Question about Olympus WS-311M Digital Voice Recorder
OLYMPUS Digital voice recorder ws-311m memory is full despite all folders being deleted
I have deleted all files and tried to record but the message I get is Memory Full
    New Friend:
I had the same problem on a WS 311 and this worked for me as well, thanks so much!
Posted on Sep 11, 2014
SOURCE:
SOURCE: "full" message
I had the same problem; see earlier post about record times. The "format" solution worked for me.
Posted on Dec 31, 2007
SOURCE: WS-110 memory full but no files
well, i resolved this myself by going to the sub-menu, and formatting the recorder to its original state. thankfully, i backed up the files on my computer first, so i didn't lose any data, although i did have to go in and re-set all my preferences on the recorder.
lesson: don't MOVE files from recorder to computer. copy them instead, and do the actual erasing from the physical recorder itself.
i don't know if this was the most elegant solution, but at least it did get my recorder up and running again. i'd love to hear if there is a better resolution out there.
Posted on Nov 29, 2008
bestdarngood
  • 3037 Answers
SOURCE: Olympus DS-30 recorder: memory is full but there are no files to delete
1.Press the FOLDER button to choose a folder.
Every time the FOLDER button is pressed, it cycles through folders and the List display will appear (+P20).
Press the + or button to choose the file you want to erase.
Press the ERASE button. The “Cancel” indicator flashes.
Press the + button to choose “Erase”.
5
Press the OK button. The display changes to “File Erase!” and erasing will start. “Erase Done” is displayed when the file is erased. File numbers will be reassigned automatically
Posted on Apr 04, 2008
SOURCE: Hi! My olympus voice recorder is
if you have a menu option, go in and perhaps even into sub-menu (I have a WS210S recorder. I found the format option and reformatted it. Now it works
Posted on May 09, 2010
  • 1218 Answers
SOURCE: my Olympus digital voice recorder
Check your operators manual....amount of recording time is dependent on "quality" mode of recoring.
If you have lost your manual go to www.olympusamerica.com
Posted on Oct 10, 2010
Olympus WS-802 will not allow me to record, gives "memory full" message
try scanning it for viruses and errors. you can also try to format the device
May 26, 2014 | Olympus WS-802 Digital Voice Recorder
My 5800musicexpress phone momery is full so how can delete my phone momery
Hello there,
If your phone should come up with the message 'memory full' it simply means there are too many files on the phones memory and requires you to delete some so its memory space will be free.
shortcut To delete the files from your phone memory i quite simple. All you have to do is try to snap a picture using the camera, it will tell you the phones memory is full and ask if you want to delete some files, then it will show you the files to delete from, either picture files, videos or songs, then you navigate to the file you want to delete and select and delete then.
Then there will be free space on the phones memory.
Thank you for using fixya.
caseytech
Jun 27, 2011 | Cell Phones
I canT recieve and send a messaage because my phone says that ' memory full, delete some data first" and i didn"t know how to delete that said data.
you need to delete some of your texts also go to your setting and click auto delete on it will delete the last one everytime you fill up your box so you will never run out of space.
Feb 06, 2011 | Nokia N70 Cellular Phone
It will not let me add videos any more and my memory is not full i still have space
The GoGear allows you to make voice or FM radio recordings and saves the recordings to the internal memory. The internal memory is limited and the GoGear may show the message "Memory Full" when trying to save recordings. When you receive this message, plug the device into the computer and delete any extraneous files or files you no longer want to keep on your device. This will free up memory so you can save more recordings or place additional music files on the GoGear.
I recommend you to reset your device If the solution above didn't solve the problem :.
Take a small object like a paper clip and use the edge to stick into the small reset button on the side next to the usb connection .
Or Try [ power + volume up button & hold for 3 seconds ]
Your mp3 player has two types of memory in it. The hard drive (where the music and photos are stored) and the Ram (where the firmware and active files are temporarily hosted).
When you soft reset your GoGear, it flushes the RAM, and restarts the operating system (which is why the contents of the hard drive does not get erased).
You can "hard reset" the device, by formatting the drive and resetting it to factory defaults in the Settings field. This is the closest thing to a "hard reset: that's available with an HD based MP3 player.
PLEASE DON'T FORGET TO RATE !
Apr 18, 2010 | Philips GOGEAR SA6045 MP3 Player
I just deleted (remotely from my mac) all the files in Folder A of my Olympus DS -40, b/c I'd gotten a memory full message. Even though it shows no files in Folder A, it still says memory full.
I found the answer on this site: http://www.olympusamerica.com/cpg_section/cpg_support_faqs.asp?id=1126#22 I held down the menu button--got to the sub menu and restored it to the original default setting. It cleared everything and now I can record tons again. Note for future--don't delete on your mac--only delete the files on your dvr to save you the trouble of having to do this.
Nov 25, 2009 | Olympus Audio Players & Recorders
How to delete some data in my nokia n73?
Try to delete songs or setups that you might have kept in the phone memory (c:) drive of your phone !
and make sure no application is running in background before opening LifeBlog.
For better viewing of the files kept in the phone memory use X-PLORER software !
It rockx.
Thanks
Apr 09, 2009 | Nokia N73 Cellular Phone
I have a problem with memory (Memory Full. Please delete some msg
you have change your memory dop memory card memory and your problem is solve
Apr 07, 2009 | Motorola Mobility ROKR E8 Cellular Phone
"Memory Full" message flashes, even though all files are deleted
Use the reformat option in the menu to completely erase the memory.
Oct 15, 2008 | Olympus DS-2300 Digital Voice Recorder
Sounds - memory full error
check and clear all hidden files...
Apr 03, 2008 | LG VX5200 Cellular Phone
Recorder says "PLEASE DOWNLOAD FILES," but there are no files to download
The DS-2 has a format option in the menu under submenu. After you choose start you will see a progress bar and it should return to full record time. Use on a MAC seems to cause the reduced record time more often than on a PC.
Dec 11, 2007 | Olympus DS-2 Digital Voice Recorder
Olympus WS-311M  Digital Voice Recorder Logo
519 people viewed this question
Top Olympus Audio Players & Recorders Experts
leoz
Level 1 Expert
Perry Mellott
Perry Mellott
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
