Question about Toshiba A105-S4054 Notebook
Urgent help there is a message in my computer saying that i do not have virtual memory ... what do i have to do...?
  • 2 more comments
  • Dale Barrett
    Dale Barrett May 11, 2010
    does the system say that you have no virtual memory or that the virtual memory is low and windows is going to increase the file size? If your getting a message then you may have a problem with your virtual memory folder in windows. Let me know what the message actually says and I
  • Dale Barrett
  • Dale Barrett
  • Dale Barrett
  • 93 Answers
Hi, Exists a formula that is that of the memory(report) ram base multiplies for 4 and this way the interval is placed in: I initiate + Panel of control + system + avanced + performance (setting) + Label Advanced + virtual memory (chance) + custom size (initial size = memory base) (Max. size = base memory x 4)
Posted on Jan 10, 2009
Even I have got more powerful PC than is required I am still getting the message about not enough of virtual memory.
Hello there,
Make sure that you restart your computer once in while. That usually frees up memory issues. If that still hasnt solved the problem, try these instructions to increase your virtual memory
I hope this has helped! Thumbs up are much appreciated.
May 08, 2011 | Empire Interactive Rowan's Battle of...
I can't download messenger in my computer tell me why?
its a result of low virtual memory of your computer.because it take longer time to download it.what you have to do is to increase your virtual memory or delete some file,if you know that you have enough virtual memory.
Jul 09, 2010 | Yahoo Messenger
Error message Low on virtual memory
Virtual Memory is used by the operating system as an extension to the Random Access Memory (RAM). When the RAM does not have enough space to accommodate the entire running program, the inactive parts of that program are temporarily shifted to the Virtual Memory. These parts are then swapped back into the RAM as and when needed. If the Virtual Memory set on your system is not enough for the computer operations to run smoothly, then you will get the "Virtual Memory Is Too Low" error message.If operating system is xp then this problem can be easily overcome by increasing the Virtual Memory size.This is how you can do it by following instrutions:
  1. Click on "Start" and then click on "Control Panel.
  2. Double-click on the "System" icon in the Control Panel.
  3. Click on the "Advanced" tab in the System Properties dialog box.
  4. Click on the "Settings" button below Performance.
  5. Click on the "Advanced" tab in the Performance Options dialog box.
  6. Click on the "Change" button below Virtual memory.
  7. Click on a drive_letter below "Drive [Volume Label]" in the Virtual Memory dialog box.
  8. Click on the "Custom size" option.
  9. Click in the "Initial size (MB)" text box and type a larger value (for example, 600).
  10. Click in the "Maximum size (MB)" text box, and type a larger value (for example, 1500).
  11. Click on the "Set" button. Similarly change the Virtual Memory on other drives.
  12. Click on "OK" and then restart your computer.
Apr 07, 2010 | Microsoft Windows XP Professional SP2
Virtual memory
The topic of Virtual Memory can be confusing for some folks, but I'll try to explain it as best I can (starting with the basics).
RAM, or, "Random Access Memory", exists in every computer. RAM are actually pieces of hardware (chips) and are used to store temporary data. The temporary data is then used for computation by the CPU (Central Processing Unit) at a later time.
So, for example: when you double click to view a movie file on your computer, it is first loaded into RAM (a chunk at a time), then moved to the CPU (Central Processing Unit) where it is processed and decoded, and eventually output to the screen and sound card. And voila, you have your movie.
RAM is also known as "Primary Memory". Comparatively, Virtual Memory (also known as Secondary Memory or Page Memory) is used in place of Primary Memory, but only if there is no Primary Memory available at the time.
Since Virtual Memory is stored on the hard drive, it is significantly slower than RAM; therefore, virtual memory usage should be avoided whenever possible. To compare: hard drive speeds are measured in Milliseconds (MS) where as RAM speeds are measured in Nanoseconds (NS). Generally speaking, the more RAM a computer has, the faster, or "more optimized" it is -- especially when switching between tasks.
If you are constantly getting the message that your system needs to increase Virtual Memory settings and you're not overworking the PC, I would suspect a memory leak. This is, of course, assuming that you haven't played with your virtual memory settings in Windows (it's best to leave it alone or restore to default).
look in Control Panel: System, Advanced, Performance, Settings, Advanced, Virtual Memory. I believe it's in a similar location in other versions of Windows.
May 11, 2009 | HP Compaq FS7600 17" CRT Monitor
Low virtual memory
You have to increase the Virtual memory.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
Mar 04, 2009 | Dell Inspiron 1300 Notebook
When I am playing XENO Assault II, it crashes and says virtual Memory error, I have a 256MB ATI Radeon X1300 Pro video card, and 2 gigs of memory. I was thinking about upgrading my processor to a Intel®...
Virtual memory is actually part of a computer's physical memory that comes in the form of memory chips or RAMs. So what right? Well, it is a necessary evil and in order for your computer to run numerous programs simultaneously (at the same time), it looks for areas of RAM (Random Access Memory) that is not currently being used and it copies files over to what is called page files. This is simply a process that allows RAM to free up space and subsequently load new or additional applications. This process is technically called thrashing and the result of it can cause the computer to react somewhat slower in its functions. However, when the computer hard drive (virtual memory) which is slower than the installed memory chips wants to correct itself, it has to constantly swap between the RAM and the hard disk drive.
What Causes These Windows Out of Virtual Memory Error Messages?
  1. The first and foremost probability is that the Windows operating platform page file maximum file size - is too small. You may think your system has a large amount of virtual memory (RAM) because the person that sold you the computer told you so. Well, this may or may not be the actuality if page files are set too low and you are getting error messages. Obviously if you are getting an error message page files are being maxed out and something needs to be changed to correct the situation.
  2. There could have been a power failure or, you shut your computer off incorrectly which led to a file or files becoming corrupted and this subsequent virtual memory message beginning to haunt you. So the two lessons learned here is to have a back-up source of power and, to always get into the practice of properly shutting down Windows via the start button where it reads "Turn off computer" in lieu of simply hitting the power off button.
Okay, so now that you have an idea of what virtual memory is, system thrashing and how it suddenly became an irritant error message, what can be done to make things right in your Windows operating platform?
Realize that although Windows automatically sets both minimum (the amount of RAM installed on your PC + 300 MB) and maximum (3 times the amount of installed RAM) to its page file sizes if you do get that virtual memory error message - then you can do the following steps to increase these minimum and maximum page file sizes;
Re-Setting Windows 2000 virtual page file sizes
  1. Right-click My Computer , and than click Properties
  2. Within System Properties menu box, click Advanced
  3. Click Performance Options . Within this pane (Virtual Memory), click Change to increase the paging file. Take special note that your Windows 2000 minimal value requires at least 126 MB for debugging.
  4. After you change (increase) the setting, click Set, and than click OK to the following message you will receive;
  5. The changes you have made require you to restart your computer before they can take effect.
  6. Click OK to close the Performance Options menu, and than click OK to close the Systems Properties menu.
  7. When prompted to restart your computer, simply respond to Yes
Re-Setting Windows XP virtual page file sizes
  1. Click Start , right click My Computer, and than click Properties
  2. In the System Properties menu box, click the Advanced tab.
  3. In the Performance menu, click Settings
  4. In the Performance Options menu, click upon the Advanced tab.
  5. In the Virtual Memory menu, click Change
  6. Change the Initial and Maximum Value Sizes to a higher value, click Set and than click OK
  7. Click OK to close Performance Options menu, and finally OK to close the Systems Properties menu
Re-Setting Windows Vista virtual page file sizes .
  1. Click on the Start button, click Control Panel, click System and Maintenance, and then click System
  2. In the left pane, click Advanced system settings. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. On the Advanced menu, under Performance, click Settings
  4. Click the Advanced tab, and then, under Virtual memory menu, click Change
  5. Clear the Automatically manage paging file size for all drives check box.
  6. Under Drive [Volume Label] , click the drive that contains the paging file you want to change.
A CPU upgrade would be a good idea, the core 2 duo is a superb processor.
Also a bit more ram perhaps another gig or two? and maybe a 512mb graphics cards would be good for gaming.
perhaps a better power supply too as E520 was not really designed for gaming.
Feb 24, 2009 | Dell Dimension E520 PC Desktop
"out of memory" message then printing to screen and printer
You would need to increase your virtual memory and restart your computer. Windows XP:
Right click my computer, go to properties
Select the advanced tab
Click advanced tab
Click change under virtual memory.
Set virtual memory 1500 to 4000
click set and apply, ok
If the memory is set higher, select a higher number.
This should resolve your issue.
Feb 06, 2009 | Microsoft Works 8.0 for PC
Check your virtual memory settings. Go to start. Right click My computer. Click properties. Click Advanced.
Click 'Settings' under Performance. Click Advanced. Click 'change' under Virtual memory. Click custom size and enter 2000 under minimum and 4000 under maximum. Click apply. Close all the windows, then restart your computer.
Jan 02, 2009 | Acer Aspire 1640Z Notebook
I need to increase virtual memory
I don't wish to sound rude but if you don't know how to do this, you prolly should just let windows continue managing it. A few wrong keystrokes can have major repurcussions
Jul 15, 2008 | Computers & Internet
Toshiba A105-S4054 Notebook Logo
70 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
