Question about Dell Inspiron 1100 Notebook
Dell Inspiron 1100 won't read 512 Meg ram.
I tried 2 different chip manufacturers - 1 that absolutely guarantees that their chips work. I know the machine worked fine with the 256 meg chip that was in it. I put that in a coworkers machine and no longer have it. The 512's beep 3 times then a pause and 1 more beep. Then the lights flash at the top of the machine. The chip folks say to clear the cmos but I don't have any memory that works and don't know how to do this otherwise. Any advice would be great. I can't get a 256 chip anywhere locally that will work.
  • 4 more comments
  • dsteigman Dec 27, 2008
    Didn't address what was stated.
    One set of chips is pc2100 (Original speed in Dell) The other is PC2700 that slows down to pc2100. I think my machine doesn't understand the 512 meg as it has no video with these chips and just beeps.
  • acgr4me Jan 03, 2009
    I have the same problem. I tried to install a 512 that is the same specifications that dell recommends and it is doing the same thing mentioned above.
  • tom0419 Jan 09, 2009
    I have the same problem. Can't add anything other than that I tried to flash the bios and the utility from Dell says something about my system being unsupported and won't let me continue.
  • memechose Jan 13, 2009
    I went to the Dell site to flash the BIOS. Can't do it. "System Unsupported." And I have a 512 meg chip to put in, haven't tried yet. Interesting.
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    What speed are the chips you are trying to put in? Dell is very picky about the speed sometimes. For instance, this model will only work with PC 2700 chips.
Explanation of Dell Inspiron 1100 Memory Upgrade Problem
My Dell Inspiron 1100 had one 512 MB card, and I wanted to buy a second such card to upgrade it to the maximum memory capacity of 1 GB. I installed a 512 MB card from crucial.com that matched all the specs for this machine. When I put it in the DIMM B slot with the old 512 MB card in DIMM A, the system would boot but the display was screwed up. Thinking there might be something wrong with the new card, I decided to try only one card at a time. So I removed the old (working) card and moved the new card to DIMM A. In this configuration, it wouldn't boot. Instead it flashed two of the three lights next to the power button for 5 seconds and then powered itself down.
Thinking the card was defective, I returned it for a replacement, but the next card behaved the same. I went through 4 more cards. All of them failed the same way. One of them was even manufactured by Dell! Yet my old card worked fine, so I knew the problem was related to the memory card and not a problem elsewhere in the laptop.
I Googled for others who had encountered the problem but nobody had an explanation for why the problem occurs. I have now figured out why some memory cards fail in the Dell Inspiron 1100 and others work.
To see if a memory card will or won't work in Dell's Inspiron 1100 count how many chips are on the card. Divide the card's memory capacity by the number of chips. If the result is more than 32 MB, you're screwed! The problem is the boneheads in Bangalore that Dell outsourced the hardware design of the Inspiron 1100 to. They assumed that the maximum memory in any one chip on the card would be 32 MB.
By releasing a piece of hardware with this limitation, they created a situation where a memory card can match all the specs (DDR PC2100, 200 pin SODIMM, CL=2.5, Unbuffered, Non-ECC) and still be incompatible because with this idiot hardware design, maximum memory per chip on the card is an unpublicized spec. that will prevent the machine from working if you exceed the 32 MB limit!
If you have a 512 MB card with 8 chips on it, it will never work. The only ones that do work are the ones with 16 chips.
The hardware design is a mess in other respects as well. See http://www.lieffcabraser.com/dell-inspiron-3.htm for more info.
Posted on Jul 10, 2009
I had the same problem. I tried several brands of memory unsuccessfully, though they all guaranteed that their products would work with my machine. Finally, my brother (who works in IT) recommended that I go through The Upgrade Place (http://www.theupgradeplace.com/). Great price - less than half of what Dell charges - and the memory worked immediately upon installation.
When I told them that I had a Dell Inspiron 1100 laptop, they said that my PC required proprietary memory (which is true). I paid with a credit card and received the part two days later.
Good luck,
Jay DeKing
Posted on Jan 26, 2009
I purchased 2 512 banks of memory from Dell. They assured me they would work in my inspiron 1100. It only took me 15 minutes to purchase the new ram. When it arrived, I installed, and the notebook would not boot up. I tried every combination I could think of (1 new, 2 new, 1 new and 1 old) and nothing would work. I ran across this web site and forum and read the comment from Jay Deking. I called the upgrade place and talked with Mary. She was well aware of the inspiron 1100 problem. Says it takes a sepcial memory. Incidentally, there were not 16 chips on each bank either. It took me 1 1/2 hours to get Dell to let me return the memory. I ordered from the upgrade place and the memory arrived today. I didn't flash the BIOS either. Inserted the new memory and walla. Worked like a champ.
Posted on Jan 23, 2010
How to upgrade ram on inspiron mini 1012
Anonymous,
Click the link below to download the online service manual. The manual will provide information on how to add/remove parts within your computer.
Inspiron 1012 Online Manuals
http://dell.to/1JCCann
Below are the memory specs for this system.
Memory
Min/Max Memory 512 MB /2 GB Memory Type DDR2-800 MHz Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 23, 2015 | Dell Computers & Internet
RAM chip sets
It is OK to mix chip (SODIMM) capacities in the 2 slots in your notebook.
The best system performance will be when you have 2 x 512MB but for now if you install 1 x 512MB, you could even leave the old chip in the other slot, it'll be fine.
Oct 19, 2007 | IBM ThinkPad R31 2656 Notebook
I'm trying to update my Inspiron 1100 to (2) 512mb PC2700 DDR 333Mhz SODIMMs (per Crucial) with no luck. Presently have (2) 12mbk PC2100 DDR 266Mhz that work. I have updated the BIOS to A32. As I am seeing...
the system mb doesnt support the 333mhz click speed. You need to get memory that 133 - 266 mhz's.. other than that you will need to upgrade the mb to support 333 mhz,, which sadly you cant get 1 to fit in that unit.. another thing to remember is that you cant mix two different clock speeds .. for example 133 and a 266 mhz..
1 thing you can try is to overclock the system..
1.) enter the bios (press the designated key shown on the boot screen to enter cmos or bios settings)..
2.) change the Clock speed to 333..
3.) save and exit..
4.) shutdown
5) insert 512mb sticks
turn on and hope for the best..
Whats strange enough is that the overclocking seems to work on some and not for others,, I think it has a lot to do with the chipset and the brand.. not sure..
let me know if it works or maybe we can try something else,, I'll post again based on your reply.
Sep 14, 2010 | Dell Inspiron 1100 Notebook
Is there any way to configure the poweredge 6300 to boot with just 2 EDO memory cards ? I am trying to install redhat 5.2 (for historical reasons) and the linux kernel isnt compatible with 4x256MB EDO...
From the manual, it says minimum of 128 meg to work, so I assume the problem is with the Linux installation. If the Linux is expecting 512 and does not see it, it probably won't work. Being as you have 4 chips installed, have you tried removing two of the ram chips?
Dec 24, 2017 | Dell PowerEdge 6300 Server
Upgrading ram on laptop, new ram not recognized.
remove the bios battery for a few seconds...and place it back on ...this will make it see the new ram memory modules...if you are sure they are compatible ..they will work .....in fact ..the ddr1 333 512 M is more that compatible with your system and it will work after you remove the battery ...\ my recommendation is to reinstall a clean operation system after you boot up ...and format the C partition too...this have to be done after memory changes to get the max out of them ..
Nov 13, 2009 | Dell Inspiron 1100 Notebook
Dell memory issues
if the ram chips are not compatible you need to get ones that are.
your unit supports this type
Memory type 1.8-V SODIMM DDR-2
Minimum memory 256 MB
Maximum memory 2 GB
you can still put 2 gigs in it but it has to be the above type
here is a link to a manual
http://support.dell.com/support/edocs/systems/ins6000/en/om/D5181bk5.pdf
and are you surprised that they say it will work. Thats why you have techs here, because the manufacturers hire people that don;t know from adam. same thing with apple. the techs you call are usless. Return your ram chips to dell and have them send you the ones that work.
Jun 02, 2009 | Dell Inspiron 6000 Notebook
Ram upgrade
you need to make sure the ram is compatable, it looks like an old machine so chances are its using sdram pc100,
check the ram your trying to make sure its not pc133. let me know what each piece of ram has on its sticker
Mar 23, 2009 | Dell OptiPlex GX200 PC Desktop
Toshiba Satellite Pro M15-S405 Memory upgrade problem
This usually happens when the laptop is not able to take more then a certain amount of memory, as the system BIOS does not support higher. By saying ACPI as the blue screen, that tells me that the power subsystem does not 'like' having more then 512MB of RAM. I am 95% sure this is your BIOS because of that information. Check and see if you can find a BIOS upgrade for your computer model, and that might fix the issue, if an update is available.
Jan 21, 2009 | Toshiba Satellite Pro M15-S405 Notebook
Sdram capacity
its that 512 mb total capacity for your computer memory?? if so read this:
To find the total amount of RAM that can be added , subtract the amount of RAM currently in the computer from the maximum amount of memory the computer can hold. For example, a computer has 256 MB of RAM. If the maximum amount of memory the computer can hold is 512 MB, then 256 MB is the amount of RAM that can be added. this info from the HP website , to find out more , go to http://www.hp.com/support , enter the model number , and look for more information about your computer specs, hope this helps , please rate & thanks AJ
May 24, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
BIOS detects only 128 MB instead of 1024 MB
Does the motherboard support 1 gig ram modules? what kkind of motherboard/video card do you have? sometimes video card onboard ram can ofset motherboard ram, especially with ati video cards.
Mar 17, 2008 | PC Chips M870 Motherboard
Dell Inspiron 1100 Notebook Logo
841 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
