Question about Nikon D40x Digital Camera
My Nikon D40 is frozen on the screen "Connecting to PC". I have left the battery out for months, tried resetting it with the reset button, tried reformatting the SD Card, etc. When I turn it on now, it says to reset the clock, when I attempt to do so it returns to the "connecting to PC screen"
  • rwasson3 Mar 06, 2009
    as described - camera comes up with screen saying "connecting to PC" and will not do anything else. This is likely to be the last Nikon product I'll ever buy after the viewfinder fiasco with a collpix 8800 - that one lasted anout 18 months and then the viewfinder went away. Nikon store in AZ says it cannot be repaired. The d40x was the replacement for it and now it is busted.
  • 3 Answers
Connect the mini usb calbe to Camera only. Camera will working like used to be without cable. Go to setup menu and Change USB setting to P, PTP. then unplug the miniusb and hopefully camera will work as it once was.
It worked for me :)
Posted on Jul 29, 2010
How to turn on Discovery Mode for Nikon D40 Digital Camera
There is nothing about a "Discovery Mode" in the D40 manual. I am not sure if this will work, but try resetting the camera to its default settings. Push the menu button on the left side of the LCD and scroll down to the pencil symbol. You will find an item on that menu called "Reset". Once you do the reset, see if the "Discovery Mode" is there. Frankly, I think you would be much better off if you read the D40 manual. In case you lost yours, I have attached a link where you can download it in pdf format.
Jun 30, 2014 | Nikon D40 Digital Camera
Nikon d40 flash won't fire
If it clicks when the flash is already open, it seems there would be a problem with the flash open sensor. The camera thinks the flash is closed, so it tries to open it again and it refuses to fire, because firing in the closed position would blow the bulb.
The D40 flash is a bit different, but if you open it (just unscrew the two little screws in front) you'll recognize the sensor clips. Open and close the flash and see if the make contact when open.
(And DON'T fire the flash when open, or at the very least don't touch anything in there when firing or you'll get zapped.
May 16, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Camera wont turn on My Nikon D40x wont turn on at all, i have been using it, then plugged it in the my laptop with the USB cable, unplugged it to take more pix, and it now wont turn on at all!!
Just a suggestion ... remove the lens, card and battery. Recharge the battery completely. Install the lens, card and battery then do a hard reset...
Hard Reset:
With D40 you need to install the lens, the card and the battery then open the cover under which USB and video sockets are. There is a small button in the hole. Press it with pencil tip or something and the camera will be reset losing all settings and clock time.
May 28, 2009 | Nikon D40x Digital Camera
Missil pmp-8308 has a frozen screen
Hi There,                On the pmp 8308 Missl Mp4 there is a hole on the left side of the device. Just stick a needle into the hole to push the reset button on the inside of the device to unfreeze the device.
Apr 02, 2009 | Aiwa HZ-WS2000 MP3 Player
My nikon d40 displays "shutter button deactivated, recharge battery".but i charged the battery, my camera still wont please
A couple of things to try, and if these don't work you will probably need to have it serviced.
1. There is a reset button which may fix it. It's described on the first page of "Troubleshooting" in your manual. The camera diagrams at the front of your manual will help you find it, near the connector cover.
2. If it doesn't work after the reset button, pull the battery out and leave it out for two days, then put it back and try again.
Mar 02, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Initialization Error
try pressing the 2 green buttons to reset the unit . if you get lucky and it turns on, immediately follow the steps to update your firmware on this website , otherwise you will need to take the camera to an authorized repair center . :)
Aug 30, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Screen frozen player will not do anything
Have you tried:
1) pressing and holding the reset button (little hole on the bottom right of the player" for 10 seconds?
2) removing the battery for 10 seconds?
3) connecting it to your PC with the battery removed?
4) connecting it to your PC and pressing the reset button for 10 seconds?
Jul 23, 2008 | Insignia NS-DV2G MP3 Player
Frozen screen
A friend has an Archos 404, media player, and it foze up while she was using it. Could not power it off or get it to do anything. Ended up having to remove the 4 tiny screws and then Remove the battery. This reset the unit completely. Put it back together, including the battery, and the unit powered on and worked correctly. Often a simple system reset can fix most freezing issues.
Dec 28, 2007 | RCA opal MP3 Player
Zen frozen
Go to recovery mode, and do a disk clean up. If that doesnt work, then you might have to format it.
Did you reset it properly? To reset your zen, put a pen head in the hole under the power button for 20 seconds
Nov 08, 2007 | Creative Labs ZEN V Plus MP3 Player
Nikon D40x Digital Camera Logo
377 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
