Question about Compaq Presario M2000 Notebook
I have a Dell Inspiron 9300
I've got a thick white line in the middle of the screen. How can I remove that white thick line?
    Novelist:
  • 126 Answers
If there is white line in the middle of the screen then first of all turn off the laptop and disconnect the ac adaptor and take out the battery and press and hold down the power button without the power cord and the battery for one minute and then turn on the computer with power cord and the battery and then check it out and still after that if u get it then check it out with the external monitor and if u get a good display in the external monitor then replace the lcd,but make sure that the screen is not broken from inside which u cannot touch and feel it.and if u get a good display in the external monitor then definately replace the lcd screen....good luck
thanks
Posted on Jan 21, 2009
White lines in my laptop's screen
its your screen problem of your laptop pls change it,
Apr 15, 2010 | Dell Inspiron 6400 Notebook
Got line on the screen on my dell inspiron 9300 wat can i do
This is caused by dead pixels, the only fix is to replace the screen.
Jan 07, 2010 | Dell Inspiron 9300 NV41 256MB Video Board...
When I start my Inspiron 9300 the Dell symbol appears andI get a dark scree with a short line near the top left of the screen. Help I tried removing the battery and restarting.
This is the dos screen before start up. Normally your motherboard and cpu go through a quick self test and then your hard drive and os start up. What is happening with yours is it is not passing its self test. What you should do is remove and re-seat the memory cards and hard drive in your computer and then try and start it up. If this does not work it means either *********** board or your cpu have failed.
Nov 12, 2009 | Dell Inspiron 9300 Notebook
Numerous, bright, multi-colored vertical lines on 9300 screen
Try taking out the Ram memory first one stick at a time. Sometimes when Ram goes bad or overheats, it first affects the display. If that is not the issue, here is the link to your service manual.
http://support.dell.com/support/edocs/systems/ins9300/sm/index.htm
Oct 09, 2009 | Dell Inspiron 9300 PC Notebook
I bought a Dell Inspiron 9300 in July of 2005, a thick white vertical line appeared on the LCD two days ago. Given the fact that there are too many custumers that acquired this model in the past, and have...
hi
this problem is very common with your model.
this problem somtimes occur due to malfunctioning of this display module.
dell takes the responsibility of all such manuacturing defects.
call the customer care and they will replace your display or motherboard whichever is required for free if you system is under warranty.
if you find the solution helpful plz rate me carefully.
Jul 02, 2009 | Dell Inspiron 9300 Notebook
I have laptop dell inspiron 9300 it 17 sreen , it has a white verticle white line about on the middle about inche 1 1/8 wide hohow to fix? thank you...very much
Unfortunately, there is no way to fix it.
This line called "Tab Separation" of LCD.
You'll need whole new LCD display.
Very very common problem.
Apr 29, 2009 | HP Pavilion zd8000 Notebook
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Pixal loss lines on screen???????????
Sometimes this is a sign of the monitor ribbon disconnecting from your motherboard. If you feel confident in taking your computer apart, you can reseat the cable and see if this improves. Usually pixels die individually, lines tend to be a video card error.
May 08, 2008 | Dell Inspiron 9300 Notebook
Compaq Presario M2000 Notebook Logo
126 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
