Question about AT&T High Speed DSL Modem
I have an at&t modem that I use to access the internet hooked up to my desktop computer and cannot remember the original internet connection passcode/key. how do i access this wireless connection on a new laptop?
  • Thomas F. Schneider May 11, 2010
    Have you called ATT  support on the phone? I have found them to be quite helpful.
  • 24 Answers
Ask the net what the URL is to your modem and then hook it back up to your desk top and use your browser to access the modem. It may have a hint or might come up with your pass code. You can always go out dial up and get the info
Posted on Dec 27, 2008
Linksys fix
check your router for proper settings.does the router give your desktop a ip address if plug in to the router only.either the modem or router does the dhcp.is the modem in bridge mode? check the settings on both
May 24, 2017 | Computers & Internet
Hello, I have a Linksys 2.4 GHZ wireless access point router. Is there any easy way for someone to explain how I go about hooking this up to my main computer so the computer on the first floor will have...
Contact the cable company and tell them you have a router connected to your modem - they will tell your modem to access the router for it to work.
Oct 29, 2010 | Computers & Internet
Isues connecting to internet from 2 computers off switch
well first get a new modem and download the program network magic and tnhat shoudl help you
Jan 18, 2010 | D-Link Express EtherNetwork DSS-5+...
I dont have access to internet am missing the hardwere
Most Internet Service providers do provide the modems necessary to connect to the internet. If you are not using a modem and are using dialup, then you will need to make sure your computer has a dial modem and that you have an active phone line to plug into your computer.
If you would like to use DSL or Cable to connect to the internet, then a call to your ISP will be sufficient and a tech will come to hook up your connection.
Nov 15, 2009 | HP Compaq Presario 6320US (DA202A#ABA) PC...
My compaq prasario is telling me I have no ip address how can i solve this problem i cannot connect to the internet
How are you connecting to the Internet now¿ That is a serious question since I will assume that this is a second computer hooked up to the same connection you want with the Presario. I also will assume that you don't have a Gateway / Router between the modem and the actual computer. I will assume that you want both of these computers on the Internet at the same time so you will want to hook up the Gateway. To reset the modem so that it will accept a different MAC Address (It's a computer thing) you will need to remove all the connections to the modem and pull out the battery that is behind a hidden door. The modem will need to be in this condition for 1 minute and then it can be hooked up to the new Gateway or Computer however you want it to be hooked up now that the modem has been reset. Good luck.
Sep 18, 2009 | Compaq Presario 5000 PC Desktop
I can't hook my computer up to my phone line for internet. I have my router and another desktop hooked up to the phone line through the router.
That modem is in itself a router. However it only has one Ethernet port and no means of broadcasting a wireless Internet Signal which makes its function of a Router somewhat useless. What you need a(n) (wireless) access point. The Access Point will give you more Ethernet slots allowing more computers to be connected to the modem/router via CAT5 (Ethernet) cables. Depending on if you get a Wireless access point or not you might also be capable of using a wireless adapter to connect to the 2wire and get Internet access.
Let me know if I need to clarify any of the points above or if I can assist you further.
Mar 16, 2009 | 2wire 1800HG Router (RG1800HG00)
Bright house modem and desktop computer, trying to hook up wireless net gear router for 2nd desktop to get internet? How do I configure the cables?
Connect the lan cable from the dsl modem into the first port on your netgear router ..
make sure your dsl modem is on PPPoE mode so that it autoconnects..
Now just connect to your wireless router via your pc interface..
*Do add a network key to your wireless network to avoid unwanted access
Jan 19, 2009 | NetGear WGR614 Wireless Router
No network detected to setup wireless router
You have to set a network connection on the computer. Go to the control panel and chose Network, the set a new one.
Jan 06, 2009 | Computers & Internet
I hooked up a wireless router and I can't get on the internet, it says Local Access only.
That means that your router does not have access through your modem. Connect your computer to your modem and check if you have internet. If you do not contact your ISP.
Aug 06, 2008 | Computers & Internet
Ethernet Card
Do a ipconfig at the command prompt and see if you are being assigned a ip from the modem. If not try rebooting the modem with the ethernet connected to modem and computer. then do ipconfig again to see if not getting internet ip, your card or modem eternet is bad. put in a new one and try again.
Jun 01, 2008 | HP PAVILION A6230N DESKTOP PC
AT&T High Speed DSL Modem Logo
459 people viewed this question
Top AT&T Computers & Internet Experts
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
