Red blinking light at bottom of panel indicating lamp replacement
I ordered lamp on line and I had some brownish sand like particles in the lamp cover and around this area. Shop vac'ed this stuff out and
shined a flashlight into the lamp area and I see the square glass
fixed unit in the back has a slight film on it. This is where the lamp
shines into this mirror like glass.
I haven't touched this yet but should this be cleaned? If so, how do
I do it. I can reach it with a soft cloth but I don't want to mess anything
up.
Thanks for the Help Guru. I cleaned off the film with the soft cloth and tried it dry with a soft cloth and it all came off without any
probems. Just waiting for the lamp to show up. thx again, rbThanks for the Help Guru. I cleaned off the film with the soft cloth and tried it dry with a soft cloth and it all came off without any
AnonymousApr 12, 2009
IS LAMP HARD TO REPLACE? IS LAMP HARD TO REPLACE?
You can't post conmments that contain an email address.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
there is an conductor under the cover,
pls push it down ,
and turn on the projector
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Hi, 3 times red light blinking indicates that Lamp Cover has not been fixed in its location properly after lamp replacement. Please make sure lamp cover (its first thing that was removed to replace lamp) is installed securely. Thanks.
Make sure properly connected and tightly sure cover put on and screws in,if change projection bulb,still blinking "LAMP" LED indication light.But,if "LAMP"LED indication flashes and making clicking noise.Ur Ballast board also dead.Require replacement,this Ballast board help to ignite the projection bulb.
Red light blinking is an indication of lamp problem. Check and secure tightly the following:
Outside lamp cover
Lamp door
Lamp
If all of the above does not solve the problem, you need to replace the lamp. Let the lamp to cool for 30 minutes after unplugging. Use XL-2400 replacement lamp.
Remove the outside lamp cover.
Remove the lamp door.
Pullout the lamp
Hook a finger through the loop of the lamp handle and pull the handle upwards. Then pull the lamp straight out.
Mount the new lamp securely.
Reattach the lamp door. Turn the knob back to "CLOSE" and secure the cover.
Put the outside lamp cover back in its place.
or visit http://www.fixya.com/support/t2631342-need_replace_42_in_sony_wega_hdtv
The POWER/STANDBY (red) indicator flashes three times If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing) A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing) A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
remove front panel under screen, rove screws from lamp access panel cover. then remove the screws from the lamp assembly housing pull lamp housing straight out. install new lamp in the housing and slide the cartridge back into set replace screws and access panel cover.
