Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Bin control can my ice machine work without the bin control?
    Problem Solver:
  • 7 Answers
Only if the switch is jumped. The machine would run constantly and will freeze up if not turned off before filling up,.
Posted on Feb 05, 2009
    Scholar:
  • 39 Answers
The bin control shuts it off when the ice bin is full. Without a bin control it should keep making ice and never stop.
Posted on Jan 19, 2009
Hoshizaki ice machine will not power up
with not model or serial numbers, I can only suggest that it may very well be the "bin stat". This is a thermostat that has a sensing bulb that is in the bin and senses the ice when it touches it to shut down the machine. If this is bad, no power goes to the control board. Try jumping this out with a jumper wire and see if the machine comes on.
Dec 18, 2016 | Hoshizaki Freezers
Why did my hoshizaki ice machine stopped making ice?
bin stat is what is used to shut machine down. if it goes bad in any way, no power will go to the control board. Start there.
Aug 11, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki km-900mah ice maker won't start the freeze process
cycle is, fill cycle for 1 minute first. If there is not water entering the unit when first turned on, look for that issue. Water turned off, water valve not working or some restriction, clogged water filters, etc. That is got to happen first. Don't over look the bin stat being bad. Nothing happens if teh bin stat is bad. It sends voltage to the control board that runs the unit.
Jul 28, 2012 | Hoshizaki Freezer Commercial Ice Machines...
No power. checked fuse box. Tried reset. no luck.
If you are sure you have power to the wiring of the machine, check the bin control. If it's frozen in the open position (electrically) or the capillary tube that connects it to the sensing bulb that sets inside the storage bin is cracked, it will keep the machine off.
Jun 18, 2011 | Hoshizaki Freezer Commercial Ice Machines...
The ice maker does not stop making ice when the bin is full
dear sir/madam
please make sure first your freezer,s defrost mode selecter set on auto mode or it,s set on auto defrosting mode. if it.s or freezer making continuously ice in ice bin then defrosting control device or temperature controller is not working for repair it please contact to your maintenance personnel for replace it .i hope after that it will work properly.
hope answer the question
thank you
please vote!
Aug 24, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Hoshizaki ice maker am-50bae . Made ice regularily--- filled ice bin half way...next day-- all ice melted away with no more new ice? next day shut off for 3 hours now o new ice.
make a few quick checks. If there are water filters on the system, be sure they are not restricked. Could be clogged. Next, check the bin stat. It usually is mounted in the ice bin. If it breaks or goes bad, it shuts down the machine. Start there and let me know if I can be of any further help.
May 19, 2010 | Hoshizaki Freezer Commercial Ice Machines...
ICE MAKER WILL NOT MAKE ICE
Check for power supplied to unit.
Check that the bin stat has not been broken and has no ice sitting on it. If the bin stat is clean and doesn't appear to be broken, you can attempt to jump out the bin stat and see if the machine comes on.
If the machine comes on, replace the bin stat. If the machine does not come on and you have shut the machine off and back on, then you will need to call for service.
The check valve is a common issue with the Hoshi line-up. If you know where this is, take it apart, clean it, and re-install it.
Jan 08, 2010 | Hoshizaki Freezer Commercial Ice Machines...
My ice machine does not make enough ice
Check the water filters first. Then check the condenser coils for dust and dirt. Determine which way the air goes thru the condenser coils and check on the side the air goes into. There are coil cleaning sprays that work good. If it is still slow, it may need gas. That will require a service call from a technician.
May 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
292 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
0duro
Level 1 Expert
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
