Question about Power Acoustik TS980-2 2 Channel 980W Synchronized Lightning Pulses Plasma Sphere Amplifier Car Audio Amplifier
Amplifier does not turn on anymore.
I recieved a Power Acoustik amplifier for Christmas a few years back. When I first set it up, it worked great. About three weeks later, however, it triggered the red protection lamp. For a while, it would work if you jostled the remote line. Now, nothing seems to turn it on. If you unplug the RCA cables, the light turns off, and the amp is completely unresponsive. (The light is supposed to be green when active) Also, this "Red Light" issue only applies to pre-amped RCA outs. If you plug it into the standard RCA outs, nothing happens. Also, disconnecting the subwoofers has absolutely no effect either. The Stats: RECIEVER: Originally, I had a Pioneer Premier DEH-P560MP Then, I temporarily replaced it with a Dual XDM6810 with Preamped RCA outputs. AMPLIFIER: Mosfet, Bridgeable, Crossover, HPF/LPF, Bass Boost, 2ohm Stable SUBWOOFERS: Dual XNBP12D 1100W Bandpass Sub System; 4ohm impedence Any information would help. The tech support at Power Acoustik simply told me "Either your ohm rating is off, or your amp is junk". That suuuure does help. I've toyed with the idea of crackin open the case and hotwiring over the power protection circuit.... But something makes me thing that that's a horrible idea. Haha. Thanks.
    Novelist:
    Champion:
  • 219 Answers
You cannot wire "over" or "around" the protection circuit. Even if you know enough to know what the circuit was, you shouldn't bypass it and force the amp to turn on. It is doing exactly what it is supposed to do, which is protect the amp and your speakers from catastrophic failure and possible fire or damaged speakers. If you are bridging your speakers then you may have put too much load on your outputs and fried them. If you put two 4ohm speakers in parallel, you will have a 2ohm load and if you then connect that 2ohm load to a bridged amp, you will be subjecting each of the bridged output channels to a 1ohm load because they will share that 2ohm load. This of course will blow the outputs and it usually takes about one month to do it. In your case it sounds like it only took 3 weeks. The long and the short of it is that it is now time to take your amp to the shop for some repair time. Sorry that it's not good news.
Posted on Apr 23, 2007
Look fix of conection line blak of cabel ithes+
Posted on Apr 22, 2007
Where can i buy a Power Acoustik TS1920-2 2 Channel 1920W...
you will get from
Sonic Electronix 28340 Avenue Crocker
Suite #202
Valencia, CA 91355
Nov 03, 2011 | Power Acoustik TS1920-2 2 Channel 1920W...
Power protect light stays on my amp its a power acoustic ps2-820
Unplug all the speaker wires and try it again, if the amplifier turn on
yo have a bad speaker, if the ampliier still in protection mode, check all the fuses in the amplifier and near the battery,
if they are ok you have a bad amplifier
good luck
Apr 01, 2010 | Power Acoustik PS2-820 Car Audio Amplifier
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
4 AWG amp wire
For that amplifier you need to be running 0 gauge wire . Also check your ground to make sure you have the best connection possible.
May 16, 2009 | Power Acoustik A2400DB Car Audio Amplifier
My amp goes in protect mode
Maybe the audio amplifier IC´s are damaged
Feb 06, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Amp Not working!
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Let me know if you have any other questions.
Sep 20, 2008 | Power Acoustik TS620-2 Synchronized...
Power Acoustik TS620-2 Amplifier
Check the wiring at the speakers themselves. It's possible that while you were moving the box one of the speaker wires came loose and shorted against the other terminal. A shorted speaker wire or damaged speaker will cause the amplifier to go into protect mode. If you have a digital multimeter with a resistance feature, you can test the resistance between the positive and negative terminals for each speaker.
Feb 26, 2007 | Power Acoustik TS620-2 Car Audio Amplifier
Car Audio & Video Logo
191 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Jose Velazquez
Jose Velazquez
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
