Question about AT&T LG CU515 Cell Phone - Black
Water damage - AT&T LG CU515 Cell Phone - Black
  • ceebee19508 May 11, 2010
    it is probably going to cost you extra to get a new phone because of the water damage
    Scholar:
  • 100 Answers
You should turn off the phone imediately then take out the battery. open up the phone and get a hiar dryer and a tooth brush, dry it out with the hair dryer, then brush it off with the tooth brush, let it out until you're sure its now dry, then put back the covers and the battery and turn it on. 90% of the time it will work again, if it didnt, then there is damage in the phone board that should be repaired by a proffesional.
let me know how it works out, good luck :)
Posted on Jan 03, 2009
Does closed water supply valve cause damage to dishwasher inlet valve or control board damage?
no
no water flow means that the inlet solenoid valve will stay open until the water level sensor is triggered by the water level
no water = no action
Jun 28, 2017 | Washing Machines
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
After 24 hours water damage does sitting a nintendo ds in rice after 24 hours work.
Most likely not, because the water damage has already damaged the circuits and the other components of the DS, and if there is any water inside the DS, the rice can't get inside of it like the water, and won't absorb it.
Feb 14, 2011 | Nintendo Video Game Consoles & Games
Water damage on the ds lite
Yes, this is a common problem with water damaged systems. I recommend you send it for repair, to anyone who will repair it under water damage.
If you don't have the money to do so, you can open it up and clean it out with rubbing alcohol and a firm brush and dry it .
Clean off EVERY SIGN of Water Damage you see.
Goodluck, I hope this helps.
Mar 31, 2010 | Video Game Consoles & Games
How can I tell if my LG Dare has water damage? I don't see one of the white or red round dots that people talk about.
In order to check for water damage you need to remove the back cover and battery and check for a square or a dot on the back of the phone, this is called the LDI (liquid damage indicator). If the LDI is white then its not water damage, if its red or pink then the phone does have water damage. If you don't see the LDI it might have been removed by someone or by the water itself, you need to take it to a Verizon store so the can check the internal LDI.
Hope this helps,
joe
Feb 25, 2010 | LG Cell Phone Accessories Bundle for...
My daughters LG KS360phone has stopped working - the dealer (optus) say they won't accept it for warranty repairs unless I pay them $50 in case its water damaged - does anyone know how to check for water...
The most basic way to check for water damage is to open the back cover and take the battery out. Either on the battery itself or on the phone under the battery there should be a white square or circle. This is called the LDI (liquid damage indicator), if this is still white then there is no water damage. But if this is red or pink there is water damage.
Hope this helps,
Joe
Feb 19, 2010 | LG KS360 QWERTY Keyboard Phone BRAND...
Water damage to Nokia 6682 and won't turn on. Can
First never turn on any phone after be drop in water ! it's cause a electric shortcut and damage the phone.
I recommand to find a expert because the operation is manually and requeste a to be expert.
But if you can:
  1. open the phone
  2. clean it with a solution that can asperat and vaporate the water
  3. use some warm air to blow it over the chip like dryer
good luck;)
Sep 09, 2009 | Nokia 6682 Handheld
Water damage. never been near water. we are told it was in cold weather and the condensation caused water to get inside.
Unfortunately water damage is usually permanent because it results in a short circuit which often fries the boards. However, if your electronics device made contact with water while OFF, fear not. It should still work provided that you wait until the innards are dry and the water evaporated. The water build up probably came from water condensation. If it hasn't fried, dry it out REALLY well and hope that it hasn't already been damaged. If you already turned it on without luck, then it looks like you have a broken iPhone on your hands. Sorry.
May 06, 2009 | Apple iPhone 3G
How to flush the engine coolant in a Fiat Sciento?
You need water and antfreeze half and half 50/50 mixture. If damage to the raditor,it will leak outside. If damage to the engine it will leak either outside or inside into the oil,and the engine is usually badly damaged. I hope you replaced the water with the antfreeze in time.
Jan 04, 2009 | 2006 Fiat Pininfarina
AT&T LG CU515 Cell Phone - Black Logo
73 people viewed this question
Top AT&T Cell Phones Experts
Oloyede Monsuru
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
