Question about Saitek Computers & Internet
Mouse right click button not working
Right click button started to work only sometimes then completely packed in. So right click on something and nothing happens but left click button is okay
jyvibar
  • 148 Answers
SOURCE: Logitech MX610 problem.
best thing to do is to replace your mouse
Posted on Mar 23, 2008
MJS_1
  • 150 Answers
SOURCE: Mouse Right click doesn't work
Replace the batteries and check to see that there is a clear path
between the wireless mouse and its transceiver.
Keep the transmitter well away from older style CRT monitors, and make sure that the USB connector is properly plugged in.
You can also try to reset the mouse by unplugging the USB
connector and plugging it back in. There is no need to reboot
the PC, because USB is hot-plug-and-play.
1) The mouse consumes very little power in standby mode.
When the mouse moves or you press a button, the mouse
wakes up, it's internal processor begins to crunch
coordinates, and the RF transmitter is briefly activated.
This surge in power quickly depletes a weak battery, and
the mouse begins to malfunction. After a short rest, the
battery partially recovers (this is due to chemistry) and
the mouse may work for a few seconds again.
For some reason, my Logitech mouse fails quicker, when
I press buttons, rather than just move the track-ball, and
the buttons are the first to malfunction.
(No I have not analyzed the circuit and the internal mouse
software to determine the exact reason it does this ::)
Anyway, replacing the "AA" battery should help.
2) The location of the little RF transciever, which connects
to the computer using a USB cable, in relation to the mouse
is also important.
a) The communication signal weakens with the square
of the distance.
b) Metallic objects will block the signal.
c) CRT monitors emit powerful, wide band interference,
polluting large segment of the radio frequency spectrum.
This interference can over-power and corrupt the faint
communications between the mouse and the transceiver.
3) If these obvious measures fail, you may have a defective
mouse:
a) The fault is most likely in the mouse, not the transceiver,
but do check in the control panel => mouse settings
to see if the mouse is communicating, and the battery
status.
(Most mouse drivers do report these things)
b) If the mouse is at fault, you can disassemble it by
removing a few small Phillips screws. Pay special
attention to any mechanical linkages, springs and levers,
to make sure you put it back together correctly.
c) Pop out the tiny circuit board, and locate the mechanical
micro-switches. See if they work when you manually
activate them.
If they feel intermittent or flaky, you may try to clean them
with a spray contact cleaner, or replace them, but given
the price of mice these days, this may not be worth it,
save for the psychological boost/and or satisfaction.
Martin
Posted on May 08, 2008
serra_baby
  • 144 Answers
hello!
o Install fresh batteries. Try brand new-high quality batteries you absolutely know are fresh and working.
o Install the latest software. Totally remove all software and reinstall from scratch.
o Try a different port and Resynchronize your device to the receiver. Try plugging the mouse into a different USB port try powering down the computer and using the PS2 port for the mouse instead. Mice in my experience overall work better using PS2 ports on PCs that have them.
o Clean the mouse lens. This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty.
SOURCE: My left mouse button isn't
my right mouse is not working
Posted on Jan 18, 2009
Mike258
  • 1498 Answers
SOURCE: Loss of control over my mouse.
Hi Arsenal,
My Logitech cordless occasionally does the same thing. On mine it was caused by a build up of gunk over the optical sensor. Once I cleaned it, it functioned normally.
I know it doesn't make sense as far as the buttons. I'm just sharing what worked for me. Hope it works for you.
Best regards
Mike
Posted on Jul 29, 2010
TOUCHPAD MOUSE ANS KEYBOARD NOT WORKING
Try these steps.. Click start button, type "mouse" on Search Programs and Files, click "mouse" under control panel. In mouse properties options....as you an see the touch pad driver tab? click it. Choose or click option button and you can enable the right and left click button. About the keyboard problem,,,,,go to device manager, right click the standard PS/2 keyboard..uninstall it. Windows restarting and the keyboard driver will re install automatically.. check if the keyboard works fine.
Aug 17, 2014 | Acer Aspire 3810T 4810T 5810T
The right click button isn't working
does this mouse have a ball on it or its the ones with the red light.
Jan 28, 2014 | Microsoft Comfort Optical Mouse 3000...
Mouse buttons left right switching sticky keys
Remember you can always use the keypad in place of the mouse. Try replacing the mouse with another one. If that doesn't work, it is probably something in the software. Do a scan on the system next.
Jan 31, 2013 | Microsoft Computers & Internet
My mouse works but is flaky! Mouse icon is
I just wanted to say Guru's probably right. I had this same problem and realized my cell phone was right between it. Moved the transmitter a little closer, moved my phone, and it works like a charm.
Mar 06, 2010 | Logitech LX6 Mouse
Mouse won't work
Install the drivers for the mouse.
May 11, 2009 | Computers & Internet
Wireless Optic Logitech mouse performace
I had the exact same problem with my original Logitech wireless mouse that came with a wireless keyboard. I eventually figured that the button component inside the mouse wasn't making consistent contact causing unintended double clicking or dropping while dragging. I fixed it by doing some soldering to switch the left mouse button with the right mouse button, since I didn't have to use double clicking or dragging with the right mouse button. It worked pretty well for several months until the switched left button started showing the same problem again. Now my newer Logitech mouse (it's more expensive Nano wireless mouse) is having the same problem after about 1 year using it. I think there's a serious durability problem with the button component that Logitech is putting on their mice. I may do the same trick again on this mouse, but now I don't consider Logitech as a good mouse manufacturer anymore. They used to make good quality hardwares but I guess they aren't that good anymore with all those cheap Chinese suppliers for their parts. :(
Apr 28, 2009 | Computers & Internet
Logitech mouse doesn't respond to my clicks
Even though it does not make sense, if you are using a wireless keyboard that is part of a combo pack (mouse included) sometimes (some brands) you have to plug in all cords on the keyboard/mouse receiver.
Oct 30, 2008 | Dynex Keyboard/Optical Mouse DX-CKB102
Left click of my logitech cordless optical mouse not works properly
try to set on your MOUSE, here:
start-control-panel-mouse folder
hope this can help. :)
May 16, 2008 | Logitech Wheel Mouse Optical
Computers & Internet Logo
346 people viewed this question
Top Saitek Computers & Internet Experts
micky dee
Vebble
Are you a Saitek Computer and Internet Expert? Answer questions, earn points and help others
