff fuel was one answer i recieved---anybody know
  • RWCamp Jan 15, 2009
    Same thing, having electric problems with the scat trak
  • 100 Answers
Try using 2 batteries to spin it over faster
Posted on Feb 16, 2009
I installed aftermarket fule pump to incresefule presure
Posted on Mar 04, 2010
Kubota troubleshooting
Faulty switch, unless it's a deisel.
Jul 27, 2014 | Kubota Garden
Starter stays engaged or blows a fuse when I try to start my skid steer
This could be the starter or the ignition switch, Take the starter out and have it tested. IF the starter tests ok, replace the ignition switch.
Jan 06, 2014 | Cars & Trucks
2003 taurus lights dimed &suddenly died as if there was no battery. I tried to jump start it but i got nothing but clicking from curcuit breakers by the battery compartment
Yes... Your battery died. But why?
First, leave the cables on longer, a good 10 or 15 minutes. When you hear that clicking noise, it's because there is not enough power available to turn the starter. It means you need more power. Leave the jumper cables on for a few more minutes and you will have the power you need to start the car.
Once the car is started, remove the jumper cables and pull the positive (Red) cable off the terminal on your battery. If the car stays running, get a new battery. If the car dies immediately after pulling the positive battery cable off, then your altenator has gone out. The altenator is the electrical generator that provides electricity to your lights, engine, stereo, AC, etc. It should be putting out about 14.2 volts. Since your car is a 12 volt system, there are a couple of extra volts to spare, which are used to recharge the battery. It takes a lot of power from a battery to start the vehicle. That's why the alternator is there to takeover after startup, plus recharge your battery in the process.
Feb 21, 2013 | 2003 Ford Taurus
Volvo/scat trak 1700
check pressurising pump is working and if ok check for pressure valves are working correctly . Have the unit system pressure tested for fault finding results
Feb 17, 2013 | Volvo Cars & Trucks
I need a down loadable manual for my kubota GL11000 diesal generator
Kubota GL11000 and Kubota GL7000 Manual http://www.pacifictoolcompany.com/index.php?main_page=index&cPath=13_127
Sep 30, 2011 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
The engine will run if I hook up jumper cables to
the on board electric system is not working, you lose your spark when you remove the jumper cables, this tells you the mower is not making its own electricity. So either the alternator or its regulator, or both have gone south.
With the engine running, you should have just above 12 volts at the battery.
So find a manual, locate the alternator/generator, and be looking in that area for a broken connection, blown fuse, or bad component.
Jul 28, 2010 | Husqvarna 22HP VTwin Hydrostatic 42" Cut...
Can not excite generator
most generators you can polarize the brushs this is done by using a 12v. battery and a set of jumper cables hook to the battery and touch the brushs with the other ends it doesn't matter whicht side, but before you do all that check the connections at the brushs and see if they are loose or not making a good contact, i do hope that i was able to help you, thank you.
Jan 07, 2010 | Coleman Powermate Premium Plus 6250W...
POSITION OF SLAVE/MASTER JUMPER on rear of unit Toshiba-Samsung SH-M522 Combo
You'll find jumper instructions in the user manual which is available on Samsungs website (http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP08&prd_mdl_cd=SH-M522C%2FBEBN&prd_mdl_name=SH-M522C&prd_ia_sub_class_cd=P ). However, most drives have jumper setting key on the drive label. The choices are usually master or slave or cable select.
Oct 25, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
On a deisel p/u (ford f250 with 6.0 v8 deisel)is one battery the primary and the other one the secondary? During warm weather, which is all the time here in Phoenix, can I remove one battery. I really...
Diesel starters work a lot harder than gas. Diesels have a much higher compression than a gas engine, usually at least double and that is why your truck has 2 batteries. Removing one is not a good idea and will not save you any time or money. If the truck will start, doing so on one battery will lead to premature failure and could damage your starter. Removing a battery will also impair your preheating system because it works like a stove element, converting electricity to heat. Leave both batteries in the truck and hooked up. Hope this helps.
Sep 11, 2009 | Ford F-250 Cars & Trucks
Garden Logo
863 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
