First off, you can download a PDF version of the manual from the manufacturer at:
http://www.vivitar.com/files_products/13/VC8025%20User%20Manual.pdf
If you don't have a PDF viewer, you can download one from:
http://www.foxitsoftware.com/pdf/reader/ (just click download under the free version)
For your convenience I've pasted the relevant information about charging the batteries from the above manual:
Please charge the battery as below 2 methods:
A. Charge with USB cable
Insert the lithium battery into your camera correctly, and connect your camera to computer with USB cable.
The red LED of camera will be light on indicating that your camera is in charging status, the LED willbe off when charge full.
B. Charge with supplied charger
Your camera is supplied a compatible charger for you, you are only required to put the battery into charger and charge the lithium battery directly from electrical outlet
Please leave feedback if this was helpful. Thanks.
The camera did not come with a charger. but it did come with a usb cable. Does it charge through that? If so why isnt my camera charging? Where can i find another charger?
Where can you get usb cable?
I have the same problem. The USB does not charge it. The USB that comes with it is for PC connection. I tried Radio Shack, but can't find the right mini-usb power cable to work.
