Question about Maytag Atlantis MAV6000 Top Load Washer
Hello, Our Maytag washer drum is stuck - Maytag Atlantis MAV6000 Top Load Washer
  • 2 more comments
  • pigtails1234 Dec 27, 2008
    Sorry, I accidently posted this without writing the rest. I noticed someone else had this same problem and followed the instructions posted on how to open/check for socks or other clothing. I've done this and was unable to find anything between the drums or in either of the two hoses. I'm stuck now and not sure where to go from here. Is there something else that could be causing this problem? The water is able to run but the cycle stops when it gets to Rinse/Spin.
    Thanks!
  • pigtails1234 Dec 28, 2008
    No, the washer doesn't agitate and doesn't drain.
  • Anonymous Jan 07, 2009
    Thanks for the reply. I was finally able to purchase a lid switch but now I'm unable to figure out how to remove/replace the old one.
  • pigtails1234 Jan 07, 2009
    Thanks for the reply. I was finally able to purchase a lid switch but I am now having trouble figuring out how to remove/replace the old one.
  • 61 Answers
Hello, the most common problem was clothing objects getting stuck between the inner tub and the top tub cover, run your fingers between the two and see if you feel any stuck clothing (socks) for example. Good luck
Posted on Dec 27, 2008
  • graham mcdonald Dec 27, 2008
    Hello, I need to know does the washer agitate and does the washer drain. A faulty lid switch is a possibity .
  • graham mcdonald Dec 28, 2008
    Hello, then i would purchase and replace the lid switch.
Clicking noise
More than likely a bra wire stuck,,,get a torch,stick ur head inside drum & have a look,,,pulled hundreds out over the years
Jun 16, 2013 | Maytag Washing Machines
Maytag Nuptune washer in spin cycle sounds like a plane taking off
Something small, like a paperclip or the wire from an underwire bra can get stuck in the holes in the drum, and rub against the outer drum. You will have to check carefully to find it.
Mar 16, 2012 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
There is a grinding noise during the wash and spin cycles.
hello,
the problem is from the jet strew it indicate that the jet strew need to be reset it at the back of the washer it is connected to the main drum it is commonly call propeller or roller it is the cost of the noise
because it has loss it position connected to the drum
unscrew the washer and see the propeller connected to the drum .
thank you and thanks for using fixya.
Jun 11, 2010 | Maytag MAH2400A Front Load Washer
Grinding while tub is turning
There is probably something stuck in the drom or the drum seal. I would check for the underwire from a bra this is a commmon problem the wire comes out and gets stuck in holes in the drum.
Mar 04, 2010 | Maytag NFW7200TW Front Load Washer
My top loading washer the water come in but it want move and" there is a smoke smell
It sounds like you have a bad belt, possibly because the drum is stuck. Make sure the drum turns freely and then change the belt.
Jan 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer will not spin. motor overheats and drum won't turn
If it has a belt try loosening the belt and see if the transmission and pump will turn and are not stuck.
If they are they will have to be replaced. Try the motor and see if it turns freely with the belt loose or off. If they all turn freely check motor.
Jun 09, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis screeches @ end of spin cycle,
may be something stuck in the drum or a segment raised on the motor. to test either remove the belt and spin the drum if no noise then the motor is faulty. if a noise then there may be a bra wire between the drum/tub.
Mar 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Coins stuck in washer
I've used a butter knife or putty knife to pry them up.. just enough to allow the coins to slide back out. Just roll the drum back and forth with the knife wedged in there. Good Luck.
Jan 25, 2009 | Maytag Neptune MAH6700A Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
238 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
