Question about Nintendo DS Lite Console
Volume is not working
I have a nintendo ds lite and the volume is very very low, you can hear it with headphones but it is extremely low and when there are no headphones plugged in, forget it! Can somebody please help me??? What could be causing this and can it be fixed?? I don't want to have to purchase another one......
  • 34 Answers
You may have something wrong with the speakers themselves. The unit might need to be replaced or repaired.
Posted on Dec 27, 2008
My nintendo ds lite as no sound but it works fine with head phones in can you help me please
It works well with the headphones?
Well.. That's odd.
Check the left side of your DS volume.
there's a toggle button that says
- VOL +
toggle it rightly,as the volume will get higher. Maybe your headphones can adjust the volume. So either contact www.nintendo.com or call Nintendo 1-800-255-3700. Or if you like your DS with headphones,keep it that way.
Mar 06, 2010 | Nintendo DS Lite Console
My Nintendo DS microphone broke for no reason and my sister's also broke for no reason...What should I do?
Go thru these steps to see if its a configuration issue with the DS:
Restart your Nintendo DS. Sometimes a quick restart will fix your microphone problem. Do this on both systems. All the steps that I mention, do them on both systems.
Check whether your microphone volume is up. Access this feature through the DS menu. If the microphone’s volume is down, it will not receive any sound.
Make sure the volume on your Nintendo DS is up. If your speakers are off, you won't hear whether your microphone works.
If these steps do not correct the problem, then systems will need to be serviced cause the main board would be bad at that point.
Dec 10, 2009 | Nintendo DS Lite Console
The sound of my new nintendo ds lite is very quit
Hi Susan,
It is possible that the volume button has slipped off of it's setting on the switch below it and that while you think you have turned the volume up it is only partially turned up.
If it is a new DS bring it back to the shop (12 month warranty on new DS systems) they are obliged to repair or replace the DS.
Sep 15, 2009 | Nintendo DS Lite Console
My nintendo ds microphone wont work how do i get it working
You have a defective connector assembly on the front of the DS Lite (the assembly where you connector an external headphone and microphone). Replace it and your done!
Apr 19, 2009 | Nintendo DS Lite
Nintendo DS Sound Not Working
You might have a wire of some sort out of place as you suggested. I would not try to take of any part of the DS, because if you hit something wrong, or can't get it back together, them you may have to get a new DS. Did your daughter spill something on her DS, or drop it?
If you don't know what happened to the DS, then it may be the companies problem. if your daughter recently got the DS, then you can return it to the store, or send a direct complaint to the company. Even if she got it a long time ago, if it suddenly starts not working at full efficiancy, send it back to nintendo. If you still have the repicet, then send back to the store and tell them what happened.
Hope it helps~
Jan 11, 2009 | Nintendo DS Lite Console
I droped the nds and now i cant turn it on. the slidey thing doesnt go back in to the proper place and it just stays in place just like the volume button.....how do i fix it and its also cracked near the...
Your on/off switch is broken and must be replaced by a Nintendo repair Service. Also if I read it correctly your DS Lite housing is broken and also must be replaced.
Nov 25, 2008 | Nintendo DS Lite Console
Microphone not working
Yea where IN the DS Lite menu?
Sep 06, 2008 | Nintendo DS Lite Console
Nintendo Ds Sound Problem
This option is only suitable for out of warranty devices as opening it violates the warranty.
Open the device and look for loosen or unplugged cables in the main bottom board. Usually this dont happen though opening and closing the unit whe it was not assembled correctly may cause the wires and conductors to loosen or even worst to get cut by the moving parts. So as you say nothing else was done with the unit between plays that is the only explanation I can guess from it.
The headset plug is in the bottom main board so no cables are required to get the audio there, though as the speakers are in the top, these require some flexible cables and conductors running throught the hinges to the top part.
Hope to this info to be helpful: How to dismantle an Original Nintendo DS.
If yours is the NDS Lite, just find this video in youtube:
"Disassembling Nintendo DS Lite"
Good Luck...
Nov 29, 2007 | Nintendo DS Lite Console
Stylus tip stuck in headphone jack(no sound!)
Yes, here is a guide to dismantle an original Nintendo DS:
How to dismantle a Nintendo DS.
And after opening it you may need to replace or try to repair the audio plug. In case you cant, then you must take it out (desoldering it with the stuck stylus tip and the mute switch, which is embeded in the headphone jack) and you can have your audio back.
As the audio switch and the jack only work to mute the speakers audio usually when you plug a headphone then you can lack of it almost all times.
Nov 15, 2007 | Nintendo DS Console
SOUND ON MY DS
replace the ribbon to the top screen. Look for "ds lite top screen" on ebay
Oct 22, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
266 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
