Can you walk me through how to remove the coins trapped in the washing machine? I suspect I have the same problem and the machine stops at 11 minutes while trying to drain.
The pump assembly is mounted to the right rear area of the base. REMOVAL 1. Disconnect power to the unit. 2. Spread a towel below the drain hoses prior to loosening the hose clamps. This will catch any residual water left in the hoses and sump area. 3. Remove the hose clamps and hoses from the pump. 4. Remove the wiring harness from the pump motor terminals. 5. Rotate the pump assembly in a counterclockwise direction. The support legs of the pump are slotted to engage in keyed slots in the base. Reverse the steps to remount the pump.
CLEANING THE PUMP The pump assembly can also be disassembled without removing the hoses from the pump
1. Depress the locking tab on the face of the pump housing. 2. Rotate the block portion of the pump containing the motor windings toward the front of the washer. This will disengage the locking tabs of the pump housing from the pump face. 3. Carefully remove the pump body away from the housing. The drain impeller is exposed for cleaning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
This could be coins or other debris under the tumblers.
If you want to DIY the fix see this post you need the Service Manual nad a number 20 TORX driver to remove the tumblers. SM left that info out.
Google this for a link to the SM 5th post in.
""Neptune TL Washer FAV6800AWW"" I can help you at that DIY forum.
Google this
""FAV6800A/FAV9800A Outer Tub bearing replacement""
I helped a couple forum members get thru Outer Tub bearing rebuild. One of the forum members took some pics where you will view the Tumblers removed. It
There is a coin trap in the pump most likely is pluged // u have one machine that is very hard to write down how to take apart as you have to remove the door lift top remove front panal .. pump is on the lower right ..I would leave that one to a pro if you never done one before......good luck
The Service manual has the procedure starting on page 37 for the tumbler removal. It’s not difficult to remove the manual doesn’t call out the Torx driver size required for tumbler removal.You will need a number 20 Torx driver to remove the Torx screw for tumbler removal. I would get a long Number 20 Torx driver for this. See page 37 of the Service Manual for tumbler removal. Looks worse than it is.
The Service Manual for reference. Sears Parts Direct for reference. When I did a recent Outer Tub Bearing replacement I found $1.78 in coins after removing the wash basket. Gotta check those pockets....:)
I have a post around somewhere of my diy Sump Screen I put in my FAV6800AW to protect the drain pump impeller from coins and other stuff from breaking the impeller or causing clogs. I'll look for the post or repost the pic's.........D*ick
when a person has coins in their pockets & forget to take them out,when the clothing is wash sometimes the coins don't get washed out,, but when you put the clothing in the dryer the tumbling will help the coins come out of the pockets that when they go to the dryer lint trap or bottom of dryer
I sounds like this is a common problem with the Maytag Neptune TL after about 3-5 years. Mine finally went out yesterday after several months of bearings getting louder all of the time. It looks like the bearings and the controller are gone. What happened to washing machines that last 15 - 20 years?
if the drum wont spin it could be the motor carbon brushes ,all machines have a drain trap some get accsess from the front of the machine some are acsessed from under the machine these get everything from bits of clothes ,coins, another possability is the pump witch drains the machine
Check the pump, pressure switch and related hose for small obsctructions. For reasons unknown they moved the pressure switch location to above the pump.
