Question about Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore Dishwasher 665.17979301 - Reset Sequence?
Hi, My Kenmore Dishwaser 665.17979301 will not start. The cancel/drain button is the only thing that is working and it makes a noise as if trying to do something but that can't be good. I few years back it would not start and I tried a reset sequence that I found online and that worked but I can't find it again. Would appreciate if you know it or can tell who I can get it from. I can't find anything in my manual. Thanks. Sue
  • 2 more comments
  • Anonymous Dec 01, 2007
    I have the same problem
  • buckep Dec 04, 2007
    Does anyone know the reset sequence to reset the Kenmore 24in dishwasher?
  • carolb1 Mar 28, 2008
    Nothing lights up/ power supply good but dishawaser will not run
  • washer blues May 11, 2010
    Yeah, I have a similar problem. I tried pushing the Sani-Rinse and Air Dry buttons back and forth a number of times. Didn't help.
    At first I thought the lock-on had accidently been engaged, but disengaging the "child lock" doesn't help. The lock-on light comes back on and sometimes blinks rapidly. I"ve counted around 7 rapid blinks at times and 3 rapid blinks at other times--in case that makes a difference. The control panel doesn't work--in other words, the dishwasher does not start, even when I can successfully get other lights to come on. I don't want to spend >$100. for a new control panel if that is not really the problem.
Try pushing the Sani-Rinse and Air Dry buttons back and forth a number of times.
Posted on Jan 31, 2008
I knew it was a sequence too, but wasn't for sure what it was...but, I pushed the water heat button, then the no dry heat button, 2 times, ..then..ALL of the buttons lit up...I pushed cancel. Let is sit for a bit, pushed the normal wash button, and then, the dishwasher worked great thru all its cycles. Mine is a sears kenmore ultrawash with quiet guard system...around 10 years old.
Posted on Sep 15, 2009
I lights and all works and sounds like it comes on but water will come in..
Posted on Mar 27, 2010
2 Suggested Answers
guru_dev
  • 315 Answers
SOURCE: Kenmore Dishwasher won't drain
If you opened and closed the door and it started, that sounds like a bad, door switch in the console.
But you did hear a hum sound when it tryed to drain, it could be the drain solenoid, or the motor/pump assembly.
Take off the bottom access and look at the solenoid when it starts to drain, the piston in the solenoid should move freely, up and down with the white drain flapper that it connects to.
Also check for bad wiring connections at the power junction box where the power hooks up to it under the dishwasher, i have seen the wire nuts either come loose or burn off due to loose connections.
Posted on Jul 02, 2009
Kenmore elite dishwasher manual
The cancel light is on because the cycle maybe paused or canceled. The lit red button should say Cancel/Drain. If you already tried to press start and if it won't finish the cycle then try pressing the Cancel/Drain to drain and start over.
Aug 15, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
Whirlpool DU915PWSSO dishwasher. When door is closed lights work. I can push start and select options, but nothing happens. No noise, no water, nothing. Pushing Cancel/Drain does appear to make the...
try pulling off the bottom spray arm under that plastic cowel is the filter system clean it out . take the cowel off and its very easy to clean the filter if that doesnt work then underneath the dishwasher where the water inlet is there is a valve . it has two outlets one going to the dishwaser and one coming from your water supply . check to make sure u have continuity going thru the valve if its not working replace the valve (word of caution turn off the water when replacing valve ) Also before changing the valve pull off both hoses from the valve there is a filter in each inlet make sure they r clear and not plugged
Oct 03, 2013 | Dishwashers
Dishwasher hums
empty out the unit and recheck the arm and rack then start it up empty and check operation --if huming but working properly --stated it does drain so motor is operating ---then its operating normal ---if arm still not working will need to remove arm and check gear or shaft for damage
Apr 16, 2017 | Kenmore Dishwashers
Dishwasher not draining
You may have lost your pump,replace or repair.
or if you can check the hose for blockage.
Jan 31, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Kenmore dishwaser
Unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Feb 16, 2008 | Kenmore 15769 Built-in Dishwasher
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Kenmore 24 in. 15142 Built-in Dishwasher Logo
4,274 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
