I got a system form my school with no HDD. I got a standard IDE interface seagate baracuda 7200 rpm 160 GB HDD. I tried booting the system with a boot CD. But the error it is showing is CDBOOT: Memory overflow error. What can be the problem?
  • Thomas F. Schneider May 11, 2010
    Did you format the drive first? How about the setup,did you go through the setup routine and sellect and save the default settings?
  • 837 Answers
If you have both a CD drive & a DVD drive, make sure you are using the 1st physical device (according to physical hookup).
Or if you do have both, then try booting with CD in other drive
Posted on Dec 27, 2008
I have a 4 channel Sunluxy H.264 Network DVR, I have fitted a 300gb HDD but although the system is working and I get the 4 cameras on screen the message I keep getting on boot up is HDD not found
Guys this one stumped me for some time, here is my solution that worked like a dream
1. plug the hard drive you are using into a pc and check the hard drive is recognise and works.
2. Delete all partitions
3. ensure it has a 8 bit cache buffer!! This is the most important one. That means the system only supports older hard drives. I got 2 second hand ones from the local pc store for $50. See the list of hard drives that are know to work below.
MANUFACTURER MODEL CAPACITY ROTATION
ST3320613AS 320GB 7200 rpm
ST33500320AS 500GB 7200 rpm
ST3750330AS 750GB 7200 rpm
Seagate
ST31000340AS 1000GB 7200 rpm
WD3200AAKS 320GB 7200 rpm
WD5000AACS 500GB 7200 rpm
WD6400AAKS 640GB 7200 rpm
WD7500AAKS 750GB 7200 rpm
WD10EADS 1TB 7200 rpm
WD15EADS 1.5TB 7200 rpm
WD
WD20EADS 2TB 7200 rpm
Maxtor STM3500320AS 500GB 7200 rpm
STM3750330AS 750GB 7200 rpm
HITACHI HDT725032VLA360 320GB 7200 rpm
HDS721010KLA330 1000GB 7200 rpm
FYI for some reason the person I bought this off online "Ebay" had no idea how to support and I could not get support from their web site as they email they give just bounces back.
Cheers.
Jan 11, 2013 | Home Security
Will a seagate pipeline 500 gb hdd from a lorax dvr work in a pc?
Yes it will work in a PC. All 3.5" sata drives are standardized. Connect it via a SATA cable and you will need to format the drive to work with windows. To do this:
1) Right-click on my computer
2) Click on "Manage"
3) Click yes to allow if any dialogue's pop up.
4) When the menu pops up look at the left side menu and click on "Disk Management"
5) Look for your drive in the list when it populates. It should show a 500GB drive and it may show an error on it since it is not formatted for windows.
6) Be sure this is the correct drive you want to use! Formatting it will erase EVERYTHING on the drive.
7) Right click on the drive in the bottom list and select the Format option.
8) Give it whatever name you want, make sure the format is set to NTFS, check the box for quick format.
9) Let it format, this should only take a few minutes. After that it will show up as a blank drive in My Computer!
Oct 25, 2012 | Seagate Technology 500GB Pipeline HD SATA...
Hard drive capacity
It's 10.2 GB
Maxtor 10.2 GB UDMA/66 7200 RPM IDE Hard Drive
General Features:
10.2 GB formatted capacity
UDMA/66
7200 RPM spindle speed
2 MB buffer
9.0 ms average access time
4.17 ms average latency
E-IDE/ATAPI interface
3.5-inch form factor
Notes:
Drive only
Maxtor model #: 51024U2
Additional Information:
Product Requirements
IDE controller
IDE cable
Available 3.5-inch drive bay
Available 4-pin power connector
Jun 28, 2012 | Maxtor Computers & Internet
Code da620000 what is capacity
It's 10.2 GB
General Features:
UDMA/66
2 MB buffer
Notes:
Drive only
Product Requirements...
IDE controller
IDE cable
My seagate barracuda 7200 80 gb having s/n: 9qz0c2zz is not recognize by my computer im using windows xp operating system
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Sep 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
Seagate 750GB usb HDD asks to format,when opening by double click
The disk is either damaged or the USB interface is damaged.
1) You could try opening the external case and connect the disk to your computer directly (Using IDE/S-ATA cables)
2) Format the HD and use data recovery software/service.
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Help
An external USB drive consists of tow parts:
a hard drive (usually a standard IDE or SATA drive), and
an enclosure
The enclosure is the box containing the drive. It also includes an interface to convert the data from the IDE or SATA interface on the drive to a USB (2) signal. Some enclosures include and internal power supply. The Freeagent has the power supply externally.
Hope that's what you mean.
Sep 08, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
3.5" Dynex USB 2.0 External Enclosure + Seagate Barracuda 7200 RPM 500 GB HDD problem with computer recognizing the HDD and the enclosure
 If your running XP , go to control panal , Admin tools>Computer Management >Storage > Disk Management . Look for it there . If its there see if it says what file system . If none format it . If it isnt there then chack the jumper on the hard drive it self . It should be set to master or cable select .
Sep 03, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Computers & Internet Logo
157 people viewed this question
Alun Cox
David Payne
David Payne
