Question about Hitachi 46F510 46" Projection HDTV
Hitachi tv blew fuse during power surge changed the fuse
I had a power surge and it blew the fuse and several other things in my home up. I changed the fuse and it still will act like it dont want to do anything. i checked it with a multimeter  and i was getting power after the fuses but it still  does nothing. I have no clue what it could be. I dont believe the problem is the fuse as of now i think that there maybe something else wrong does anyone have any suggestions
  • 1348 Answers
SOURCE: Got a Hitachi rear projection model # 50ux58b.
the three guns that the lenses drive operate at 28kv.
there are very high and dangerous voltages in a tv set.
you can look for the fuse main pc board by the power cord..if it is black,there is a major short.if it is just barely blown,change it.
the fuses are 3ag glass type and just pop in. use a set of rubber gloves and insulated pliers.. tvs are DANGEROUS
Posted on Jul 04, 2009
  • 1153 Answers
SOURCE: No audio, no video
Can you find out what Led is not on or which comes up and goes out? Most of these sets have convergence problems. Or Power Regulators.
Posted on Sep 23, 2007
  • 16 Answers
SOURCE: hitachi 60fx32b rear projection
When you turn on the TV do you hear 3 clicking noises then the TV turns off?
Posted on Jan 12, 2008
  • 579 Answers
SOURCE: Hitachi 51F510 with NO POWER
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Right on schedule since your TV is 10 years old)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Posted on Feb 15, 2008
  • 453 Answers
SOURCE: Green leds turn on momentarily when first plugged in then shutoff
ok , on hitachi pro tv is very common with bad power supply u may want to replace the voltage regulator which is next to the fuse u already replace , also loose connection on all the power supply seccion , also u may want to check the resistor close by the convergence ic 2.2 ohn if this are smoke replace stk392-110
Posted on May 08, 2009
I have an Hitachi 32 in Plasma tv 32PD5200E which suffered a power surge from a storm sunday night , everything else in house ok replaced fuse but new one blew imediately . Is this set worth repairing as...
The tv have fries alot more components on the tv power supply board,than just the fuse.U have to have alots more equipments and very good eclectronic testing and troubleshooting skills to find out what exact components parts are burn and to replaced it on the tv power supply board.U could take a gamble chance and try website like Ebay.com to buy a whole new refurbish power supply board for the replacement.Might get the tv to be working again might not because power surges,if it have a big enough electrical static charges it will fries alots more boards and it components some where else too.Tv worth repairing or not it is up to u for to do the researching for the new tv prices and the prices charges by tv repair shops by those tv Techs. for repairing the tv..
May 10, 2011 | Hitachi Televison & Video
Tv wont turn on
Check the ff:
1. Power plug - for open internal wire due to frequent bending,pulling.
2. Try to power by remote - if power up by remote then you have a faulty tack switch.
3. Replace Internal Fuse - sometimes because of power surge the fuse fail. However if the fuse blew again this is an indication of shorts.
Next step is not Diy because of the ff reason
3. Voltage regulator - might be open or shorted.
4. H-out transistor - shorted
5. Open fusible resistor in line with the B+.
6.Dry joints
Thanks for using fixya.
Pls rate my help.
Jan 25, 2011 | Hitachi Televison & Video
Tv does not turn on after a thunderstorm and several attempts at power returning to the home. The power went on briefly then shut off several times, now the television will not turn on. We had the tv...
Check the main fuse in the power supply, the TV also has small surge protection devices (MOVs) installed after the fuse, any surges the come along and big enough will cause the main AC fuse to blow. When you surge protector, EVERY connections must go through the surge protector, for example, the AC cord of the TV is connected to the surge protector, the cable connection did not go through the surge protection, the surge then can get to the TV through the cables.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 21, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I had a power surge last night do to a storm and now my Projection TV won't turn on. Is there a surge protector inside the TV that I can reset or is the TV fried?
there are several fusses in a hitachi located in the power board if your lucky one of them took the hit you can , or have atech look for you the gma type fuse are avail at Radio Shack or your local tv shop
Dec 03, 2009 | Hitachi 57F500 57" Rear Projection...
We didnt have a surge protector on our tv we purchased from home shopping net. and lihtning came in the line and i guess hit our tv can it be fixed or is it worth fixing price wise i hate to throw it away...
Look at the power supply module, most of them will have a surge protection devices (called MOV, same as used in common surge power strip but cannot handle big surge that power strip can handle) installed to protect minor surge, it should blow the fuse. Once MOV blown, it will more likely stay short circuit, if you put the new fuse in it will blow the fuse right away. You need to see if the MOVs blew up any sign of blown up components.
Nov 01, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
No power on Samsung TV after storm
Hello Zkarim,
I'm very sorry to hear about your unfortunate new's. I had the same problem in my own home maybe a week ago.
Basically if your power flickered on and off at anytime during this storm then there was a power surge that probably fried your TV.
* First check the power where the tv was plugged in. Is it a power strip or a surge protector ? Surge protectors typically have an on/off switch and a separate reset push button.
If it is a power strip then the tv fried because there was nothing to stop it from happening (not even the fuse). If it was plugged into a surge protector then it could be quiet a few years old and not as reliable or the surge was to powerful for the limit on the surge protector.
The only thing you can do personally is send it in for repair if it's under warranty, if it is not then you can have it looked at by an authorized repair technician in your area. Troubleshooting should be fairly low, and you will at least be able to find out your options once they find the defected part.
Thank you for choosing Fixya!
Jul 15, 2009 | Samsung LE32A457 32 in. LCD TV
Hitachi 50GX30B 50 in. Rear Projection...tv won't turn on since electricity went off & on
I have worked on several of this model for power surge damage. Usually what I find is a blown fuse, a shorted regulator i.c. and possibly a blown bridge rectifier(diode array). On rare occasions you can solve this problem by replacing only the fuse, but if the fuse blows when you plug the set in, you will more than likely find above mentioned parts have failed. The best thing to do is to call a repairman but if you have an ohm meter you can test it yourself:1.Unplug set and remove rear cover.2.Get spotlight and look closely at where power cord connects to circuit board.Small glass fuse will appear black if open usually.Otherwise,test for continuity, or just replace it.3.After replacing fuse plug power cord back in while looking at fuse.If you see an instant flash, fuse blew again meaning you will need to obtain parts in power supply and solder work will be required. That is probably as far as I can take this other than saying that you might first want to look at underside of circuit board to determine if major surge damage has occurred. If it has you will immediately know because it will have burn marks all around a/c power supply. I hope this helps, Russmann.
Apr 28, 2009 | Hitachi 50GX30B 50". Rear Projection...
Power Surge at Home
This time it came in on the cable, the clue was the cable box also blew. So if you had a cable surge supression device...for HDTV, I think you would have survived the second surge.
I do have the technology. It is a F-connector type and will handle HDTV signal.
Nov 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Fuse location on tv
a fuse is a small glass tube about 3/4" to 1". it is located near the end of the power cord inside the tv. it is located in the power board supply circuit. there are several reason why fuse blew up. 1. sudden surge current/voltage in your area 2. shorted in either power supply or horizontal deflection circuits. when replacing fuse, be sure to change it with the same value. but if after replacement has been done and the fuse blew again, there is a short in the circuit as stated in reason no. 2. refer to a qualified service technician if you are not inclined with this job. good luck!
Feb 12, 2007 | Panasonic CT-32HXC43 32" TV
Hitachi 46F510 46" Projection HDTV Logo
385 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
