Video card or Power supply?
I have a HP Pavilion a1642x. Its pretty cheap buy i intended to replace certain parts for gaming. So i first got a video card. its a
xfx 8800gs pci-e, not the best but good for what it cost. it helped alot but with the default RAM i was very limited. So i bought so kingston RAM 2x1gb cards compared to the default 2x512mb. This helped tremendously in cooling my PC and helping the Video card. i thought ''since its so cool i should try overclocking the graphics.'' So i downloaded ntune,i know about rivertune, and safely raised the juice. After a few tests i found the max without a fail, about 710mhz. After about 1 day i had a crash. At first i thought the bestec fail finally happened but now im not so sure. i unplugged certain things to rule out faulty parts. i tried unplugging the p1 and to my amazment it worked. the led was now static but when i tried plugging it back in it shutdown.
then it was the video cards turn. i unplugged the six-holed pci plug and started my computer. i got a loud static beep. i completly removed the card to find my computer booted.
So i either fried the card or had a bestec psu fail. any help or opinion is appreciated a dont really need a fix, i just need to know what to replace for sure as im not made of money.
  • 1 more comment
  • foggydog1 Dec 27, 2008
    i thought about that but i put the card back in to make sure. now i got a static green led in back but no response to the power button
    im sorry i wasted your time. it seems a friend thought he broke my computer and started to tinker with it making it worse i have resolved the problem buy plugging in the p10 the p9 and the p7 in the correct slots and found that fixed my problem again sry for wasting your time
  • Thomas F. Schneider May 11, 2010
    If it booted w/o the card in,then I doubt that is it is the power supply unit.
  • 38 Answers
Well if you overclocked you video card you have to increase your video card voltage by using bios for not having a crash. this could be as well your overclocking problem. try to use your default video card clocks and sea what will happen. it could be becouse your psu is low on power four your computer components.
Posted on Oct 03, 2009
Replace power supply motherboard
Replacing power supply mother board risks fire and shock. For the cost of a new supply, It is far better to replace it. I believe that is a standard power supply. You can buy them from Staples or Best Buy for cheap.. If you're not sure of the correct part, remove the old one (only 4 screws and a few cables) Make note of cable connection locations.. but really, it is pretty hard to put a plug into the wrong socket. Bring the old supply to your supplier of choice and match it with a new one.. Higher wattage is OK, lower is not
Good luck
Jan 15, 2014 | HEWLETT-PACKARD Hewlett Packard Pavilion...
What is the best video card for gaming for hp a1726x pc desktop
Depends on the game and the minium requirements. You computer does have a PCI express x16 slot open, so you will want a video card for that slot. The other issue will be a power supply. Like most brands HP puts in the cheapest power supply they can. An extended graphics card will draw more power and therefor wear out your power supply. I would look for something in the range of a 750Watt power supply at minimum. If you post more information about the game you want to play (or games), we can assist you further.
Hope this helps.
Feb 14, 2012 | HP Hewlett Packard Pavilion a1726x PC...
I have an HP pavilion with an AMD Phenom X4 9750 processor with an Nvidia GeForce 9100 graphics card. I have noticed a ridiculous decrease in frame rate that happens randomly while i play pc games...
hi,
you may even find a new graphics card won't help. you are most likley suffering from an overheated northbridge. there not usually monitored for temp this is on the MB so, not good news as this will eventually go dead. and even re- greasing at this point won't help. however. by disassembling both the video card and northbridge heat sinks. you should find one of them pretty dried out.
GL
hope this helps
don't forget to vote for me
Thanks
Jamer
Jul 12, 2011 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
I HAVE A HP PAVILION SLIMLINE (S5310F) AND WANT TO PUT IN A VIDRO CARD, SO I NEED A LARGER POWER SUPPLY. HOW DOO I DO THAT?
Replacing the Power Supply DEPENDING on the power needed? you might have to settle for a slower, weaker performing video card. Make sure you check the video card power supply specs needed.
Chances are you will max WATT at about 300WATTs less then what you'd need to power a gaming video card. OR you could do as I'd do.
Remove everything and place it all in a standard tower case - install a 650WATT power supply in to the new mid/full size case and BAM solution found.. Have fun and a great day to ya.
Oct 10, 2010 | HP (0950-3952) (09503952) 425-Watt Power...
I want to upgrade video card for my pc(HP Pavillion a1120n) i wanted to know what kind of video card is compitible with my pc. please help thanks. ;)
From what I gather, your computer has a PCIe v1.0 slot for a video card upgrade and comes with intel on-board video. So you will need a PCIe 2.0 video card (v1.0 are no longer available and 2.0 are backwards compatible)
I assume, like most PC's, yours has a 350-450 Watt Power Supply. Check your power supply to be sure, you just can't put any video card, you are limited to the available power from the power supply. If you want a top of the line video card for gaming you will need a more powerful power supply. If all you need is better performance and better video quality (DVI/HDMI) then any sub $100 dollars card will do.
I cannot emphasize enough, check your power supply wattage capacity and the watts required by the new card before buying.
Also, do you have additional power connection from the power supply for the new card? most cards, not all, require a 6-pin PCIe power connector.
For the average user I recommend:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130395
Mar 13, 2010 | HP Pavilion a1120n (PX759AA) PC Desktop
Need to upgrade video graphics card for HP a305w.
That computer has 3 PCI slots. (I got the specs here: http://www4.dealtime.com/xPF-HP-Compaq-A305W-Intel-Celeron-2-7GHz-256MB-DDR-40GB-HDD-CD-RW-10-100Mbps-LAN-Support-Wind ).
The 6200 is compatible, just make sure it's the PCI version and not PCI-E.
Jul 19, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
HP Pavilion 250 watt PSU that includes a Nvidia GeForce 9300
The maximum output of a PSU simply means it is able to supply a certain amount of power. It can also deliver anything under the wattage. Where you fry things is where the connectors are wrong. HP, COmpaq, Dell, IBM have all, at times, used nonstandard connectors in their PCs. If you take something with a standard connector, and use it in a machine where that connector needs to nonstandard, you can fry stuff.
Feb 02, 2009 | HP Computers & Internet
Upgrade Video Card
I would recommend picking up a higher watt power supply just to keep up with the changing demands on computers. They are not to do yourself. If still wondering what cards can go with a 300 watt power: Maybe an ATi Radeon 9250 256mb? It seems that a 350 watt power supply should still be minimum nowadays and they are cheap.
Oct 30, 2007 | HP Pavilion m7480n (882780389410) PC...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
