Question about HP PSC 2210 All-In-One InkJet Printer
Printer Problem I received an error message "Open Door" Clear carriage jam and press enter. I have done this. The carriage is stuck on the left of the printer, and won't budge. Please help me Thank You
  • 7 more comments
  • dalin Nov 07, 2007
    I received an error message "Open Door" Clear carriage jam and press enter. carriage is moving.But at the start of moving a suond is produces.And paper is not picking .when we open the door carriage moves from left to right and stops at left.
  • Anonymous Nov 19, 2007
    Carriage stuck in right corner
  • Anonymous Nov 20, 2007
    Clear carriage jam and press enter. I have done this but nothing happened. There is no paper stuck in printer
  • moyville Nov 20, 2007
    clear carriage jam and press enter
  • gerryhunter1 Apr 09, 2008
    HP 2210 says "Open Door, Clear carriage jam.
    Nothing happens
  • Nazih Raad Apr 23, 2008
    I put of the power,I opened the door,I tend the carriage 2 inch to the right,I put the power on ,after some time , I pressed enter, the carriage still go to the left
    how can I do to resolve the problem?
  • chissy May 30, 2008
    I have turned the printer off. moved the carriage and it still goes to the left and stop after i power it on.
  • hbsmkf Jan 10, 2009
    I was in the middle of a printing job when my printer starting amking a groaning noise and the printer cartridge tray stopped on the left side of the printer. I followed the directions for trouble shooting and the printer cartridge still will not move. I haved a HP PSC 2210 All- In- One.
    Please Help
  • bskap
    bskap Feb 14, 2009
    Had the same problem - but I can blame the cat, who reached inside and pulled off a thin plastic strap from behind the print heads, If I have to disassemble the printer to reattach it I think we're buying a new printer.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 544 Answers
Unplug the printer.
Move the carriage back to the home position, all the way right.
Plug back in the printer.
Posted on Jan 25, 2009
Turn off the computer,wait a few secs and turn it on.
Posted on Apr 28, 2007
SOURCE:
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
Feb 03, 2011 | Office Equipment & Supplies
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
476 people viewed this question
Clive
Clive
Thomas F. Schneider
